17 inch Staggered OZ Aero Classic Design Wheel, Performa wheels review - Mercedes-Benz Forum
post #1 of 74 (permalink) Old 04-06-2019, 08:41 PM Thread Starter
Date registered: Apr 2018
Vehicle: 1988 300SEL W126
Quoted: 116 Post(s)
I decided to start a new thread for these wheels instead of the one i started before. Before i started the thread asking about Alzor monoblock wheels and then we talked about Performa wheels, the project took longer than expected between ordering wrong spacers and not long enough studs for like 4 times ,till i found the ideal length for the rear wheels ,without damaging the emergency brake hardware, if you are interested in those wheels, here is my review and setting. The paint and the quality of the wheels is more than i expected, the center bore is 66.6mm, no play at all, no rings are needed to attach it to the hub, no defects at all, the rivets are fake and just for the look, they are one peace wheels and you can't dis-assemble them. The communication with the seller is great, and the shipping from Malaysia was so fast, the seller reduced the price in the invoice that he sent to the customs, i paid only $40 to declare the wheels based on the price he included wich is $450.
here is a link to the wheels on eBay .Item number:332376885949, https://www.ebay.com/itm/New-17-inch...72.m2749.l2649
I bought the spacers from EZAccessory | Wheel Adapters, Suspension Parts, Lug Nuts & More, 15mm for the rear with lip, and 10mm flat spacers to the front, No spacers required if you want to use raised center caps for the front wheels. I tried both settings, and the regular center caps looks better.
I bought chrome studs from EZAccessory | Wheel Adapters, Suspension Parts, Lug Nuts & More also, they are on sale for only $1.99, the quality is amazing. 12mmX1.50 studs 45mm for the rear (with 15mm spacers), and 12mmx1.50 studs 39mm for the front with 10mm spacers.
Front tires 225/45R17XL 94W, rear tires 255/40R17 94W.
for me the height of the car with the 17" wheels is good for me, i don't want to go with lower springs, i am satisfied with the height of the car, the wheels and the tires filled most of the fender well, its better than before. please let me know if you have any questions.
ID:	2502466   Click image for larger version
ID:	2502468   Click image for larger version
ID:	2502470   Click image for larger version
ID:	2502472   Click image for larger version
ID:	2502476   Click image for larger version
ID:	2502478   Click image for larger version
ID:	2502480   Click image for larger version
ID:	2502482   Click image for larger version
DownhillA4 likes this.
Faiz Jan is offline
post #2 of 74 (permalink) Old 04-06-2019, 08:43 PM Thread Starter
Quoted: 116 Post(s)
more pictures
ID:	2502486   Click image for larger version
ID:	2502488   Click image for larger version
ID:	2502490   Click image for larger version
ID:	2502492   Click image for larger version
ID:	2502496   Click image for larger version
slownrusty, AxelWulff and lesguy like this.
Faiz Jan is offline
post #3 of 74 (permalink) Old 04-06-2019, 08:49 PM Thread Starter
Quoted: 116 Post(s)
more pictures from different angels, so you will have an idea.
ID:	2502500   Click image for larger version
ID:	2502502   Click image for larger version
ID:	2502504   Click image for larger version
ID:	2502506   Click image for larger version
ID:	2502510   Click image for larger version
dolucasi, Jake007 and lesguy like this.
Faiz Jan is offline
post #4 of 74 (permalink) Old 04-06-2019, 09:45 PM
luckymike's Avatar
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1989 560SEL, 1995 E420
Quoted: 576 Post(s)
Looks great. Congratulations on finally being done.
luckymike is offline
post #5 of 74 (permalink) Old 04-07-2019, 08:56 AM
Jake007's Avatar
Date registered: Aug 2016
Vehicle: 1991 560SEC
Quoted: 65 Post(s)
I bought these same wheels 18 months ago for my SEC. When I click on your link, it goes to the eBay page showing that I have purchased this item. So, this is the same seller that I used but when I bought them the bore size was 73.1mm, requiring custom spacers which cost me $250.00. It's great that they are now making these wheels that are a direct fit for our cars. I'm very happy with my set. Yours look fantastic although I do think it does need to be lowered a bit.
Jake007 is offline
post #6 of 74 (permalink) Old 04-07-2019, 12:24 PM
Date registered: Feb 2008
Vehicle: Too many to list
Quoted: 1538 Post(s)
it is too bad these wheels require spacers to clear the front center cap and not rub the inner rear tire wheel well, as I feel the tires stick out too far from the body with the spacers .
And yes I totally understand you don’t want to lower your car and there are legitimate reasons not to- but without lowering the Stance is just way off , it makes the wheels and tires look Like they weren’t made to fit this car . Wheels and tires and stance is an art form that’s hard to get just right .
AxelWulff likes this.
tusabes is offline
post #7 of 74 (permalink) Old 04-07-2019, 08:51 PM
Fonzi's Avatar
Date registered: Jun 2010
Vehicle: 450slc5.0cab 280sl5sp 280se4.5 500seAMG +250seStkW108 350sl4spdX3 500secEuro
Quoted: 2348 Post(s)
I think the 73.1 bore may have helped. Hopefully the fronts of Faiz Jan are still centering on the hubs. Otherwise, they could start vibrating after hitting a pothole.
My signature:
If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #8 of 74 (permalink) Old 04-07-2019, 10:23 PM
KRH
KRH's Avatar
Date registered: Nov 2009
Vehicle: 87 Euro500HVSEC. 88 Euro 560HVSEC. 89 Euro 560HVSEL
Quoted: 539 Post(s)
On a lowered car you would definitely have clearance issue on those front tires with the wheel arch as with the spacers they protrude too far out.
There is an engineering science to getting W126 wheel track geometry right in relation spacing of both front and rear rims in relation to each other (centre-line of front and rear rims) which affects handling of the car and how it tracks both straight and into corners/braking etc. So spacing out front wheels is not that simple.
17 x 8" ET11 is the max and 17 x 8.5 ET18 is the max
MBL87560SEC and Faiz Jan like this.
by
, on Flickr" border="0" />
87 White Euro 500 "ECE" 265hp SEC
88 Black Euro 560 "RUF"300hp SEC
89 Blue Euro 560 "RUF" 300hp Hydro SEL
KRH is offline
post #9 of 74 (permalink) Old 04-07-2019, 11:02 PM
bsclifton's Avatar
Date registered: Jan 2008
Vehicle: 1991 560SEC / 2007 S550
Quoted: 127 Post(s)
The wheels definitely look nice - but it almost looks like they don't fit properly. It could be the pictures, but the wheels themselves seems to be popped out farther than they should be (see attached shot)
(sorry if this is a noob question) If the wheels are offset 25, how exactly does the spacer help? Would a 12mm spacer bring the gap down to 13?
Name:	Screen Shot 2019-04-07 at 11.01.29 PM.png
liviu165 likes this.
1991 560SEC; 145,187 miles
2013 GL550; 99,960 miles
Previous cars
2007 S550; 146,541 miles (sold)
2009 C300; 95,861 miles (sold)
2006 S430; 101,719 miles (sold)
2001 SL500; 114,032 miles (sold)
1986 560SEL; 150,276 miles (hit by drunk driver)
bsclifton is online now
post #10 of 74 (permalink) Old 04-07-2019, 11:22 PM
vdubpower's Avatar
Date registered: Nov 2003
Vehicle: 1985 500sel and 500sec 2012 E63 1989 Porsche 911
Quoted: 555 Post(s)
i do like these wheels and they seem nice from a far but this thread is reminding me of former member BADwayz and his wheels
you oldtimers know what im talking about
Faiz Jan likes this.
1985 500SEL Euro Nautic Blue - A Classic Beauty
1985 500SEC Euro Nautic Blue
1989 Porsche 911 Carrera Silver Anniversary Edition
2012 E63 AMG Iridium Silver - Performance Package
vdubpower is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
For Sale and Wanted myunimog Unimog 850 07-21-2019 02:18 PM
Option codes jtetherson General Mercedes-Benz 3 01-22-2013 01:08 PM
AMG Aero II Monoblock 20" Inch Staggered Set of 4 W140 kmirchia For Sale/Wanted/Trade/Giveaway 2 06-23-2012 02:15 AM
Why adapters for Sprinter wheels on 460 Gkase G-Class 4 01-07-2005 12:03 AM
I need suggestions on wheel covers for my 16 inch winter steel wheels dbottoms R170 SLK-Class 3 01-08-2004 07:39 PM
