Aux fans. - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 07-01-2019, 02:28 PM Thread Starter
Tbilisi79's Avatar
Date registered: Oct 2005
Vehicle: 420SEL
Quoted: 113 Post(s)
Send a message via Yahoo to Tbilisi79
Aux fans.
Guys. One of the auxiliary fans decided to work on and off. If I give it a jolt it usually come back on.
Can I replace just one fan or do I have to change out both ?
Most online shops donít specify they are selling a stand alone single fan or a replacement fan for dual setup.
Autohaus az has a fan that says left. This mightíve it.
Again. I started the car. It didnít work. Bit the fan with a hand and it bbs tarts working.
Thanks.
Tbilisi79 is offline
post #2 of 7 (permalink) Old 07-01-2019, 05:55 PM
John350's Avatar
Date registered: Nov 2014
Vehicle: 1990 350SDL, "Grandpa's Roadster" Project Car
Quoted: 824 Post(s)
That'll do it every time!
John350 is offline
post #3 of 7 (permalink) Old 07-02-2019, 02:09 AM
ianrandom's Avatar
Date registered: Jul 2008
Vehicle: 1986/1990 W126
Quoted: 1204 Post(s)
Hehe.
But yeah, are your fans running the whole time usually then? I guess it might be because it's really hot where you are, but according to the behaviour of both mine, and my AC guy, they should only come on when needed. AC pressure raising past a certain point, or engine temp the same.
We got the pressure wrong on my SE and the aux fan ran whenever I turned on the AC. Also the AC was sub par. So we adjusted the pressure as basically too much freon I think, and all was well again.
'86 420SE
'90 420SEC
Daily transport 9spd Giant DH Comp downhill bike
ianrandom is offline
post #4 of 7 (permalink) Old 07-02-2019, 02:06 PM Thread Starter
Tbilisi79's Avatar
Vehicle: 420SEL
Quoted: 113 Post(s)
So get a single fan and replace one of the fans ? I assume the are interchangeable ?
post #5 of 7 (permalink) Old 07-03-2019, 06:46 AM Thread Starter
Tbilisi79's Avatar
Vehicle: 420SEL
Quoted: 113 Post(s)
Aux fans.
Let some Freon out. Not my intention as the valve got stuck till I got it to close.
Low pressure at 45-50, was 60 yesterday.
Idling in 85F weather ac is blowing 50f. Both fans working since gave it a wack yesterday.
40f while moving.
post #6 of 7 (permalink) Old 07-03-2019, 10:40 AM
Date registered: Feb 2008
Vehicle: Too many to list
Quoted: 1549 Post(s)
Just douse some lube on the fan bearings it’s probably good for another 30 years
tusabes is offline
post #7 of 7 (permalink) Old 07-03-2019, 02:28 PM
luckymike's Avatar
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1989 560SEL, 1995 E420
Quoted: 581 Post(s)
Sounds like it's time for new brushes in your fan motor.
luckymike is offline
