I need help with Performa 25 W126 wheels - Mercedes-Benz Forum
post #1 of 45 (permalink) Old 03-23-2019, 07:29 PM Thread Starter
Date registered: Apr 2018
Vehicle: 1988 300SEL W126
Quoted: 107 Post(s)
so today wasn't a good day for me, i was so exited to install the new wheels i got yesterday, i followed the instructions (wheels off set and tire size) from other members who installed the 17" performa 25 wheels before. I installed the rear tires and did a test , the car didn't move at all, it seems spacers needed, can you please see if the studs are long or not (from the black dust brake mark on the studs), and what is the recomended spacers that i need to buy, it seems the wheels are rubbing in the fender well. or the studs are long.
Tire size:
Front : 225/45/17
Rear : 255/40/17
Wheels:
Front : Rim 17x8J front offset 25
Rear : Rim 17x9.5J rear offset 25
ID:	2498812   Click image for larger version
ID:	2498814   Click image for larger version
ID:	2498816   Click image for larger version
ID:	2498818   Click image for larger version
ID:	2498822   Click image for larger version
ID:	2498824   Click image for larger version
Faiz Jan is offline
post #2 of 45 (permalink) Old 03-23-2019, 07:37 PM
Date registered: Feb 2008
Vehicle: Too many to list
Quoted: 1509 Post(s)
Usually if the car won’t move at all your studs are too long . Don’t need spacers just shorter studs
But are the wheels rubbing the inner fender liner ? Your pic is Too hard to tell what it is showing . Mount them up with the long studs and feel for clearances . If there’s inner rubbing you’ll need spacers
tusabes is offline
post #3 of 45 (permalink) Old 03-23-2019, 07:46 PM
liviu165's Avatar
Date registered: Aug 2013
Vehicle: 1989 MB 420SEL, 1991 560SEC
Quoted: 623 Post(s)
From your pictures I am getting the impression that the threaded portion of your lug bolts sticks out too much. KRH advised in an earlier post somewhere how much is allowed on the back before you'd hit the parking brake hardware when installing the wheels. IIRC about 5-6 threads max sticking out. I hope KRH will advise here.
For the front wheels the lug bolts should be fine, is only on the back that the length is so critical.
liviu165 is offline
post #4 of 45 (permalink) Old 03-23-2019, 07:48 PM Thread Starter
Quoted: 107 Post(s)
Yes, picture number 4 showing scratches on the fender well.
Originally Posted by tusabes View Post
Usually if the car wonít move at all your studs are too long . Donít need spacers just shorter studs
But are the wheels rubbing the inner fender liner ? Your pic is Too hard to tell what it is showing . Mount them up with the long studs and feel for clearances . If thereís inner rubbing youíll need spacers
Faiz Jan is offline
post #5 of 45 (permalink) Old 03-23-2019, 08:14 PM
AxelWulff's Avatar
Date registered: Oct 2004
Vehicle: 1990 SEC
Quoted: 43 Post(s)
Yes, you need spacers.
You could try a few whacks with a big hammer. The point that interferes with the wheels seems to be protruding a bit from the rest of the inner fender.
Tolerances are tight on our cars. AMG put the absolute max width wheel with the 17x10, ET 17 at the rear. However, depending on your springs and variations in geometry, you could still get rubbing.
I've had a go with a hammer in my rear wheel wells to eliminate occasional rubbing.
Regards,
Axel
1990 SEC, Arctic White w/gray interior, M119.960 326 Hp. engine from 1992 500 SL, 722.370 transmission from 500E (reinforced clutches), 2:82 Differential, Euro Headlamps, 1st Gear Start module, One-Touch Window module and Keyless Entry module all from BergWerks, Bilstein HD Shocks on front axle, H&R lowering springs front and rear, AMG 3-piece 17" rims, 8.5" in the front and 10" at the rear.
AxelWulff is online now
post #6 of 45 (permalink) Old 03-23-2019, 08:31 PM Thread Starter
Quoted: 107 Post(s)
5 mm spacers ?
Faiz Jan is offline
post #7 of 45 (permalink) Old 03-23-2019, 08:50 PM Thread Starter
Quoted: 107 Post(s)
The back spacing area is so tight, the back of the wheels are rubbing the fender well (not from the fender side) ,i think spacers will push the rims forward the fender a little bit for clearance, so i don't know how thick the spacers should be.
Faiz Jan is offline
post #8 of 45 (permalink) Old 03-23-2019, 08:55 PM
AxelWulff's Avatar
Vehicle: 1990 SEC
Quoted: 43 Post(s)
The back spacing area is so tight, the back of the wheels are rubbing the fender well (bot from the fender side) i thing spacers will push them forward the fender a little bit for clearance, so i don't know how thick the spacers should be.
From the looks of it, 5 mm spacers should suffice. Brings the offset down to 20.
Regards,
Axel
post #9 of 45 (permalink) Old 03-23-2019, 09:29 PM
vdubpower's Avatar
Date registered: Nov 2003
Vehicle: 1985 500sel and 500sec 2012 E63 1989 Porsche 911
Quoted: 545 Post(s)
Wasn't there a member who just installed these recently... Black car
I'm sure he will be of great help
vdubpower is offline
post #10 of 45 (permalink) Old 03-23-2019, 09:31 PM
Date registered: Nov 2018
Vehicle: 1991 560SEL
Quoted: 102 Post(s)
I may have quality 5mm spacers in proper bolt pattern the garage. PM me if needed
lesguy is online now
OEM Wheels that can fit w163 ML stvhck W163 M-Class 23 07-16-2017 01:48 AM
W126 SEC SEL AMG Wheels, Body, Diff, Doors, Euro Bumper, Sunroof, Chrome Garage Sale! 48hp For Sale/Wanted/Trade/Giveaway 12 12-14-2013 03:14 PM
HELP! (in)correct wheels size for W126 HELP! BenzDslPwr W126 S,SE,SEC,SEL,SD,SDL Class 13 09-21-2010 01:00 PM
Information about Replica Wheels Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 7 08-09-2010 01:05 PM
Why does TireRack sell ET35 for 17" W126 wheels? 1985MB380SE W126 S,SE,SEC,SEL,SD,SDL Class 13 07-25-2007 10:49 AM
