Automatic climate control function - Mercedes-Benz Forum
post #1 of 23 (permalink) Old 04-20-2019, 10:33 AM Thread Starter
Date registered: Jul 2018
Vehicle: 1990 300SE
Quoted: 37 Post(s)
Hi i'm wondering how the acc in my car works imagine this scenario:
outside temp 80 I set my temp at 70 middle button pressed low fan speed
what will the system do:
A. cool the evaporator just enough to keep the interior at 70 without using the heater and to save the compressor and increase gas mileage
or
B. cool the evaporator down to freezing and also use the heater to bring temp up
christuna is offline
post #2 of 23 (permalink) Old 04-20-2019, 01:27 PM
luckymike's Avatar
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1989 560SEL, 1995 E420
Quoted: 576 Post(s)
I don't know the answer to this but I suspect it can be found in section 83-600 of the manual. It goes into quite a bit of detail.
christuna likes this.
luckymike is offline
post #3 of 23 (permalink) Old 04-21-2019, 08:53 AM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 68 250S, 91 300se, 98 SL500, 450SEL 6.9, 14 CLS550 Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 833 Post(s)
just set fan on auto and leave it alone. adjust temp dial in very small increments to compensate for various temp changes.
I think A is what happens.
I tell my wife all the time that setting the thermostat on the lowest setting doesnt make the car cool off faster. (After giving up on that conversation I finally got her to change because her CLS550 eco start/stop wont work if the interior temp is different that the thermostat setting.) The compressor is either on or off depending on demand.
MBL87560SEC and ianrandom like this.
rumb is offline
post #4 of 23 (permalink) Old 04-21-2019, 10:46 AM Thread Starter
Vehicle: 1990 300SE
Quoted: 37 Post(s)
I think the answer is B
the 83-600 section of the manual for the middle button (button c) says this:
"The compressor is added, the evaporator temperature is held to approx. 0 C"
and this:
"The refrigerant compressor of the air conditioning system is switched on at outside temperatures above +4 C"
also if you read section 83-601 (function test) with button c compressor runs on every temp setting.
Test 6 shows button c and temp wheel at 22 C and both compressor and monovalve are switched on so I think the answer to my original question is B.
So the system in my 300SE is less efficient than in my old 240D which had manual climate control and had a separate rotary wheel for the air conditioner strenth setting while the heater had its own two rotary switches (left and right side) and it was just a simple linkage from the dash to the heater valve.
post #5 of 23 (permalink) Old 06-15-2019, 11:44 AM
Vehicle: 1990 190e 2.6l Calif. auto 1987 Ford F150 4.9L Calif. man 4OD 4X4 2013 Suzuki C50 Crusier
Quoted: 14 Post(s)
A and B is wrong. 1. With the a/c on, heater control valve shuts off the hot water flow going into the cab. 2. The a/c system has a temp sensor that turns off the compressor when temp gets below your deg setting and turn on when gets above the deg setting. 3. The a/c system cycles the compressor off and on to your settings. 4. If the heater has hot water going thur the water control valve and at the heater/evap core then the temp would never get cold.
zpa001 is offline
post #6 of 23 (permalink) Old 06-18-2019, 10:00 PM
Quoted: 14 Post(s)
In other words, the heater is not used. In short the compressor is controlled to cycle on and off.
zpa001 is offline
post #7 of 23 (permalink) Old 06-20-2019, 07:35 AM
mclare's Avatar
Date registered: Aug 2008
Vehicle: 2012 CL550 4MATIC Coupe
Quoted: 311 Post(s)
Send a message via Yahoo to mclare Send a message via Skype™ to mclare
Hey rumb!
My CL550 doesn't do that I don't think?
Current Stable:
2012 CL550 C4 4MATIC Coupe
Past cars:
1991-560 SEC AMG - Coupe - 199/261 - 300 HP Custom Built Motor - Highly Modified Coupe.
1990-560 SEL - Sedan - 199/261 - Stock. Euro Headlamps & Wipers
1987 560 SEC Black/Tan
1988 420 SEL Champagne/Brown
mclare is offline
post #8 of 23 (permalink) Old 06-20-2019, 07:36 AM
mclare's Avatar
Quoted: 311 Post(s)
+1 - The heater is NOT used. The compressor IS cycled.
Current Stable:
Past cars:
mclare is offline
post #9 of 23 (permalink) Old 06-20-2019, 07:37 AM
mclare's Avatar
Quoted: 311 Post(s)
This is correct.
Current Stable:
Past cars:
mclare is offline
post #10 of 23 (permalink) Old 06-20-2019, 08:24 AM Thread Starter
Vehicle: 1990 300SE
Quoted: 37 Post(s)
if you read section 83-601 (function test) with button c (middle one).
Test 6 shows button c and temp wheel at 22 C and both compressor and monovalve are switched on.
Mercedes-Benz Diagnostic Trouble Codes (DTC) for 1996+ models GeeS General Mercedes-Benz 45 03-23-2019 06:04 AM
2004 E320 - Red Battery "Visit Workshop" - Is it the Relay or Main battery ccrobin W211 E-Class 10 11-20-2015 03:25 AM
How to preserve a functioning automatic climate control system? neuromancer W123 E,CE,D,CD,TD,TE Class 8 08-26-2015 08:21 PM
Useful links 4 new members - repost Bazzle R170 SLK-Class 79 02-06-2011 09:45 PM
Bad preformance Arotished R170 SLK-Class 13 06-04-2008 09:12 AM
