Rims / lug bolts / W126 vs R129 q's - Page 3 - Mercedes-Benz Forum
post #21 of 24 (permalink) Old 06-16-2019, 09:34 PM
Date registered: Feb 2008
Vehicle: Too many to list
Quoted: 1549 Post(s)
there should be model numbers stamped into the back side of those rims under all the brake dust and corrosion
I had The same problem , discovering two rims I bought from the same car were 1 inch different, they sent me a front and rear instead of two rears !!
ID:	2521002   Click image for larger version
tusabes is offline
post #22 of 24 (permalink) Old 06-17-2019, 01:35 PM Thread Starter
isthenew's Avatar
Date registered: Jan 2014
Vehicle: 1989 300SE 232k miles
Quoted: 223 Post(s)
I could not find any information stamped on any of the replacement rims, other than the words "Chrome Tech." As such I didn't bother looking at the OEM.
In any case, I mounted the 40mm rim to a front hub. It clears the outer tie rod end by like 1 mm. And I'm not comfortable with that. So I switched, placing the 60mm on front. It was clear of the tie rod end. But the 40mm rims won't mount on the back. They don't clear the car.
So I'm done w/these. Gonna sell them (and my 60mm bolts) and buy 2 new tires for the OEM rims.
Oh, and when I drive now, I'm getting a fun and exciting grind from my left rear hub; the one where I put the 60mm bolt into the 40mm rim and I tightened into things that never should experience those bolts. Here's hoping it's not too difficult a repair....
Thanks for all the help.
isthenew is offline
post #23 of 24 (permalink) Old 06-17-2019, 02:00 PM
Sounds like you damaged the parking brake
tusabes is offline
post #24 of 24 (permalink) Old 06-17-2019, 03:08 PM Thread Starter
isthenew's Avatar
Quoted: 223 Post(s)
Cool. That's my thought. Here's hoping it'll make it back to the warehouse. And it's not too badly damaged.
Nothing like finding your way around a car due to your own mistakes
isthenew is offline
