How to determine whether hazard switch or relay is bad - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 06-10-2019, 06:25 PM Thread Starter
Date registered: Jun 2019
Quoted: 2 Post(s)
Hi All,
I have a Euro 1985 500 SEC. I just purchased the car and am trying to get it inspected but the emergency flashers are not working. The blinkers all work when activated by the stalk. If I press the button to turn the hazards on, the blinkers will no longer work with the stalk. If I turn emergency hazard switch off, the blinkers work just fine again when activated by the turn signal stalk. Can either the hazard switch or the relay be deemed good or bad with this information?
dinguskahn is offline
post #2 of 6 (permalink) Old 06-10-2019, 07:37 PM
gogi's Avatar
Date registered: Jan 2008
Vehicle: 1991 560sec. 1969 280SL
Quoted: 238 Post(s)
Originally Posted by dinguskahn View Post
Hi All,
I would clean or replace hazard switch. You may get lucky if you turn switch on and off about 10-15 times rapidly probably corrosion buildup inside of hazard switch.
gogi is offline
post #3 of 6 (permalink) Old 06-10-2019, 08:07 PM Thread Starter
Quoted: 2 Post(s)
I took it apart and rubbed all the contact points with an abrasive pad until they were shiny. No change in how it operates other than above.
Can I conclude the relay is good if the blinkers work? Is it definitely the switch knowing the above situation? Just trying not to throw parts at it if I can avoid it.
post #4 of 6 (permalink) Old 06-10-2019, 09:14 PM
Date registered: May 2019
Vehicle: 1998 W210 E320 base saloon USA version
Quoted: 16 Post(s)
Test the switch electrically with a multi meter first.
I would not exclude the relay given your description.
SD_GR is offline
post #5 of 6 (permalink) Old 06-10-2019, 11:31 PM
vx255's Avatar
Date registered: Apr 2019
Quoted: 4 Post(s)
Pull the hazard switch out and hit it with some contact cleaner spray.
vx255 is offline
post #6 of 6 (permalink) Old 06-11-2019, 05:03 AM
gogi's Avatar
Quoted: 238 Post(s)
I believe the the turn signals and the hazard switch share the same circuit.
^^ What he says above. Check continuity of the switch with a multi meter, that way you’ll know if the switch is faulty.
gogi is offline
