Radiator drain plug identification - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-08-2019, 09:22 AM Thread Starter
isthenew's Avatar
Date registered: Jan 2014
Vehicle: 1989 300SE 232k miles
Quoted: 219 Post(s)
Hello All,
I went to change my coolant today and ran into a problem. I can not remove the radiator drain plug. It is not removable by a normal screw driver. The plug has 2 parallel indentions that I assume are for a special tool. It actually looks like a female, 2-prong electrical outlet.
I attached a picture. Does anyone know what this is? Where I can buy the proper removal tool? Or another way I can remove this?
Thanks,
Bill
isthenew is offline
post #2 of 3 (permalink) Old 06-08-2019, 12:49 PM
gogi's Avatar
Date registered: Jan 2008
Vehicle: 1991 560sec. 1969 280SL
Quoted: 238 Post(s)
Get two normal straight blade screw drivers put them both in the slots hold them parallel and, use a longer screw driver at right angles between the two screw drivers and turn counterclockwise
isthenew likes this.
gogi is offline
post #3 of 3 (permalink) Old 06-10-2019, 05:55 PM Thread Starter
isthenew's Avatar
Quoted: 219 Post(s)
This is fantastic! I put 2 flat-head screwdrivers in there, but I could not figure out how to turn the handles. That said, I tried this, adding the 3rd screwdriver. It's not working. I can't get enough leverage, even w/the screwdriver as a handle, to turn the plug. I may wind up just using a reverse bit to remove it and install s different plug.
isthenew is offline
