painting headlight wipers - Mercedes-Benz Forum
post #1 of 23 (permalink) Old 05-14-2019, 04:45 AM Thread Starter
Date registered: Jan 2007
Vehicle: 1979 280 SLC, 1987 560SEC, 1995 E280T
Quoted: 6 Post(s)
Dear fellow enthusiasts, has anyone ever attempted to paint the plastic cap covering the spindle and the base of the headlight wiper? On every W126, the color of the cap has mostly disappeared whereas the wiper arm itself has largely kept its original color.
If so, what is the result when the base is repainted and does anyone have suggestions for a good color match (e.g. Revell model paint)? Did you use a primer?
Thanks,
Tempur
tempur is offline
post #2 of 23 (permalink) Old 05-14-2019, 06:11 AM
ianrandom's Avatar
Date registered: Jul 2008
Vehicle: 1986/1990 W126
Quoted: 1159 Post(s)
Yes, many times. Just key the surface well and clean well. I used different paints but no problems with any. Plastic paint worked well.
I did loads of pairs actually and sold them on to raise money for other car parts, quite a few sold on here ages ago.
'86 420SE
'90 420SEC
Daily transport 9spd Giant DH Comp downhill bike
ianrandom is offline
post #3 of 23 (permalink) Old 05-14-2019, 06:11 AM
ianrandom's Avatar
Oh I just painted the whole arm and cap though.
'86 420SE
'90 420SEC
post #4 of 23 (permalink) Old 05-14-2019, 06:12 AM
MBL87560SEC's Avatar
Date registered: Jul 2004
Vehicle: 1991 500SEC sub 50K mi. 1987 560SEC Now 150K mi. 2018
Quoted: 398 Post(s)
Hi there,
My '91 Euro SEC has what you describe, whereas the USA vesion has totally different headlamps & wipers.. The US ones don't fade as they are metal entirely.
I have found new ones online from Europe, so here are some images for reference.
The Euro plastic caps are much darker than the arms themselves...
I bought some metallic spray that matches perfectly..
MBL
ID:	2512512   Click image for larger version
91 500SEC EURO Germany
87 560SEC USA 49 State Version
MBL87560SEC is offline
post #5 of 23 (permalink) Old 05-14-2019, 09:58 AM
AxelWulff's Avatar
Date registered: Oct 2004
Vehicle: 1990 SEC
Quoted: 44 Post(s)
I've painted my Gen 1 Euro headlamp wipers to match the body color and it's all in the prep work.
You've also have to use different paints between the plastic and metal parts.
A bit fiddly, but the result is well worth it.
MBL87560SEC and Chicky like this.
Regards,
Axel
1990 SEC, Arctic White w/gray interior, M119.960 326 Hp. engine from 1992 500 SL, 722.370 transmission from 500E (reinforced clutches), 2:82 Differential, Euro Headlamps, 1st Gear Start module, One-Touch Window module and Keyless Entry module all from BergWerks, Bilstein HD Shocks on front axle, H&R lowering springs front and rear, AMG 3-piece 17" rims, 8.5" in the front and 10" at the rear.
AxelWulff is online now
post #6 of 23 (permalink) Old 05-14-2019, 10:46 AM
Quoted: 398 Post(s)
So true Axel,
Use the wrong stuff and the plastic crazes...M
post #7 of 23 (permalink) Old 05-14-2019, 09:16 PM
Date registered: Apr 2004
Vehicle: '91 560SEC, '98 SL500
Quoted: 155 Post(s)
The last paint work on my SEC was the headlight wipers, I think they turned out well.
AxelWulff likes this.
slownrusty is offline
post #8 of 23 (permalink) Old 05-14-2019, 11:03 PM
magicbigdaddy's Avatar
Date registered: Dec 2006
Vehicle: 1989 560 SEC - V-8 Kompressor - 95 E320 Estate
Quoted: 324 Post(s)
Did this last week. My experience is best when a light coat of primer is applied after sanding and prior to painting. Mike
1989 560 SEC Supercharged - 317+ rwhp - H&R lowered - OZ 3 piece staggered wheels - upgraded brakes - AMG Tri-Y's - Bergwerks FGS - a true Euro Rod
1981 500SE euro AMG
1985 euro 500SEC
1986 560 SEC
1985 500SEL
1989 560SEC
1990 560SEL
1987 euro 560SEL 300hp 822 engine option
magicbigdaddy is offline
post #9 of 23 (permalink) Old 05-15-2019, 01:30 AM Thread Starter
Quoted: 6 Post(s)
Thanks to all for the encouraging words. I'll give it a go and post pics of the result!
tempur is offline
post #10 of 23 (permalink) Old 05-15-2019, 01:45 PM
Date registered: May 2018
Vehicle: 1988 Mercedes 500 sec
Quoted: 36 Post(s)
MBL87560SEC how much were the wipers do you have an ebay link
Benz 1 is offline
WTB W202 headlight housings designed for headlight wipers C22O For Sale/Wanted/Trade/Giveaway 2 10-11-2009 06:45 AM
US headlight wipers - removal - and use with EURO Headlights StarGazer W124 E,CE,D,TD Class 30 08-24-2008 02:27 PM
headlight wipers (need help) tandm1999 W123 E,CE,D,CD,TD,TE Class 6 01-02-2008 10:37 AM
Euro headlight wipers? AzimuthAviation W126 S,SE,SEC,SEL,SD,SDL Class 7 06-03-2007 12:33 PM
Converting Headlight Wipers to euro after a Euro headlight conversion. wongi2 W126 S,SE,SEC,SEL,SD,SDL Class 0 09-22-2003 02:05 AM
