Anyone have lower balljoint tool to loan/rent? - Mercedes-Benz Forum
post #1 of 23 (permalink) Old 05-18-2019, 05:55 AM Thread Starter
Date registered: Nov 2018
Vehicle: 1991 560SEL
Quoted: 103 Post(s)
prefer to not try the remove the rubber boot and ham a c clamp method, but rather, use the proper tool/method. And not having luck finding local mb Indy shop to do the work/none have the tool. Thanks!
lesguy is online now
post #2 of 23 (permalink) Old 05-18-2019, 10:12 AM
Dikdaan's Avatar
Date registered: Jan 2014
Vehicle: 1977 450 SEL 6.9
Quoted: 118 Post(s)
I am pretty sure you can get these on ebay for not a lot of $
Dikdaan is offline
post #3 of 23 (permalink) Old 05-18-2019, 11:05 AM Thread Starter
Quoted: 103 Post(s)
I searched and did not find one. Only one I found is on pelican parts for $500
post #4 of 23 (permalink) Old 05-18-2019, 12:52 PM
liviu165's Avatar
Date registered: Aug 2013
Vehicle: 1989 MB 420SEL, 1991 560SEC
Quoted: 624 Post(s)
Thai one works great: https://www.ebay.com/itm/Mercedes-Be...QAAOxyd5tRyNJl
You just need a hydraulic press.
luckymike likes this.
liviu165 is online now
post #5 of 23 (permalink) Old 05-18-2019, 08:46 PM
Martin_UK's Avatar
Date registered: Aug 2014
Vehicle: W126 1990 500SE (ASR) & W126 1991 300SE
Quoted: 7 Post(s)
I've been wondering about this, as it's on my list of jobs to do at some point. Why doesn't an ordinary ball joint press kit work? Something like this for example: https://www.ebay.com/itm/21PC-C-PRES...R/401213893695
Martin_UK is offline
post #6 of 23 (permalink) Old 05-18-2019, 09:36 PM
liviu165's Avatar
Quoted: 624 Post(s)
Who said it doesn't work? Instead of doing experiments, I used the one in the link above (post 4), but that doesn't mean anything else wouldn't work. Perhaps when time comes for you to replace your ball joints, you buy the one in the link you posted, try to use it and share with us your experience for everybody's benefit.
post #7 of 23 (permalink) Old 05-18-2019, 09:39 PM
Martin_UK's Avatar
Quoted: 7 Post(s)
Well, I remember when asking around for quotes to do this job, some garages, even Mercedes ones, said that they did not have the 'special tool' that was needed to press these joints. So I assumed that there was some reason for a widely available one not to be suitable.
post #8 of 23 (permalink) Old 05-18-2019, 09:45 PM
luckymike's Avatar
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1989 560SEL, 1995 E420
Quoted: 553 Post(s)
I think if you compare the MB tool with the generic eBay ones like you linked to, you'll find the eBay version doesn't clear the steering knuckle at the joint
The MB tool will install the ball joint in the car, the tube-style that liviu linked to requires stripping down the knuckle and using a press. But it really works great. I own that tube-style, too, thanks to liviu and it's very slick. If you have, or have access to a press, that is.
liviu165 likes this.
luckymike is offline
post #9 of 23 (permalink) Old 05-18-2019, 09:50 PM
Martin_UK's Avatar
Quoted: 7 Post(s)
Ok, that makes sense. So, if I don't have access to a press (which I don't), but don't mind stripping the car down, then I can go with a generic set?
post #10 of 23 (permalink) Old 05-18-2019, 09:55 PM
luckymike's Avatar
Quoted: 553 Post(s)
Nope. The generic set is too bulky to fit into the knuckle and get a direct push on the ball joint, in my experience. As liviu said, it would be nice if you wanted to try and then let us know. I've only tried one generic and there may be other versions that would work.
WTB: Used W-210 lower control bushing tool jessejames4 For Sale/Wanted/Trade/Giveaway 0 09-12-2014 06:52 PM
The dreaded suspension work??? MAVA W140 S-Class 50 08-16-2014 03:19 PM
FS: Tools & Tool Cabinet - Chilliwack, BC Jolly Roger For Sale/Wanted/Trade/Giveaway 0 10-07-2012 12:45 PM
Anyone have the lower control arm bushing tool and spring compressor to loan me? Schweinhund W210 E-Class 15 09-05-2012 09:20 PM
Selling W210 Lower control arm tool brandon671 W210 E-Class 5 09-24-2011 05:56 AM
