Did the and sensor snap off - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 06-19-2019, 12:35 AM Thread Starter
Date registered: May 2018
Vehicle: 1988 Mercedes 500 sec
Quoted: 41 Post(s)
Removing the old and sensor and this is how it came out in assuming in pic the sensor is still stuck in
If so can I heat this area and pull it out or will it damage something
First pic is the part of the susp leg second pic is sensor removed
ID:	2522110   Click image for larger version
Benz 1 is offline
post #2 of 8 (permalink) Old 06-19-2019, 02:47 AM Thread Starter
Quoted: 41 Post(s)
Did the abs sensor snap off
Sorry just realised title not correct this is the front leg and sensor
Benz 1 is offline
post #3 of 8 (permalink) Old 06-19-2019, 03:58 AM
Stutz's Avatar
Date registered: Oct 2009
Vehicle: 1999 500SL, 1988 SEC
Quoted: 249 Post(s)
If you have a torch that will heat that area quickly it should be ok. Just be careful of ball joint. I would also letpenetrating oil soak it overnight.
Stutz is offline
post #4 of 8 (permalink) Old 06-19-2019, 04:11 AM Thread Starter
Quoted: 41 Post(s)
thanks just didnt want to heat it as wasnt sure if there was just the hole for sensor to fit in or other bits for the abs
the ball joit is being replaced any way, that will be another problem when i get to it
Benz 1 is offline
post #5 of 8 (permalink) Old 06-19-2019, 04:36 AM
humblejoe's Avatar
Date registered: Feb 2007
Vehicle: 04 odyssey (265k) 1995 E320 wagon (295k)
Quoted: 326 Post(s)
If you take hub and rotor off you can use a punch and tap it out from the front.
mramay likes this.
"alte Schulqualität"
W124, One of the last great gifts of West Germany
humblejoe is online now
post #6 of 8 (permalink) Old 06-19-2019, 05:24 AM
Date registered: Nov 2018
Vehicle: 1991 560SEL
Quoted: 116 Post(s)
if you are removing the arm and havent touched the other side yet? Suggestion that I learned from here: Leave the sensor in place, but disconnect/unplug from the other end. Eliminates risk of damaging sensor by removal
lesguy is offline
post #7 of 8 (permalink) Old 06-19-2019, 06:17 AM Thread Starter
Quoted: 41 Post(s)
humblejoe thanks that sounds like a good idea, i had to remove the sensor as it was stuck on solid new one nearly £200 havent an old one to put back in
Benz 1 is offline
post #8 of 8 (permalink) Old 06-19-2019, 01:00 PM Thread Starter
Quoted: 41 Post(s)
Thanks for everyone's advice sensor has successfully been removed
ianrandom likes this.
Benz 1 is offline
