560sec cruise control - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 03-22-2019, 01:04 PM Thread Starter
Date registered: Dec 2018
Vehicle: 2014 c207, 1991 c124, 1980 450sl
Quoted: 12 Post(s)
Hello everyone,
As i'm sorting through some stuff on my 560, now i got to the cruise control. I read how to test and repair the amp and how to test the actuator. However, before i get to that, i was changing the valve cover gaskets and I noticed the linkage between the throttle and actuator is missing.
I have a couple of questions here:
1. Could it have been removed for a reason? Perhaps it was removed because it was making the throttle stick in an open position?
2. I read somewhere that the actuator arm should move on its own to match throttle movement even if it was disconnected. Is that true? Because mine doesn't so that probably solves half thr problem
PS: The car js an euro 1990 car with asr
CactiGuy is offline
post #2 of 13 (permalink) Old 03-22-2019, 01:24 PM
John350's Avatar
Date registered: Nov 2014
Vehicle: 1990 350SDL, "Grandpa's Roadster" Project Car
Quoted: 800 Post(s)
I suspect that means disconnected from the cruise amplifier, not from the throttle. The actuator will not follow the throttle if it's not connected to the throttle...
AxelWulff likes this.
John
"Real engines don't have spark plugs!"
John350 is offline
post #3 of 13 (permalink) Old 03-22-2019, 10:56 PM Thread Starter
Quoted: 12 Post(s)
Makes a lot of sense thanks! Sounds like it will not be an easy fix
CactiGuy is offline
post #4 of 13 (permalink) Old 03-23-2019, 02:51 AM
MBL87560SEC's Avatar
Date registered: Jul 2004
Vehicle: 1991 500SEC sub 50K mi. 1987 560SEC Now 150K mi. 2018
Quoted: 396 Post(s)
Hey CactiGuy,
In addition to John's contribution above, here are the MBCD pdfs showing the physical differences between conventional throttle linkage and the ASR variant.
*PDATE: Here are all pdfs for the Acceleration Control System - M116/4.2 L & M117/5.6 L.
As a note here, M16 the cruise actuator in manual throttle control is replaced in the ASR variants with M16/1, the actual throttle controller. Its a 'drive by wire' system.
At least you'll be able to see what it should look like & where you are..
Good luck man.
MBL
91 500SEC EURO Germany
87 560SEC USA 49 State Version
Last edited by MBL87560SEC; 03-23-2019 at 11:53 AM. Reason: Added additional ASR Tech Info
MBL87560SEC is offline
post #5 of 13 (permalink) Old 03-23-2019, 05:47 AM
Date registered: Jan 2007
Vehicle: 1979 280 SLC, 1987 560SEC, 1995 E280T
Quoted: 6 Post(s)
Hi CactiGuy,
Maybe it was disconnected for the same reason I did mine (although I unplugged the actuator, rather than disconnect the linkage): After I replaced the amplifier with a resoldered one (which didn't change anything) and installed another actuator, I could feel a vibration in the accelerator. Going back to the last thing I changed before it occurred, I unplugged the actuator and the vibration disappeared.
I am no further in figuring out why my cruise control still doesn't work, but at least I no longer have this nagging vibration under my right foot.
Tempur
tempur is offline
post #6 of 13 (permalink) Old 03-23-2019, 08:35 AM Thread Starter
Quoted: 12 Post(s)
Hey CactiGuy,
In addition to John's contribution above, here is the MBCD pdf showing the physical differences between conventional throttle linkage and the ASR variant.
Here too, is the ASR Design & Function pdf.
Good luck man.
MBL
Hello MBL and thanks a lot for the very helpful info! It's very easy to get the wrong part
However, i am having trouble loading the photos you attached
CactiGuy is offline
post #7 of 13 (permalink) Old 03-23-2019, 08:36 AM Thread Starter
Quoted: 12 Post(s)
Originally Posted by tempur View Post
Hi CactiGuy,
Tempur
I figured the must be a reason it was disconnected. If it ever happens to me now i know the culprit!
CactiGuy is offline
post #8 of 13 (permalink) Old 03-23-2019, 08:38 AM Thread Starter
Quoted: 12 Post(s)
As a side not, when i reconnect the actuator, i wouldn't feel too confident to test out the cruise control on the road. Would jacking up the read end work?
CactiGuy is offline
post #9 of 13 (permalink) Old 03-23-2019, 08:59 AM
John350's Avatar
Quoted: 800 Post(s)
I wouldn't worry...
I think mine did the worst thing possible: when you turned the cruise on it would floorboard the throttle. When the speed exceeded the set speed by about 5km/hr, it would let the throttle completely off, which reduced the speed below the set point, so it again boarded the accelerator. Wash, rinse, repeat...
Of course, it might be a little worse with a 560 than a 350SD...
John
John350 is offline
post #10 of 13 (permalink) Old 03-23-2019, 10:50 AM
Quoted: 396 Post(s)
I fear this would NOT work as the ASR would sense speed differences between the wheels & apply the ABS to stabilize the perceived incorrect situation.
MBL
Possible Battery Control Module Fault?? Vorland W211 E-Class 54 08-17-2017 07:17 PM
I fixed my cruise control!! St3ve W124 E,CE,D,TD Class 52 09-16-2015 03:12 PM
Useful links 4 new members - repost Bazzle R170 SLK-Class 79 02-06-2011 09:45 PM
cruise control problem link rod question St3ve W124 E,CE,D,TD Class 3 11-13-2006 11:31 AM
Cruise control 560sec alanr W126 S,SE,SEC,SEL,SD,SDL Class 2 01-15-2004 10:30 AM
