Water pump fan bolt and vicious clutch - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 06-11-2019, 07:28 PM Thread Starter
Eneli Aaving's Avatar
Date registered: Jun 2019
Hi fellow Merc lovers.
I have 1990 W126 300 SE
I need to chance vicious fan clutch, but the Allen head of the bolt is gone.
So my question is...do anyone know what thread that bolt has?
So I colud pre buy it before I take aux fans and radiator off to drill the bolt out and replace clutch and the bolt.
Also, maybe someoknows some tips or tricks to make it as painless as possible.
Thank you
Eneli Aaving is offline
post #2 of 14 (permalink) Old 06-11-2019, 09:00 PM
mramay's Avatar
Date registered: Feb 2005
Vehicle: Two '87 570SECs, one '87 560SEL
Quoted: 249 Post(s)
Please complete your profile - where upon this planet do you reside? It does help us help you (you might be just down the road from someone here).
Never have seen the fan held onto the water pump with allen head bolts? They've all been 10mm headed bolts. Are you asking about those four bolts?? Define "gone" - allen head stripped out or the round head of the allen bolt has broken off??
Don't remember the thread size for those but they're very common on the car, nothing special. Take one that came out to a Fastener Shop and they'll be able to match it easily.
ianrandom likes this.
Blasphemous Mike
US '87 560SEC with Euro headlights, clear markers, H&Rs, 17x8.5/Nitto's, ATE slotted rotors with ceramic pads, BergWerks FGS, 3.07 Limited Slip. '87 560SEL with Euro Headlights, lowered, 235/40/17's
mramay is offline
post #3 of 14 (permalink) Old 06-11-2019, 09:05 PM
luckymike's Avatar
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1989 560SEL, 1995 E420
Quoted: 553 Post(s)
Thank you
You could just buy the replacement bolt from Mercedes?
ianrandom and liviu165 like this.
luckymike is offline
post #4 of 14 (permalink) Old 06-12-2019, 12:22 AM Thread Starter
Hi. Thank you for your time.
I am still learning to use this forum, trying yo update my details asap. I am located in Brisbane AUS.
So the Allen head is stripped out by someone. And I guess, I need to remove one middle bolt to get the cooling fan and the clutch out.
Probably MB shops would be good idea, but would like to know what they need to sell me. Otherwise I still might come home with the wrong bolt and I discover it when I can not drive anymore. Ps, picture of the bolt is from a YouTube video.
post #5 of 14 (permalink) Old 06-12-2019, 01:15 AM
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6.
Quoted: 1809 Post(s)
The torque on those bolts is not very high. If you can reach the protruding head, a quality vise grip and use a pipe for leverage might help.
Even a thrashed vise grip is still cheaper than 1 hour at the mechanic shop. I happen to have HQ cobalt drill bits incl a set of 'Left Turn' drill bits.
Using those to drill a hole to use my easy out bits for broken and damaged bolts (beside R, I also have left turn easy outs), most of the time the bad bolt will already come out with drilling, as the bit is turning in the correct direction for removal.
US forum members can just go to one of the top stickies for the service manual, perhaps a UK, NZ or fellow Aussie member will post up the pm?
Cheers
Btw, the attachment shows hot to complete your profile.
Teutone is offline
post #6 of 14 (permalink) Old 06-12-2019, 02:26 AM
plinker17722's Avatar
Date registered: Mar 2015
Vehicle: 1989 W124 260E
Quoted: 134 Post(s)
Bolt
The fan clutch bolt is not an allen wrench bit but a star torque bit . Was the right bit used to remove the bolt?? See picture . Mercedes part Number is 0000 0000 04 138 By the way yoiu will see 4 bolts at the rear of the unit these 4 bolts hold both bearing holder and fan clutch .Should be easy to remove the whole item bearing and fan clutch in one , once you remove these 4 bolots . Look on you tube video to see how its done.
This is a retro ride .
plinker17722 is online now
post #7 of 14 (permalink) Old 06-12-2019, 02:40 AM
Quoted: 134 Post(s)
fan
As i was saying this is the layout of the 4 bolts in question. And remember if you remove fan blades it must only go on one way or it will blow air out from the engine and not draw it in to cool the radiator.
mramay likes this.
post #8 of 14 (permalink) Old 06-12-2019, 05:31 AM Thread Starter
Thank you. I will definitely look into those 4 bolt more carefully.
I think so far everyone has assumed that it is an Allen key, I'll try torque as well. Thank you for the part number. I'll try to call into few MB stores now whwn I have bit more of information.
I've added sample of the one YouTube video where it is suggested that it is Allen key, have found some misleading information then 😕
post #9 of 14 (permalink) Old 06-13-2019, 01:42 AM
Seppo's Avatar
Date registered: Dec 2008
Vehicle: MB 300SE '90, anthrazite grey, black leather
Quoted: 8 Post(s)
In my 300SE (M103), it is indeed an allen key (originally anyway); I think the picture above is from a V8 motor. You will also need the tool to hold the pulley in place.
plinker17722 likes this.
W 126 300 SE -90 anthrazite grey, > 650 000 km, DD
W 123 200 D -84 classic white, > 620 000 km, ru(/e)sting
(W 140 S 320 -95, blue black, > 405 000 km, wife's)
Seppo is offline
post #10 of 14 (permalink) Old 06-13-2019, 01:49 AM
Quoted: 134 Post(s)
If you canot remove the centre bolt just remove the 4 bolts to get fan and bearing off in one then you can work on the torque head bolt removal when you have it on the bench.
