Iso-Octane - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 05-17-2019, 06:23 PM Thread Starter
Tom Kaiser's Avatar
Date registered: Jul 2010
Vehicle: 1989 SEL 560
Quoted: 134 Post(s)
Iso-Octane
MB Maintenance Manual 14-450 (page 2) recommends the use of Iso-Octane to test for leaks of fuel lines, intake system, fuel distributor, and injection valves. I am unable to find that product available for my use.
Where can I obtain Iso-Octane?
Tom Kaiser is offline
post #2 of 7 (permalink) Old 05-17-2019, 07:21 PM
Vehicle: '85 300D Turbo, '91 420SEL, '92 190E 2.6, '09 C350, '12 E63 Wagon
Quoted: 581 Post(s)
Iso-Octane
Look for 2,2,4-Trimethylpentane:
https://www.fishersci.com/us/en/prod...isooctane.html
I looked at the 99% one it’s quite expensive, $50.70 for 500 mL.
Tom Kaiser likes this.
jzchen is online now
post #3 of 7 (permalink) Old 05-17-2019, 07:23 PM
Quoted: 581 Post(s)
But I never bought any for such purpose. (Just wanted to help you source it).
post #4 of 7 (permalink) Old 05-18-2019, 04:38 AM Thread Starter
Tom Kaiser's Avatar
Quoted: 134 Post(s)
The associated Safety Statements make me wonder if I should pursue this product:
Safety and Handling
GHS H Statement:
May be fatal if swallowed and enters airways.
Very toxic to aquatic life with long lasting effects.
May cause drowsiness or dizziness.
Causes skin irritation.
Highly flammable liquid and vapor.
GHS P Statement:
Avoid breathing dust/fume/gas/mist/vapors/spray.
IF SWALLOWED: Immediately call a POISON CENTRE or doctor/physician.
Do NOT induce vomiting.
Avoid release to the environment.
IF ON SKIN: Wash with plenty of soap and water.
Keep away from heat/sparks/open flames/hot surfaces. - No smoking.
Ground/Bond container and receiving equipment.
WARNING: The information provided on this web site was developed in compliance with European Union (EU) regulations and is correct to the best of our knowledge, information and belief at the date of its publication. The information given is designed only as a guide for safe handling and use. It is not to be considered as either a warranty or quality specification.
GHS Signal Word: Danger [Will Robinson]
post #5 of 7 (permalink) Old 05-18-2019, 05:04 AM
John350's Avatar
Date registered: Nov 2014
Vehicle: 1990 350SDL, "Grandpa's Roadster" Project Car
Quoted: 800 Post(s)
Not fuel lines (that's a separate sentence.). It's just a check for vacuum leaks. You can use carb cleaner, propane, anything moderately flammable will work.
John
"Real engines don't have spark plugs!"
John350 is offline
post #6 of 7 (permalink) Old 05-18-2019, 06:52 AM
Quoted: 581 Post(s)
There is another chemical in automotive grade fuel that is/was a known carcinogen at the time of publication, I believe benzene. (Should be in the same text as you saw the iso-octane). It is given as the reason not to use plain old gasoline.
I noticed that 2,2,4-Trimethylhexane is used as a pesticide, which means somehow when it’s done killing pests may be somewhat safer....
post #7 of 7 (permalink) Old 05-18-2019, 08:01 AM
nugent's Avatar
Date registered: Jul 2005
Vehicle: 2008 E350 110k, 2000 E320 143k, 1983 380SEC 240k
Quoted: 117 Post(s)
By definition, i-octane has a Research Octane Number (RON) of 100 (n-heptane is 0). But I cannot see why gasoline would not be ok for the purpose.
nugent is offline
1998 E430 Catalytic Converter noises rebelmdot General Mercedes-Benz 9 04-21-2010 03:51 PM
Fuel Change?? MaxR129 R129 SL-Class 9 06-21-2009 08:33 AM
Home made fuel Additives Von Maximo R/C107 SL/SLC Class 8 12-24-2006 01:39 PM
Does the ML 320 really need premium gas? Jeff Schaeffer W163 M-Class 29 11-20-2006 08:03 PM
