Rough start warm, fuel accumulator? - Mercedes-Benz Forum
post #1 of 33 (permalink) Old 05-14-2019, 11:01 PM Thread Starter
BGW500's Avatar
Date registered: Jun 2018
Vehicle: 85 Mercedes 500 SEC
Quoted: 40 Post(s)
1985 500SEC When it starts cold it's fine and reaches operating temp or nearly then has a hesitation. Sometimes when it's a warm start it takes awhile to start and then runs rough for a bit and smoothes out. I thought the accumulator must keep pressure because cold starting was fine but now I read somewhere that the accumulator can affect warm starts so might be up for a new one but will that affect performance when running at operating temperature if it has an issue? It seems to be when the cold start injector cuts out I have an issue or it's masking something.
BGW500 is offline
post #2 of 33 (permalink) Old 05-15-2019, 07:49 AM
John350's Avatar
Date registered: Nov 2014
Vehicle: 1990 350SDL, "Grandpa's Roadster" Project Car
Quoted: 791 Post(s)
Do a system pressure test to see if the system holds pressure. There are cold start aids that mask pressure problems when cold, but when warm the engine can't quickly develop enough pressure to deliver fuel.
plinker17722 likes this.
John
"Real engines don't have spark plugs!"
John350 is offline
post #3 of 33 (permalink) Old 05-15-2019, 04:59 PM
MBL87560SEC's Avatar
Date registered: Jul 2004
Vehicle: 1991 500SEC sub 50K mi. 1987 560SEC Now 150K mi. 2018
Quoted: 388 Post(s)
Hi there,
John is correct, doing a system pressure check is what needs to happen here.
The main function of the accumulator is to maintain 'rest' pressure for that hot restart, say 5 to 20-ish minutes from the time the warm engine has been shut off.
As the engine runs, the accumulator provides a damping effect as well.
"Takes a while to start and then runs rough for a bit and smoothes out." indicates to these eyes, that one or more of the injectors are likely dripping raw fuel into the ports when shut off, thus causing low/no rest pressure.. and the plug fouling that clears with driving.
The proper operation of the cold start valve means it only operates when the starter motor is engaged, and never on that hot restart condition.
Good Luck,
MBL
ianrandom and isthenew like this.
91 500SEC EURO Germany
87 560SEC USA 49 State Version
MBL87560SEC is offline
post #4 of 33 (permalink) Old 05-16-2019, 05:52 AM Thread Starter
BGW500's Avatar
Quoted: 40 Post(s)
Thanks for your help. I'll have to get the fuel pressure tested then. Did I read some where that's around 5.3 to 5.5? The hesitation I get when warm would still be from injectors then? I've had a miss in it but this feels definitely fuel related and cuts in about 70 degrees. I thought it might be fuel filter but there's a definite pattern to it. The other thing is if I play with the air/fuel mixture it seems to come good for a day and then plays up again.
BGW500 is offline
post #5 of 33 (permalink) Old 05-16-2019, 06:28 AM
Date registered: Nov 2018
Vehicle: 1991 560SEL
Quoted: 87 Post(s)
I experience (randomly) the same symptoms as described here. After replacing the accumulator, filter, and both pumps (somewhat of a preventative thing, as all of the above had a fair amount of corrosion including all clamps, and all appeared original from 1991), I still have the issue as well. Since the car is a weekend pleasure car, havent given much attention to the issue, but would like to eventually address.
My question(im new to working on fuel injection systems, other than filter changes): How does one troubleshoot this:
"one or more of the injectors are likely dripping raw fuel into the ports when shut off"
lesguy is online now
post #6 of 33 (permalink) Old 05-16-2019, 07:39 AM Thread Starter
BGW500's Avatar
Quoted: 40 Post(s)
Yes mine is just a weekend car too. It's just annoying because I got it running really sweet and it was nice to drive. Changed the thermo and now I have issues again.
BGW500 is offline
post #7 of 33 (permalink) Old 05-16-2019, 09:17 AM
luckymike's Avatar
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1989 560SEL, 1995 E420
Quoted: 535 Post(s)
I suppose a leak down test might indicate leaking injectors if you're sure everything else is tight. Best is to pull the injectors and test them. I use a homemade tester.
Another possibility is the seal at the bottom of the control piston in the fuel distributor. If it's leaking at rest, you're going to get extra fuel puddling in the rubber boot underneath. You can check this with a strong light and mirror.
lesguy likes this.
luckymike is online now
post #8 of 33 (permalink) Old 05-16-2019, 10:06 PM Thread Starter
BGW500's Avatar
Quoted: 40 Post(s)
Does all those suggestions relate to the hesitation that starts at operating temp as well? Or is that a separate issue? It does feel like more of a fuel issue than a spark issue but I could be wrong.
BGW500 is offline
post #9 of 33 (permalink) Old 05-17-2019, 12:07 AM
Seppo's Avatar
Date registered: Dec 2008
Vehicle: MB 300SE -90, > 640 000 km
Quoted: 8 Post(s)
Mine used to do the similarly (although M103 motor; required often two starts when warm, took a few seconds to start running smoothly), new injectors cured the problem.
Good luck,
Seppo
W 126 300 SE -90 anthrazite grey, > 650 000 km, DD
W 123 200 D -84 classic white, > 620 000 km, ru(/e)sting
(W 140 S 320 -95, blue black, > 405 000 km, wife's)
Seppo is offline
post #10 of 33 (permalink) Old 05-17-2019, 07:55 AM
luckymike's Avatar
Quoted: 535 Post(s)
If you're referring to mine, it depends on the severity of the injector or control piston leak. You need extra fuel at a cold start so those leaks could be masked. They can definitely be an issue for warm starts.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Martin_UK
GL350 2010 Cold Start Problems Nface21 X166 GL / GLS-Class 0 11-03-2018 12:58 PM
HARD START PROBLEM SOLVED - R&R FPR (FUEL PRESSURE REGULATOR) DIY mclare W126 S,SE,SEC,SEL,SD,SDL Class 12 07-11-2017 12:15 PM
W140 Fix it Yourself Articles Merc600sec W140 S-Class 265 11-04-2015 11:17 PM
Bosch KE-Jetronic Overview isthisdave R/C107 SL/SLC Class 16 11-20-2012 03:33 PM
Fuel pressure regulator Vs accumulator NewMBie W126 S,SE,SEC,SEL,SD,SDL Class 2 03-22-2005 01:03 AM
