Re-timing Engine After New Timing Chain/Tensioners & Rocker Arm Replacement? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 05-16-2019, 08:52 AM Thread Starter
Date registered: Apr 2019
Vehicle: 1990 420SEL
Quoted: 5 Post(s)
Completed timing chain replacement including tensioner/guide rails. Put back together and runs (after a few hiccups) great at idle. Haven't had it on road yet due to waiting on rims to be powder coated, but after searching I was not able to determine if it's recommended to put a timing light on engine due to r & r of distributor?
Also - I believe I have 1 or 2 rocker arms that need replacement. Okay to just replace rocker arm and leave original shim in place if no evidence of wear?
JR420 is online now
post #2 of 5 (permalink) Old 05-16-2019, 09:04 AM
Date registered: Jul 2018
Vehicle: 1990 300SE
Quoted: 27 Post(s)
on your car timing is done by a sensor near the flywheel so you don't have to do that.
engines 1985 and older get their timing signal from the distributor and they have to set their timing but you don't, 1986 and newer cars the distributor is there to hold the cap and rotor that's all.
when replacing rocker arms fsm says to check clearance:
https://www.startekinfo.com/StarTek/..._56/05-213.pdf
why do you want to replace them?
christuna is online now
post #3 of 5 (permalink) Old 05-16-2019, 09:26 AM Thread Starter
Quoted: 5 Post(s)
Thanks, good to know on timing.
I have a slight ticking noise coming from front passenger side valve cover and that leads me to believe it is likely a rocker? No issue with lubrication as I can see steady stream of oil coming out of cam oiler.
JR420 is online now
post #4 of 5 (permalink) Old 05-16-2019, 09:59 AM
Vehicle: 1990 300SE
Quoted: 27 Post(s)
hydraulic "lifter" is always a possibility
post #5 of 5 (permalink) Old 05-16-2019, 10:04 AM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 68 250S, 91 300se, 98 SL500, 450SEL 6.9, 14 CLS550 Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 804 Post(s)
That would be a hydraulic valve compensator not the rocker arm.
Long read on a recent adventure correcting same problem:
https://www.benzworld.org/forums/w12...djustment.html
mramay likes this.
rumb is offline
Injection Pump fuel adjustment for the MW and M pumps, engine tuning and maintenance Forcedinduction W123 E,CE,D,CD,TD,TE Class 5 11-28-2017 01:19 AM
Timing chain replacement, engine wont turn need help AfricaXJ6 W126 S,SE,SEC,SEL,SD,SDL Class 7 10-07-2012 06:55 AM
2005 S430 code P2734 and P0748 car in Limp Mode Help!!! iBan W220 S-Class 25 06-20-2012 05:37 AM
1968-93 North American MBZ Models MercedesFan1981 General Mercedes-Benz 2 05-24-2012 10:10 PM
New V8 diesel formally announced GregW / Oregon W164 M-Class 0 05-20-2005 09:00 PM
