1983 euro model charging problem - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 06-15-2019, 03:15 AM Thread Starter
Date registered: Sep 2014
Vehicle: 1983 280sl I6 euro model
Need help:
ignition on ...red light on start car ignition light off. batter volts 12.7 before start . wont charge. REPLACED ALTERNATOR . NEW BATTERY .
IS THERE A FUSE SOMEPLACE? HOW DO i DIAGNOSE?
Thanks.
clintackerman is offline
post #2 of 7 (permalink) Old 06-18-2019, 02:18 AM
ianrandom's Avatar
Date registered: Jul 2008
Vehicle: 1986/1990 W126
Quoted: 1203 Post(s)
All I can think of is checking the cables especially the ground.
'86 420SE
'90 420SEC
Daily transport 9spd Giant DH Comp downhill bike
ianrandom is offline
post #3 of 7 (permalink) Old 06-18-2019, 07:13 PM
aam
Greek God of the R129
aam's Avatar
Date registered: Dec 2004
Vehicle: SL500-500SEL-190E
Quoted: 231 Post(s)
Ignition key on. All dash warning lights on.
Check the battery light, it should be ON.
If its not, replace the bulb, or, broken disconnected wire.
The light is the signal/sensor, that makes the alternator charge.
Regards,
aam.
aam is offline
post #4 of 7 (permalink) Old 06-20-2019, 03:27 AM Thread Starter
STILL NOODLIING OUT THE CHARGING ISSUE
Here is specific vehicle information:
1983 280SE EURO MODEL MERCEDES
THE ENGINE NUMBER IS 110 989 126 155
VIN # IS WDB 126 02211 207 9595
I will run a good ground from the engine to the battery to see what happens.
will take a few days since the two piece alternator pulley spun and will need to be replaced.
Also....can i check the alternator by measuring voltage...see pic.
the new alternator may be defective.
post #5 of 7 (permalink) Old 06-20-2019, 05:15 AM
ianrandom's Avatar
Good call, could well be a faulty alternator, especially if its a cheaper one. But even if not, don't rule it out.
I keep a little cheap charge Led indicator that tells me how many volts, just in case. Plugs into the cigarette lighter. You could try that as an easy option and you can see how it behave while running.
'86 420SE
'90 420SEC
post #6 of 7 (permalink) Old 07-31-2019, 12:40 PM
Date registered: Mar 2018
Vehicle: 92 300DT om603 swap
Quoted: 6 Post(s)
Have you resolved this issue? It seems I have the same problem.
fildyb is offline
post #7 of 7 (permalink) Old 08-01-2019, 02:51 AM
plinker17722's Avatar
Date registered: Mar 2015
Vehicle: 1989 W124 260E
Quoted: 161 Post(s)
First if you have ant contacts like the one in the picture i would clean them all up to start with . Might even be the battery clamps fouled up inside .. Earth return problems are a major factor in failure of 90% of all electrical issues .
plinker17722 is offline
