Mercedes-Benz Forum (https://www.benzworld.org/forums/)
-   W126 S,SE,SEC,SEL,SD,SDL Class (https://www.benzworld.org/forums/w126-s-se-sec-sel-sd/)
-   -   should i replace all the rubber bushes front susp refurb (https://www.benzworld.org/forums/w126-s-se-sec-sel-sd/3029582-should-i-replace-all-rubber-bushes.html)
Benz 1 06-18-2019 01:07 PM
i am rebuilding the front and rear suspension on the sec will be seprating shotblasting and then painting all the bits,
should i change all the rubber bushes or are there any which do not really need doing at 113000 miles
the front alone just rubber bushes and ball joints will be im excess of £1300 still have the rear to do
if they should be done i will do them but some still seem strong with no play
ianrandom 06-18-2019 01:58 PM
Its a lot of money, but non MB quality down there is usually pointless and a waste of work.
The car will probably be amazing to drive with all new bushings up front. Its amazing how long the originals last, but they must be a bit on the harder side by now.
rumb 06-18-2019 02:05 PM
I replaced everything up front including shocks and the ride is fantastic. While in that area I purchased new inner fender liners as the old were getting brittle and who knows how much longer MB will provide them.
Benz 1 06-18-2019 02:29 PM
yes i will try get some lemforder parts as they are same as Mercedes original
I am literally stripping every single part and bush front rear prop shaft flex discs etc will use some lemforder some from Mercedes
does it make that much difference to the ride quality
C Cortez 06-18-2019 05:37 PM
To paraphrase some of the more experienced members of this forum : " ... if you are doing the hard work, reward yourself and your car with OE parts.." -- specially for important parts like suspension.
Take a look at comments on Lemforder on this and other forums. The net sense that i get is that parts made in fatherland are fine, EU parts mostly fine. China manufacturers are a no-no. Getting back to Lemforder, it appears that they are now stamping parts manufactured in many countries, including China.
Given that we are saving a ton by doing the work ourselves, i err on the side of never having to worry if i have a good quality replacement part.
My $ 0.02
humblejoe 06-18-2019 05:48 PM
If you plan on keeping it longer than two years, go top shelf. Unless you like redoing it, if it's some kind of Zen therapy. Then by all means go 100% Shenzen😁
Got the sheet metal all welded in?
Benz 1 06-19-2019 12:32 AM
Guess you can't win didnt realise lemforder were stamping Chinese parts
When you say OE are you referring to mercedes equivalents parts directly from mercedes
Most of the mercedes parts are also made elsewhere and stamped with mercedes
Don't mind paying for better quality bits as im doing the Labour but it seems expensive isnt always better
Eg lemforder ball joint kit £40 mercedes it is just over £100 but prob is lemforder
ianrandom 06-19-2019 02:32 AM
Mercedes is always better. They had their own quality control, so Mercedes Bosch for example is better than Bosch.
Its changing, slowly and the last bastion of quality there seems to be starting to ebb away a little. We've had a couple accounts of Mercedes parts not fitting properly now.
But for me it's still better than the unknown. Especially rubber.
Beware that OE term, its a bit of a popular term in the US and its often misleading to get sales.
Fonzi 06-19-2019 08:28 PM
I will throw some counter-opinion out there. Learning HOW to do it is the challenge in my mind. What tools? What parts? The lessons can be learned the first time around. Once you know how to do it. Itís always easier the second time around, the confidence, etc. That actually makes me not mind doing things more than once. Do you use long life synthetic oil to avoid oil changes? Or do you enjoy going back and doing the job quickly? Me? Iím fine changing the brake pads on my wifeís car and getting faster at it. Iím not worried if the brake pads last forever.
But if you are doing a top shelf restoration on your car, then yeah, nice new MB rubber feels good.
Heikkif 06-20-2019 09:59 AM
Lemforder lower ball joints seem to be made in Malaysia. I am not sure what to think of thatÖ.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
