5.6 liter frustration 560SL - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-17-2019, 01:22 PM Thread Starter
Quanta2's Avatar
Date registered: Jul 2018
Vehicle: 1986 560SL
Quoted: 6 Post(s)
Can someone offer a little guidance? I have a gremlin haunting me! Bought this car about a year ago, it had been sitting for 15 years in a heated garage. Went through everything I could think of, now I have a strange quirk.
The car starts perfect and idles around 750 rpm, really runs good on road until the temperature gets to normal then will start oscillating at the low throttle position. With maybe 1/8 throttle it will fade for a second or two and then come right back to smooth running. Say cruising on flat road at 40 or 50 mph, fades every few seconds for about a second. If I push just slightly on the throttle, perfect again. The duty cycle is 51% but when the fade takes effect, it goes to 75% for a second or two, then right back to 51%. This is measuring at pin #3 on X11 while driving. What should I be looking at next? What would make the voltage drop at pin #3? Have had the fuel distribution center rebuilt by Flowtech, pressures are good on top and bottom, all new rubber parts, fuel pumps and filter, fuel pressure regulator, idle control module, fuel pump module, over voltage protector, new holders and seals on injectors, air flow sensor, coolant temp sensor, throttle position sensor, O2 sensor, coil. O2 sensor puts out .47 volts. Vacuum test is solid. EHA readings are on spec at an idle. I have not drivin while monitoring the EHA. Anyone know what in the world would cause the readings at Pin #3 to drop like that?
Thanks for reading.
Quanta2 is offline
post #2 of 3 (permalink) Old 04-17-2019, 02:07 PM
luckymike's Avatar
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1989 560SEL, 1995 E420
Quoted: 530 Post(s)
Here's a random thought. Check the small wire connected to your positive terminal cable. Make sure the connection is clean and tight. On the W126 this feeds the fuel pump relay.
I'd also consider breaking and making all the connections of the relay, ovp, ecu, etc. and cleaning all the grounds in the engine bay.
luckymike is offline
post #3 of 3 (permalink) Old 04-17-2019, 05:50 PM Thread Starter
Quanta2's Avatar
Vehicle: 1986 560SL
Quoted: 6 Post(s)
Will do, thank you for the reply!
luckymike likes this.
Quanta2 is offline
560SL New timing chain and parts for sale Velocity Vector R/C107 SL/SLC Class 20 10-19-2013 01:07 PM
560SL Timing Chain and Parts All New Velocity Vector For Sale/Wanted/Trade/Giveaway 0 10-12-2013 02:25 AM
I'm selling my 93 300CE w/75k original ebay item #110117970002 Labik34 W124 E,CE,D,TD Class 16 04-28-2007 10:40 PM
e-class coupe cus W124 E,CE,D,TD Class 1 08-22-2004 11:11 AM
E270CDI agill W211 E-Class 5 03-17-2003 12:39 PM
