No interior lights or Seat Belt Warning Lights - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-20-2019, 11:47 PM Thread Starter
Date registered: May 2019
Vehicle: 1986 W126 300SE
Angry No interior lights or Seat Belt Warning Lights
Hi, I am new to this forum and have just acquired my second classic motor vehicle. This1986 W126 300 SE has an interior front and rear courtesy light and seat belt warning lights built into the front courtesy light roof cluster. My mechanic has checked all fuses and all bulbs and they are fine. None of these lights work when you open any door or use the slider switch. All door switches are fine as the courtesy lights in the bottom of each door activate with no problem. Also, the switch in the front cluster (accommodating the roof courtesy light and seat belt warning lights) for the sun roof is fully operational. Can anyone advise what the problem might be. It is a fully imported Australian delivered vehicle. Thanking you for your time. Regards Dave:
davekave is offline
post #2 of 3 (permalink) Old 05-21-2019, 04:45 PM
Moderately subtle
edfreeman's Avatar
Date registered: Dec 2003
Vehicle: 94 E500, 97 500SL
Quoted: 175 Post(s)
Send a message via AIM to edfreeman
Moved to correct forum.
edfreeman is offline
post #3 of 3 (permalink) Old 05-25-2019, 03:41 PM
alexstorm's Avatar
Date registered: Jan 2011
Vehicle: 1983 380-SEL, '67 220D (sold), '65 200D (sold), '75 L-206D (sold)
Quoted: 52 Post(s)
Since multiple lights fail, it's logical to assume that the ground might be bad. Check that voltage passes through correctly on each event with an ohmmeter.
alexstorm is offline
Seats Leather Remove & Refit New Leather Coverings / Seat Removal Merc-S600 W140 S-Class 62 11-14-2016 06:31 PM
New upholstery ScottinSoCal R/C107 SL/SLC Class 94 12-29-2012 01:43 PM
Fixing stuck rear seat ML series atss2006 General Mercedes-Benz 0 10-11-2011 07:33 AM
Seat Belt Warning Chime cerritos W210 E-Class 4 02-28-2011 11:06 AM
Seat Belt Warning 04mbc230 General Mercedes-Benz 3 07-14-2010 03:28 PM
