widebody lower skirt variations - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 04-10-2019, 02:07 PM Thread Starter
Date registered: May 2018
Vehicle: 1988 Mercedes 500 sec
Quoted: 35 Post(s)
been looking at sec widebody pics why are some of the side skirts flush with the rear lower quarter plastic moulding whilst on others the moulding sits recessed an inch or two from the skirt
is it the way it has been fitted or the kit itself.
Benz 1 is offline
post #2 of 5 (permalink) Old 04-10-2019, 03:28 PM
macdeity's Avatar
Date registered: Aug 2009
Vehicle: 1984 500SEC AMG Euro "Das Model"
Quoted: 76 Post(s)
Gen I and Gen II styles vary, Gen II style is wider at both ends. Unfortunately the Gen I style is not being reproduced, unless you make your own copy from an original, I might even modify my Gen II into a Gen I.
Just when I thought I was out...they pull me back in
macdeity is offline
post #3 of 5 (permalink) Old 04-10-2019, 03:30 PM Thread Starter
Quoted: 35 Post(s)
gen 2
Benz 1 is offline
post #4 of 5 (permalink) Old 05-21-2019, 08:33 PM
Date registered: Feb 2010
Vehicle: 1968 250SE S-Class. 1988 560SEC S-Class Widebody
Quoted: 82 Post(s)
The skirts on a Widebody Gen 2 are widebody specific and get deeper at front and rear and also angle out away from the car. Lowe cladding needs some fab work to get them sitting right and in the correct place. Most widebodys vary in a lot of different areas - just comes down to fitment and how the it has been fitted up.
D&WCali is offline
post #5 of 5 (permalink) Old 05-22-2019, 12:28 AM Thread Starter
Quoted: 35 Post(s)
In which way is the origional cladding modified to fit on the gen 2 as i find if there is a large gap it looks ridiculous besides ot must look perfect on a merc
Benz 1 is offline
Rear power window/motor DIY keyhole C209/A209 CLK-Class 133 06-03-2019 01:47 AM
Mid Ball Joint Removal on Front Lower Control Arm warren032 W211 E-Class 6 01-06-2016 11:54 PM
Lower Control Arm/Stuck Airmatic Set Screw/Inner Tie Rod oceanliner W220 S-Class 23 01-01-2016 10:33 PM
FS: W210 Lower Control Arm Rebuild Tools (standard & 4-matic) marcmayer For Sale/Wanted/Trade/Giveaway 2 10-17-2010 11:30 AM
Paint lower cladding or lower car....that is the question jrmd01 W124 E,CE,D,TD Class 18 07-31-2010 08:57 AM
