560 SEC Engine Swap toughts - Page 3 - Mercedes-Benz Forum
post #21 of 24 (permalink) Old 03-16-2019, 03:08 AM
ianrandom's Avatar
Date registered: Jul 2008
Vehicle: 1986/1990 W126
Quoted: 1158 Post(s)
Perhaps turbo is the way to go if it's possible. Given that this is the low compression US version, I remember reading those would be the best versions to use a turbo on. What's the rating on that version? About 240hp isn't it?
'86 420SE
'90 420SEC
Daily transport 9spd Giant DH Comp downhill bike
ianrandom is offline
post #22 of 24 (permalink) Old 03-16-2019, 05:42 AM
Date registered: Apr 2004
Vehicle: '91 560SEC, '98 SL500
Quoted: 153 Post(s)
Ian - 238 (whopping) hp
slownrusty is offline
post #23 of 24 (permalink) Old 03-16-2019, 05:57 AM
ianrandom's Avatar
Hmm about the same as my 420. (231) Although that one has a high compression engine and it really sings actually. Very happy to rev and lots of get up.
'86 420SE
'90 420SEC
post #24 of 24 (permalink) Old 03-16-2019, 03:08 PM Thread Starter
Date registered: Mar 2019
Vehicle: 1989 Mercedes Benz 560 SEC
Quoted: 4 Post(s)
Originally Posted by 29Hersey View Post
don't be scared michael,
stuff in a small block chevy with a carb, solid motor mounts, one wire alternator, one wire to distributor,dry sump oil system so it will clear steering and you are all set. You can probably do it for around 9,500-12,000$ good luck.
that was my original intention.
did you do or seen that working yourself?
all the other options mentioned arent really worth the effort, i mean c'mon for under 100hp gain i do not want to spend 20 grand or swap the engine.
Michael24 is offline
Engine swap 500 engine in 380 SEC 1976kjell W126 S,SE,SEC,SEL,SD,SDL Class 29 01-01-2019 02:56 PM
Injection Pump fuel adjustment for the MW and M pumps, engine tuning and maintenance Forcedinduction W123 E,CE,D,CD,TD,TE Class 5 11-28-2017 01:19 AM
Dropping a 560 SEC engine into a 380 SEC - Need Advice GotTheBenz W126 S,SE,SEC,SEL,SD,SDL Class 46 06-01-2012 10:59 AM
New V8 diesel formally announced GregW / Oregon W164 M-Class 0 05-20-2005 09:00 PM
320 CDI vs 350 rubensans W164 M-Class 1 05-03-2005 03:36 PM
