Can a Gen2 Climate Control unit work in a Gen1? - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 06-04-2019, 09:18 PM Thread Starter
corellian corvette's Avatar
Date registered: Dec 2014
Vehicle: 1991 560SEC
Quoted: 166 Post(s)
I know the way it mounts to the dash wood are different, but assuming I swapped that over too, would the physical unit work?
My current Gen1 unit is going bad and won't close the defrost vents. I have some good Gen2 units I think which I was thinking I would swap in.
Thoughts?
1991 560 SEC Euro
1986 420 SEL
1985 500 SEC (US)
1983 500 SEC (Euro)
corellian corvette is offline
post #2 of 9 (permalink) Old 06-05-2019, 06:15 AM
MBL87560SEC's Avatar
Date registered: Jul 2004
Vehicle: 1991 500SEC sub 50K mi. 1987 560SEC Now 150K mi. 2018
Quoted: 403 Post(s)
Hi there,
I may be misunderstanding you as to what is meant by the word 'units', but if you mean the vacuum pod actuator [101] for defroster nozzle flap A0008004375, it is the same Gen 1 to Gen 2.
Hope that sheds some light.
M.
Name:	Screen Shot 2019-06-05 at 9.17.46 AM.png
91 500SEC EURO Germany
87 560SEC USA 49 State Version
MBL87560SEC is offline
post #3 of 9 (permalink) Old 06-05-2019, 09:14 AM
bsclifton's Avatar
Date registered: Jan 2008
Vehicle: 1991 560SEC / 2007 S550
Quoted: 124 Post(s)
I think he means the overall unit (where the push buttons and scrollie wheel are)
1991 560SEC; 145,187 miles
2013 GL550; 99,960 miles
Previous cars
2007 S550; 146,541 miles (sold)
2009 C300; 95,861 miles (sold)
2006 S430; 101,719 miles (sold)
2001 SL500; 114,032 miles (sold)
1986 560SEL; 150,276 miles (hit by drunk driver)
bsclifton is online now
post #4 of 9 (permalink) Old 06-05-2019, 09:56 AM
Date registered: Nov 2002
Vehicle: '82 500sec euro, '95 Ford F150
Quoted: 148 Post(s)
No. It’s also different dimensions as well as the plugs are different.
roadhouse is offline
post #5 of 9 (permalink) Old 06-05-2019, 10:03 AM
liviu165's Avatar
Date registered: Aug 2013
Vehicle: 1989 MB 420SEL, 1991 560SEC
Quoted: 626 Post(s)
Yes, he is referring to the actual controller.
A comparison between the electrical schematics of Gen 1 and Gen 2 will offer the first clue. There were some things changed between the two generations, just like the window switches and for that reason the windows switches are not easily interchangeable. That may also be the case with the climate controller, although I am inclined to believe that in this case the interchange may be possible but the connectors may have to be swapped and wired differently.
liviu165 is offline
post #6 of 9 (permalink) Old 06-05-2019, 10:07 AM
liviu165's Avatar
Quoted: 626 Post(s)
Originally Posted by roadhouse View Post
No. Itís also different dimensions as well as the plugs are different.
I envisioned that the dimensions may be different but wasn't sure. At any rate, he can solve that by using a Gen2 wood plate and then he deals with the electrical wiring. I am assuming that the overall dimensions of the wood plate are the same.
Or he can use parts from a Gen2 to repair the Gen1 unit.
liviu165 is offline
post #7 of 9 (permalink) Old 06-05-2019, 11:12 AM
1783pictures's Avatar
Date registered: Feb 2016
Vehicle: 85 500SEC (Euro), 87 560SEC (now sold)
Location: Eastern NC (formerly China, NYC and Connecticut)
Quoted: 334 Post(s)
How different are they in actual operation? My 560SEC's auto setting was terrific. As I altered the temp dial it would reduce in strength gradually, much like a modern system. Not as advanced, but noticeable. With my 500SEC Auto is essentially 60 to 65% strength and nothing less. It never lowers in power.
1783pictures is offline
post #8 of 9 (permalink) Old 06-05-2019, 10:48 PM
magicbigdaddy's Avatar
Date registered: Dec 2006
Vehicle: 1989 560 SEC - V-8 Kompressor - 95 E320 Estate
Quoted: 327 Post(s)
If my memory is correct, 20 years ago I had a GenI SEC and when the auxiliary heater water pump failed it would "take out" the controller and would require either a replacement or rebuild as the circuit board inside would fry a couple contacts. Haven't seen this happen on GenII. One would imagine improvements were added to the GenII units. Same buttons but different circuits inside.
roadhouse and AxelWulff like this.
1989 560 SEC Supercharged - 317+ rwhp - H&R lowered - OZ 3 piece staggered wheels - upgraded brakes - AMG Tri-Y's - Bergwerks FGS - a true Euro Rod
1981 500SE euro AMG
1985 euro 500SEC
1986 560 SEC
1985 500SEL
1989 560SEC
1990 560SEL
1987 euro 560SEL 300hp 822 engine option
magicbigdaddy is offline
post #9 of 9 (permalink) Old 06-06-2019, 08:07 AM
mramay's Avatar
Date registered: Feb 2005
Vehicle: Two '87 570SECs, one '87 560SEL
Quoted: 256 Post(s)
Not closing the defrost vents is a function of a vacuum pod. These fail. I'd bet that this pod is dying or there are significant vacuum leaks elsewhere that won't allow enough vacuum to that pod. Pull off the right side of the console to get to the vacuum manifold, pull a vacuum on the line going to that pod and see if 1. it holds a vacuum (isn't leaking) and 2. the defrost vent moves properly.
Pull the center vent air direction control thingys (the vanes you move to blow the air right/left) and you can see this pod about a foot inside the dash.
I changed out that pod's rubber diaphragm without disassembling the dashboard to get the pod in/out, but it was a PITA.
AxelWulff and gogi like this.
Blasphemous Mike
US '87 560SEC with Euro headlights, clear markers, H&Rs, 17x8.5/Nitto's, ATE slotted rotors with ceramic pads, BergWerks FGS, 3.07 Limited Slip. '87 560SEL with Euro Headlights, lowered, 235/40/17's
mramay is offline
