Broken plastic tip - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 05-12-2019, 02:39 PM Thread Starter
Petethemedic's Avatar
Date registered: Jun 2012
Vehicle: 1984 300 SD 1984 300CDT
Quoted: 14 Post(s)
Broken plastic tip
Hi y'all!
I broke the tip off of the radiator housing (see pic) any idea how to fix this folly?
1982 300D Turbo Sedan " Tanny Girl" (sold)
1982 300SD
1984 300CDT
Petethemedic is offline
post #2 of 7 (permalink) Old 05-12-2019, 03:18 PM
KRH
KRH's Avatar
Date registered: Nov 2009
Vehicle: 87 Euro500HVSEC. 88 Euro 560HVSEC. 89 Euro 560HVSEL
Quoted: 521 Post(s)
New radiator - that is plastic under heat and pressure
Maybe possible to tap a thread on the inside of the hole and screw in a tapped tube of brass but not much plastic to work with - i would not chance it and certainly would not try gluing it with bondo or similar product
AxelWulff likes this.
by
, on Flickr" border="0" />
87 White Euro 500 "ECE" 265hp SEC
88 Black Euro 560 "RUF"300hp SEC
89 Blue Euro 560 "RUF" 300hp Hydro SEL
KRH is offline
post #3 of 7 (permalink) Old 05-12-2019, 05:41 PM Thread Starter
Quoted: 14 Post(s)
Damnit! Thanks! I replaced radiator in late 2017. Oh well. I was leaning on the hose to remove air filter housing to paint it and broke it
1982 300SD
1984 300CDT
post #4 of 7 (permalink) Old 05-12-2019, 06:56 PM
luckymike's Avatar
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1989 560SEL, 1995 E420
Quoted: 535 Post(s)
How aggravating. I wonder if you could use a rivnut with an oring or firm rubber washer as a seal, then thread a sleeve into that?
luckymike is online now
post #5 of 7 (permalink) Old 05-12-2019, 07:14 PM
mramay's Avatar
Date registered: Feb 2005
Vehicle: Two '87 570SECs, one '87 560SEL
Quoted: 242 Post(s)
I fixed mine a year ago for $5.00. Drill that out to 3/8" (I think that's the size. With the upper radiator hose off and some paper inside to catch the plastic drill pieces), get a metal valve stem for a rim, which comes with a rubber gasket. Take out the schrader valve (save it for the R12 low side fill fitting).
Home Depot sells washers with rubber bonded to one side (another 50 cent part) and that went on the outside. PM me for detail or call me.
This is a simple fix that should take ten minutes, and you don't even have to pull the radiator.
Blasphemous Mike
US '87 560SEC with Euro headlights, clear markers, H&Rs, 17x8.5/Nitto's, ATE slotted rotors with ceramic pads, BergWerks FGS, 3.07 Limited Slip. '87 560SEL with Euro Headlights, lowered, 235/40/17's
mramay is offline
post #6 of 7 (permalink) Old 05-12-2019, 08:56 PM
luckymike's Avatar
Quoted: 535 Post(s)
It's a great idea, mramay, but I don't see the top radiator hose nearby in the pic for access.
post #7 of 7 (permalink) Old 05-12-2019, 09:55 PM
mramay's Avatar
Quoted: 242 Post(s)
Backwards radiator! Never saw one like that - all the W126's I've worked on have the upper hose right next to that plastic nipple. What is that one in?
I'd do it anyway. A coat hanger and some string will let me install the valve. A vacuum cleaner would let me drill the hole, the rest would be easy.
luckymike and John350 like this.
Blasphemous Mike
mramay is offline
Pencil glow plug tip broken off inside prechamber. gregp1962 W123 E,CE,D,CD,TD,TE Class 3 01-30-2019 10:34 AM
C230 Kompressor P0410 and broken plastic lines on front of engine. [email protected] W202 C-Class 4 11-12-2017 08:18 PM
Hatch Door Actuator: Plastic Stuff, Warning don't do this!!, Easy to Change.. Thanks raybenz.. AC_ML W163 M-Class 27 06-02-2015 10:30 AM
1994 E320 with radiator woes, broken plastic, repairable? 2005x W124 E,CE,D,TD Class 5 03-02-2012 07:43 PM
Findings: What Happens to Broken Plastic Chain Guides? strife2 W126 S,SE,SEC,SEL,SD,SDL Class 6 06-09-2011 06:01 PM
