M117 560 SL Engine / Rocker Arm Adjustment - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 05-20-2019, 08:36 AM Thread Starter
Date registered: Aug 2009
Vehicle: W107 W113
Quoted: 87 Post(s)
Hello,
I am hearing a slight ticking sound coming from one of the rocker arms, can the hydro rocker adjuster (see attached picture) be adjusted to reduce any slack?
M117 560 SL Engine / Rocker Arm Adjustment-screenshot_20190520_175948.jpg
Sent from my MAR-LX1M using Tapatalk
R107
S320L1999 is online now
post #2 of 6 (permalink) Old 05-20-2019, 11:09 AM
Date registered: Apr 2019
Vehicle: 1990 420 SEC
Quoted: 5 Post(s)
There was a thread on this subject recently:
https://www.benzworld.org/forums/w12...djustment.html
Heikkif is online now
post #3 of 6 (permalink) Old 05-20-2019, 02:03 PM
Stutz's Avatar
Date registered: Oct 2009
Vehicle: 1999 500SL, 1988 SEC
Quoted: 239 Post(s)
Yikes, see the thread by me on this. The only adjustments are by getting different pucks under the rockers. You need a go no go tool to check things though
Stutz is offline
post #4 of 6 (permalink) Old 05-20-2019, 02:10 PM Thread Starter
Vehicle: W107 W113
Quoted: 87 Post(s)
Just read through (parts) of your odyssey - I luckily only have a slight ticking sound coming from one single rocker.
What do you suggest, go for a thinner pluck?
R107
post #5 of 6 (permalink) Old 05-21-2019, 04:23 PM
Stutz's Avatar
Quoted: 239 Post(s)
You have to get the gauge and figure if you need a thinner or thicker puck. In my case I needed thinner since I had a valve job done. I have a few I could send but again I need to know size
Stutz is offline
post #6 of 6 (permalink) Old 05-21-2019, 07:10 PM
John350's Avatar
Date registered: Nov 2014
Vehicle: 1990 350SDL, "Grandpa's Roadster" Project Car
Quoted: 800 Post(s)
Originally Posted by S320L1999 View Post
... I luckily only have a slight ticking sound coming from one single rocker.
What do you suggest,...
They should not need adjustment over the life of the engine. That's what the hydraulic compensator is for. Either your compensator is not holding pressure as it should or you have abnormal wear of either the cam or the rocker (or both). Any way you look at it, adjusting it is a temporary cure at best.
John
"Real engines don't have spark plugs!"
John350 is offline
KE-Jetronic Lambda control (duty cycle) adjustment H.D. W124 E,CE,D,TD Class 46 02-22-2019 03:37 AM
Updated part numbers for suspension bushings? Steve_B W140 S-Class 37 12-13-2017 08:23 AM
Engine Shocks/ Engine mount arm question Blaxmith W123 E,CE,D,CD,TD,TE Class 2 06-16-2016 12:25 AM
1968-93 North American MBZ Models MercedesFan1981 General Mercedes-Benz 2 05-24-2012 10:10 PM
Advisability of 560 Engine in 420 ? Coinarian W126 S,SE,SEC,SEL,SD,SDL Class 4 10-11-2006 05:30 AM
