SLS comment - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 03-26-2019, 03:26 PM Thread Starter
Tom Kaiser's Avatar
Date registered: Jul 2010
Vehicle: 1989 SEL 560
Quoted: 134 Post(s)
SLS comment
I installed new SLS struts today. One of my first steps was to bleed the pressure off of the SLS system at the valve by the rear axle. I connected a clear plastic hose to the nipple down to a clean container. I noticed an excessive amount of foam came out of the bleed valve. I finished the installation and had a leak at one of the new copper crush washers at one of the struts. I again bled the pressure off of the SLS system and this time I did NOT have foam. Does anyone know if this foam has any significance?
The second new copper crush wash worked as intended and the leak was resolved. The vehicle rode much smoother with the new struts. I am trying to determine if the foam was a contributing factor to the less then smooth ride before the project.
Thanks in advance for any/all replies.
Tom Kaiser is offline
post #2 of 7 (permalink) Old 03-26-2019, 03:36 PM
MBL87560SEC's Avatar
Date registered: Jul 2004
Vehicle: 1991 500SEC sub 50K mi. 1987 560SEC Now 150K mi. 2018
Quoted: 396 Post(s)
Hey Tom,
Messy job, Good for you.
Bubbles = Air in system.
"less than smooth"... I think you're correct.
Cheers, man
M.
91 500SEC EURO Germany
87 560SEC USA 49 State Version
MBL87560SEC is offline
post #3 of 7 (permalink) Old 03-26-2019, 05:42 PM
Date registered: Nov 2018
Vehicle: 1991 560SEL
Quoted: 102 Post(s)
Also, as you noticed, crush washers must be new and have to be 2000% sure the line isn’t the least but cross threaded on the sls ram when installing. Otherwise you will get a oily leak
lesguy is offline
post #4 of 7 (permalink) Old 03-27-2019, 07:06 AM Thread Starter
Tom Kaiser's Avatar
Quoted: 134 Post(s)
Does anyone have experience/comments with the following statement: "I like to remove the linkage from the valve so I can most completely bleed the system. This way with the engine running I can lower the lever arm and fully lower the rear, then raise until the rear rises to it's maximum height. Just a few cycles should fully bleed and everything and restore that amazing ride quality from such a simple system "
post #5 of 7 (permalink) Old 03-27-2019, 07:52 AM
Date registered: Dec 2018
Vehicle: 2014 c207, 1991 c124, 1980 450sl
Quoted: 12 Post(s)
In my experience, foam came from ruptured accumulators.
CactiGuy is offline
post #6 of 7 (permalink) Old 03-27-2019, 09:15 AM
luckymike's Avatar
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1989 560SEL, 1995 E420
Quoted: 550 Post(s)
I've done this, Tom. I didn't notice any problems the first time I did it. But the second time, I raised the lever to fill the system then raised the car on the lift I was using. After a few minutes, I saw a drip from the front of the car. The pressure SLS hose was leaking!
This was the day before a long trip. I lowered the car and moved the lever back down and buttoned everything up. I cleaned the hose where it had been leaking between the hose and fitting and went for a test drive. Thankfully no more leak and nothing since then.
So the take away for me was to go ahead and raise and lower the car manually with the lever but don't leave it in the up position for long because the system must create tremendous pressure.
luckymike is online now
post #7 of 7 (permalink) Old 03-27-2019, 02:10 PM
281lxm's Avatar
Date registered: Dec 2011
Vehicle: 1991 560 SEC 1994 E500 2014 E350 Cab
Quoted: 435 Post(s)
I agree, too much pressure too long will snap that hose (I had to replace mine) and anything holding pressure for excessively long or at higher PSI.
_____________________________________________
1991 560SEC 199 /268, 17" RS90'S, Eibach springs, Bilstein HD shocks, Custom rear sway bar, Euro Headlights, Custom ceramic coated headers and down pipes with stainless dual exhaust, W140 glass sunroof, dog ear trunk spoiler, OEM Skid Plate, Euro bumpers, wood refinish and restored.
281lxm is offline
W140 SLS Suspension; mods are not a good idea daidnik W140 S-Class 9 10-12-2017 12:56 PM
Optimum time to buy SLS?: Bottom Depreciation curve; 4yr warranty tail;2016-2018 Kayvan Mercedes-Benz SLS AMG 0 11-04-2015 09:12 AM
SLS Rebuild general questions thread... ps2cho W124 E,CE,D,TD Class 86 10-18-2015 12:00 AM
Report: Mercedes to Build Electric Version of Upcoming SLS Supercar administrator Mercedes-Benz News 2 07-13-2009 08:45 AM
H & R springs on an SLS 16V question NWA-CRJ W210 E-Class 0 10-26-2005 06:36 PM
