Help Identify part please - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 05-13-2019, 12:19 PM Thread Starter
Date registered: Sep 2017
Vehicle: 1989 560SEC Euro 300HP 52K miles
Quoted: 25 Post(s)
This is a pic from under my 89 560sec, we are looking for identity of the plastic part in center with black cap on top which has a wire running into it. It is under the oil pan and is NOT the oil pressure sending unit that makes your needle dance when faulty
Part number would be awesome also if possible
Name:	Mercedes oil switch.jpg
bobolinski1 is offline
post #2 of 7 (permalink) Old 05-13-2019, 12:37 PM
Date registered: Jul 2018
Vehicle: 1990 300SE
Quoted: 33 Post(s)
it looks like LOW OIL LEVEL WARNING LIGHT sensor part: 1265420817
christuna is offline
post #3 of 7 (permalink) Old 05-13-2019, 01:40 PM Thread Starter
Quoted: 25 Post(s)
Thank you, do you know if a oil drain and pan drop is required for installation or just plug and play?
post #4 of 7 (permalink) Old 05-13-2019, 02:16 PM
Stutz's Avatar
Date registered: Oct 2009
Vehicle: 1999 500SL, 1988 SEC
Quoted: 238 Post(s)
Unfortunately the lower oil pan has to come off
Stutz is offline
post #5 of 7 (permalink) Old 05-13-2019, 02:27 PM
Vehicle: 1990 300SE
Quoted: 33 Post(s)
oil pan has 2 parts: upper and lower one you only need to remove the lower one its an easy job and it has a gasket: 1190140822
post #6 of 7 (permalink) Old 05-13-2019, 04:33 PM
Stutz's Avatar
Quoted: 238 Post(s)
Well if you remove the oil pan you should replace the rubber foot on the oil pump. They get brittle and pieces fall off. They don’t cost much either. Lower oil pan gaskets are rather expensive for what they are. I think MB is around $20.00. I am replacing my sensor so that is how I know. Sensor is about $60.00
Stutz is offline
post #7 of 7 (permalink) Old 05-13-2019, 07:44 PM Thread Starter
Quoted: 25 Post(s)
Originally Posted by Stutz View Post
Well if you remove the oil pan you should replace the rubber foot on the oil pump. They get brittle and pieces fall off. They donít cost much either. Lower oil pan gaskets are rather expensive for what they are. I think MB is around $20.00. I am replacing my sensor so that is how I know. Sensor is about $60.00
Thank you, do you know the part number for the rubber foot by chance
Need help to identify part sirstanley W203 C32 AMG, C55 AMG 6 01-11-2016 06:57 AM
Trying to identify a part and a leak semperfiguy98 W202 C-Class 2 11-15-2015 09:00 PM
central locking hose--dealer can't identify part number Pete1978 R129 SL-Class 5 10-12-2015 01:29 PM
I cant identify this part.. Ideas? cobbcj7 R/C107 SL/SLC Class 4 07-25-2015 05:14 PM
Can You Help Identify This Part from Under Dash? ArcticDweller R129 SL-Class 12 12-17-2012 01:28 PM
