Strange New Engine Vibration After Changing Engine Mounts - Mercedes-Benz Forum
post #1 of 37 (permalink) Old 03-24-2019, 04:29 PM Thread Starter
Date registered: Aug 2017
Vehicle: 1991 560SEL
Quoted: 23 Post(s)
I changed my mounts and dampers yesterday. I even did my transmission mount, which is great because the one I removed came out in two pieces
I have noticed a much smoother idle, but I also have a strange and subtle vibration that only started after I did this job.
I can feel it through the accelerator pedal and through the seat, though it is slight. It only seems to appear under the following conditions:
-The car is in gear and accelerating from a dead stop (like leaving a ref light)
-The car is at operating temp (this doesnít seem to manifest when itís cold)
-Engine speeds are between 800-1100 RPM in park and then only at operating temp.
I speculated that since the old mounts were super collapsed, and that since the new mounts have my engine sitting maybe 3/4Ē higher for the first time in who knows how long, the throttle linkage adjustments might have been altered by the engineís vertical displacement.
Alternatively, I speculate that my raising the engine slightly to install the mounts and dampers (it came up maybe an incho and a half as a result of my lifting it with a transmission jack) could have upset something, but I have done several visual inspections with very bright lights and I see nothing out of place.
Wrench Jedi is offline
post #2 of 37 (permalink) Old 03-24-2019, 04:43 PM
281lxm's Avatar
Date registered: Dec 2011
Vehicle: 1991 560 SEC 1994 E500 2014 E350 Cab
Quoted: 435 Post(s)
I didnít read this all but the transmission mount aka rear engine mount should also be changed. So with the geometry of the mounts, after reading it perhaps your drive shaft center bearing is worn from the previous condition. Your reply came in as I am typing adding edits, sorry in the car at a light
_____________________________________________
1991 560SEC 199 /268, 17" RS90'S, Eibach springs, Bilstein HD shocks, Custom rear sway bar, Euro Headlights, Custom ceramic coated headers and down pipes with stainless dual exhaust, W140 glass sunroof, dog ear trunk spoiler, OEM Skid Plate, Euro bumpers, wood refinish and restored.
281lxm is offline
post #3 of 37 (permalink) Old 03-24-2019, 04:45 PM Thread Starter
Quoted: 23 Post(s)
It was also changed yesterday.
post #4 of 37 (permalink) Old 03-24-2019, 09:13 PM
luckymike's Avatar
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1989 560SEL, 1995 E420
Quoted: 553 Post(s)
I vote for the rubber bearing/bushing mount at the center of the driveshaft. I have a similar vibration when accelerating from a stop. OR up a steep hill at low speed. Does yours do that on a hill?
I got under the car and discovered that the driveshaft could be wiggled quite a bit in the center so I suspect the center mount.
luckymike is offline
post #5 of 37 (permalink) Old 03-24-2019, 09:43 PM Thread Starter
Quoted: 23 Post(s)
No worries, I appreciate the input!
The driveshaft seems solid on my car, and Iíve had the rear diff down before to replace the rear flex disc and all that. It didnít give me any reason to believe that the center bearing was worn.
Additionally, I get the aforementioned strange idle anomaly in park too, after the engine is warm and has been driven for a bit. So I hesitate to think itís driveshaft-related.
luckymike likes this.
post #6 of 37 (permalink) Old 03-24-2019, 10:12 PM
luckymike's Avatar
Quoted: 553 Post(s)
Just to clarify, I don't mean the bearing. I mean the rubber support around the bearing.
post #7 of 37 (permalink) Old 03-24-2019, 10:47 PM
liviu165's Avatar
Date registered: Aug 2013
Vehicle: 1989 MB 420SEL, 1991 560SEC
Quoted: 624 Post(s)
What exactly was the brand of parts you put on the car now? Meyle, Lemforder, URO, etc? The rubber quality plays a role too, many times overlooked.
liviu165 is offline
post #8 of 37 (permalink) Old 03-25-2019, 07:04 AM
281lxm's Avatar
Quoted: 435 Post(s)
Just like I said in the pm to you
When I finished the thought while typing i n the car at a stop light.
281lxm is offline
post #9 of 37 (permalink) Old 03-25-2019, 07:25 AM Thread Starter
Quoted: 23 Post(s)
Is that something that would cause my vibration when the vehicle is in park and idling?
I just drove the car to the gym, and it was normal and smooth up until it reached operating temp, then between engine speeds of 1000-1500 RPM, my vibration manifested. Usually when coming into throttle after exiting a corner or something like that. I am now sitting in the vehicle in a parking lot, in park, and I have the vibration again.
Iím guessing this doesnít happen often as a result of new engine mounts
post #10 of 37 (permalink) Old 03-25-2019, 08:54 AM
luckymike's Avatar
Quoted: 553 Post(s)
Oops! I skipped right over the 'in park' part. No, clearly that takes the driveshaft out of the equation.
Well, you may have disturbed or changed something during the engine mount change. I'd probably spend some time carefully looking over the engine bay for anything out of place. If that didn't yield any answers, I guess I'd start with the troubleshooting tree in the manual, section 07.3-121.
I hate it when putting in new parts seems to create a problem.
Wrench Jedi likes this.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
nuri
Lemforder engine mounts WTF Peter 68 R129 SL-Class 4 09-24-2018 08:43 AM
Transmission Service DIY atmsmshr W220 S-Class 41 05-07-2016 06:21 AM
Strange Harmonic Vibration SOLVED!!! 04S600AMG W220 S-Class 3 07-16-2014 09:39 AM
2005 S430 code P2734 and P0748 car in Limp Mode Help!!! iBan W220 S-Class 25 06-20-2012 05:37 AM
Cam Oilers and Sludge Removal 97e420sweet W210 E-Class 14 01-14-2009 08:58 AM
