Clean are restore windshield washer bottle tank - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 05-13-2019, 08:18 AM Thread Starter
Date registered: Apr 2018
Vehicle: 1988 300SEL W126
Quoted: 108 Post(s)
Clean and restore windshield washer bottle tank
I was looking for one for a while, my old heating element was leaking inside the washer tank, the heating element itself is no longer available from MB, i found one on ebay so i decided to give it a shot, i decided to share my pictures with you if you want to clean and restore and get rid of that green junk calcium inside the tank and the heating element. If you are married don't do it on the sink like i did , almost wife kick me outside the house . All you need is white vinegar, water, a container, tooth brush for cleaning, sand paper (400 and 2000 grid) to sand the scratches on the tank and powder citric acid from you local grocery store. i know some will say you are in Texas you don't that heating element, my answer is: my OCD will not allow me to see something unplugged or not working in my car . below are some pictures in case you want to clean yours.
Parts needed:
1- If your Rubber Grommet is worn out where the heating element is attached to the Washer Reservoir Cap. this part for you
Manufacturer Part Number: 010-997-13-81, MBZ part #: Mercedes Benz A 1249975081
2- If your washer pump seals grommet are leaking, this part for you
Manufacturer Part Number: 123 997 36 81
3- If your valve is stuck, not working, leaking from the seals where the coil is attached to the valve, buy new valve that comes with washer from Parts.com for $15.60 and for $14 from the dealership.
Part number:1268300784
Cleaning:
1- Mix like 4-5 cups of hot water, 1 cup white vinegar and 2 table spoons of powder citric acid.
2- Soak it for a couple of hours or more (it depends on how bad and dirty is your tank)
3- brush it with soapy water and sand the scratches or heavy spots with 400 grid sand paper followed by 2000 to make it smooth again.
Note: there might be another way, but this is my way.
ID:	2512238   Click image for larger version
ID:	2512240   Click image for larger version
ID:	2512242   Click image for larger version
ID:	2512244   Click image for larger version
ID:	2512248   Click image for larger version
AxelWulff, mramay and Chicky like this.
Faiz Jan is offline
post #2 of 5 (permalink) Old 05-13-2019, 12:22 PM
Date registered: Feb 2008
Vehicle: Too many to list
Quoted: 1516 Post(s)
Wow great write up !! Never seen someone restore these
tusabes is online now
post #3 of 5 (permalink) Old 05-13-2019, 12:28 PM
Chicky's Avatar
Date registered: Apr 2007
Vehicle: 1991 R129 500SL
Quoted: 91 Post(s)
Talking
... no wonder your wife was "mad" at you... using the pyrex glass serving dish
Seriously, OCD's unite
Chicky is offline
post #4 of 5 (permalink) Old 05-13-2019, 12:31 PM Thread Starter
Quoted: 108 Post(s)
Faiz Jan is offline
post #5 of 5 (permalink) Old 05-13-2019, 02:34 PM
ianrandom's Avatar
Date registered: Jul 2008
Vehicle: 1986/1990 W126
Quoted: 1159 Post(s)
Hehe. My other half is completely used to parts in the house, by now.
I did my washer tanks with Milton sterilising fluid soaking and scrubbing.
No heater element in mine though.
I would say that doing as you have and then using water to flush out the washer lines before filling with fresh mix, does wonders for the pressure/volume of the spray.
Mixing additives over time previously can result in bad reaction between chemicals, resulting in blobby gooey fluid.
Anyway looks great well done.
'86 420SE
'90 420SEC
Daily transport 9spd Giant DH Comp downhill bike
ianrandom is offline
Windshield washer bottle (tank) hyprr1 W163 M-Class 22 08-04-2015 03:16 AM
Hardy Boys and the Big Wiggly Thing (Windshield washer heater coil) stimpy451 W126 S,SE,SEC,SEL,SD,SDL Class 3 04-14-2015 08:37 PM
1994 E420 Windshield Washer Issue blkennedy W124 E,CE,D,TD Class 7 12-16-2009 02:37 PM
How do I remove the windshield washer nozzles? ScottT W203 C-Class 0 07-25-2005 06:44 AM
Windshield Washer Tank AAC W163 M-Class 8 09-30-2003 05:16 AM
