Center vents intermittent - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 06-14-2019, 09:07 AM Thread Starter
gogi's Avatar
Date registered: Jan 2008
Vehicle: 1991 560sec. 1969 280SL
Quoted: 236 Post(s)
For my 1991 560sec. My Mityvac pump hooked up to the Gang of Four tells me I need the diaphragms in #38 defroster pod and also #42 where there are two pods also need diaphragms see schematic below. Im hoping the pod that is visible behind the climate control panel is the defroster pod. Can 281lxm, liviu, John350, Wooky Chewy Baca or anyone whos replaced the defroster pod please confirm this.
Id really like to just replace these three pods and not go replacing all of them because maybe their all the same age. When and if I have more or all the rest to replace at a later date then that will give me another reason to tinker with my baby.
Thanks in advance for any and all advise/response.
gogi is offline
post #2 of 11 (permalink) Old 06-14-2019, 10:42 AM
Supporting Vendor
AutohausAZ's Avatar
Date registered: Dec 2004
Vehicle: Too Many to List
Quoted: 31 Post(s)
We carry a few vacuum actuators for that HVAC system: https://www.autohausaz.com/catalog/c...tor?s=d&page=1
Visit the AutohausAZ Vendor Section for special pricing for Benzworld members:
AutohausAZ is offline
post #3 of 11 (permalink) Old 06-14-2019, 11:54 AM
mramay's Avatar
Date registered: Feb 2005
Vehicle: Two '87 570SECs, one '87 560SEL
Quoted: 256 Post(s)
I replaced the center vent vacuum pod though the vents, with some long hemostats and a long screwdriver. The vent blade assembly (the directional vane thingy that is used to direct air) comes out easily, then while the replacement isn't simple, it can be done without disassembling the dash.
vdubpower likes this.
Blasphemous Mike
US '87 560SEC with Euro headlights, clear markers, H&Rs, 17x8.5/Nitto's, ATE slotted rotors with ceramic pads, BergWerks FGS, 3.07 Limited Slip. '87 560SEL with Euro Headlights, lowered, 235/40/17's
mramay is online now
post #4 of 11 (permalink) Old 06-14-2019, 04:47 PM Thread Starter
gogi's Avatar
Quoted: 236 Post(s)
As stated in the thread my question is simply to replace the defroster pod. The fresh/recirculated air pods Im, pretty sure I have to remove the passenger air bag to replace.
gogi is offline
post #5 of 11 (permalink) Old 06-14-2019, 09:48 PM
mramay's Avatar
Quoted: 256 Post(s)
I believe the center vent pod *is* the dash & defroster vacuum motor. Could be wrong (been there many times). What say the experts??
Blasphemous Mike
post #6 of 11 (permalink) Old 06-14-2019, 10:39 PM
vdubpower's Avatar
Date registered: Nov 2003
Vehicle: 1985 500sel and 500sec 2012 E63 1989 Porsche 911
Quoted: 552 Post(s)
my darn center pods just went out....15 yrs ago has them replaced...i wonder if that is typical life span
i like to drive with ECON on just to get some air in the car...and run AC obviously when too hot, even tho my system is full of leaks.
Anyways, is there a way to just rig the pods to stay open, if i dont need to have defrost/ or heater options ever used?
1985 500SEL Euro Nautic Blue - A Classic Beauty
1985 500SEC Euro Nautic Blue
1989 Porsche 911 Carrera Silver Anniversary Edition
2012 E63 AMG Iridium Silver - Performance Package
vdubpower is offline
post #7 of 11 (permalink) Old 06-15-2019, 04:38 AM Thread Starter
gogi's Avatar
Quoted: 236 Post(s)
If you look at the schematic in my first post #40 is the pod for center vents and #38 is for the defroster.
gogi is offline
post #8 of 11 (permalink) Old 06-16-2019, 12:41 PM
mclare's Avatar
Date registered: Aug 2008
Vehicle: 2012 CL550 4MATIC Coupe
Quoted: 311 Post(s)
Send a message via Yahoo to mclare Send a message via Skype™ to mclare
There's one of them that's all the way under and is a total bitch to replace!
I did mine when the unit was removed.
mramay likes this.
Current Stable:
2012 CL550 C4 4MATIC Coupe
Past cars:
1991-560 SEC AMG - Coupe - 199/261 - 300 HP Custom Built Motor - Highly Modified Coupe.
1990-560 SEL - Sedan - 199/261 - Stock. Euro Headlamps & Wipers
1987 560 SEC Black/Tan
1988 420 SEL Champagne/Brown
mclare is offline
post #9 of 11 (permalink) Old 06-16-2019, 02:09 PM
mramay's Avatar
Quoted: 256 Post(s)
I believe (a guess) that the pod straight back in through the dashboard center vents is your culprit. It's (thankfully) been a while since I've been in there but it might be possible to make a hook out of coat-hanger wire and pull the pod's arm into the position you want, then bend the outside end to hook it into position.
Blasphemous Mike
post #10 of 11 (permalink) Old 06-16-2019, 03:22 PM
Stutz's Avatar
Date registered: Oct 2009
Vehicle: 1999 500SL, 1988 SEC
Quoted: 250 Post(s)
You can do all of them with the dash in but its difficult. The glovebox, radio, heating control and drivers side panel has to come out. There are write ups on it
Stutz is offline
