Coolant temp sensor for CIS - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 06-09-2019, 09:40 AM Thread Starter
Date registered: Nov 2018
Vehicle: 1991 560SEL
Quoted: 117 Post(s)
There is a fair aMount of conflicting information as to the type and location of the sensor. 4 pole, 2 pole green, by the firewall, by the thermostat housing. Can someone review the pics and let me know if my sensor that sends a signal to the cold start injector, is the two prong blue one?
ID:	2519062   Click image for larger version
lesguy is offline
post #2 of 6 (permalink) Old 06-09-2019, 09:42 AM Thread Starter
Quoted: 117 Post(s)
It appears that this was the former location of that same sensor (but 4 pole) on earlier models?
lesguy is offline
post #3 of 6 (permalink) Old 06-09-2019, 09:44 AM Thread Starter
Quoted: 117 Post(s)
And lastly, is this the one I need? When I enter 1991 560 SEL it says that this is not compatible. https://rover.ebay.com/rover/0/0/0?m...2F350909551121
lesguy is offline
post #4 of 6 (permalink) Old 06-09-2019, 03:48 PM
gogi's Avatar
Date registered: Jan 2008
Vehicle: 1991 560sec. 1969 280SL
Quoted: 237 Post(s)
No Les that is not the one. The one you want has four prongs itís black and round under a black, one inch diameter plug on top of intake manifold behind the idle control valve. You have to remove the air cleaner to see it.
GreenT likes this.
gogi is offline
post #5 of 6 (permalink) Old 06-09-2019, 04:08 PM Thread Starter
Quoted: 117 Post(s)
Thanks. Me thinks I’ve found it. This one? Circled in yellow? If so, appears to be part #0085423217
ID:	2519110   Click image for larger version
lesguy is offline
post #6 of 6 (permalink) Old 06-09-2019, 05:53 PM
GreenT's Avatar
Date registered: Mar 2013
Vehicle: 1995 S500 - 1986 420SEL
Quoted: 10539 Post(s)
That's the one.
lesguy likes this.
GreenT is online now
