Seatbelt presenter. - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 03-01-2019, 06:30 AM Thread Starter
gogi's Avatar
Date registered: Jan 2008
Vehicle: 1991 560sec. 1969 280SL
Quoted: 235 Post(s)
Seatbelt presenter.
If the seat buckle is disconnected under the passenger side seat, would that completely disable the s/belt presenter on my 91 sec ?
My passenger side presenter is inoperable and I donít hear the motor. I did do the reset to no avail.
gogi is offline
post #2 of 9 (permalink) Old 03-02-2019, 09:22 AM
MBL87560SEC's Avatar
Date registered: Jul 2004
Vehicle: 1991 500SEC sub 50K mi. 1987 560SEC Now 150K mi. 2018
Quoted: 403 Post(s)
My passenger side presenter is inoperable and I don’t hear the motor. I did do the reset to no avail.
Hi there,
On my 91, the right side presenter was totally inop when I got it..
In testing & researching the issue, I found the right side controller unit unplugged, the connector just hanging behind the side panel.. After reconnecting I found the motor would not stop.. Obviously the gear was stripped.. I could not believe someone would go to all that trouble to mask a problem.
If your right side extender has never worked, I might pull the right rear cushion & backrest, then side panel, etc. Of course, if this the case, I think obtaining a replacement gear first might be helpful. I drove my nice 'new' SEC for a week, the interior all half torn apart.. :/
Here are the schematics for you & pdfs should you need fine print
I cannot get that pdf of the passenger side below 1.9MB, our max upload ceiling.
Obviously, if yours at one time functioned normally, its something else..
M.
I sent the PDFs by email...
Name:	Screen Shot 2019-03-02 at 11.51.23 AM.jpg
ID:	2493140   Click image for larger version
Name:	Screen Shot 2019-03-02 at 11.51.37 AM.jpg
mramay and wooky_chew_bacca like this.
91 500SEC EURO Germany
87 560SEC USA 49 State Version
MBL87560SEC is offline
post #3 of 9 (permalink) Old 03-02-2019, 11:01 AM
bsclifton's Avatar
Vehicle: 1991 560SEC / 2007 S550
Quoted: 124 Post(s)
I have a spare motor for each side from my 84 500 SEC- I haven’t tested them, but if you wanted to replace, it’s fairly easy to do. Shoot me a DM if you’re interested
1991 560SEC; 145,187 miles
2013 GL550; 99,960 miles
Previous cars
2007 S550; 146,541 miles (sold)
2009 C300; 95,861 miles (sold)
2006 S430; 101,719 miles (sold)
2001 SL500; 114,032 miles (sold)
1986 560SEL; 150,276 miles (hit by drunk driver)
bsclifton is online now
post #4 of 9 (permalink) Old 03-03-2019, 03:45 PM
HardwayMB's Avatar
Date registered: Jan 2018
Vehicle: 1988 560 SEC
Quoted: 73 Post(s)
I agree with MBL87560SEC, best to get the rear cushions out and see what is going on at the control box behind the panel. Take the extender off to see if power is getting to the extender motor as well.
HardwayMB is offline
post #5 of 9 (permalink) Old 03-03-2019, 05:02 PM
wooky_chew_bacca's Avatar
Date registered: Oct 2009
Vehicle: '91 560SEC, '91 300SE (sold), '98 Yota, '02 S-10 Hauler
Quoted: 1282 Post(s)
I started to say but then saw that yall were talking about the same model of SEC. I think it was mclare that told be there were 3 different versions of the presenters, GenI, GenII, and 90-91 and that 90-91 were specific with no interchangeability with the other GenII cars
Some days it's just not worth chewing through the restraints
My Stable:
'91 560SEC "Ursula"
'91 300SE (sold) "Sadie"
'11 Suzuki SX4 Sport Sedan
'02 S-10 Truck
'72 SeaBird boat, "Riff Raft", overhaul restarted
Dif-tor heh smusma
I'm surprised that NOBODY has asked me what this is / means
LOL
wooky_chew_bacca is offline
post #6 of 9 (permalink) Old 03-04-2019, 07:29 AM Thread Starter
gogi's Avatar
Quoted: 235 Post(s)
Jeff I donít think the motor is getting power as I donít hear any noise whatsoever when door is closed. I did check the pin switch in the door jamb and it was fine. The previous owner had told me the presenter sometimes would go crazy in n out, so his mechanic disconnected something.
Iíll probably take things apart when weather warms up, Iíd like to find out what the hell that idiot mechanic disconnected before I proceed. There is no point taking things apart without knowing where the open circuit is. I was wondering if he disconnected the seatbelt buckle,and if he did, how that would affect the circuit.
I would think the only thing that buckle does is tell the arm to retract when seatbelt is fastened, but it may also signal the arm to present when unbuckled. Iím going to take the seat up and see if buckle is indeed disconnected. I think we have one more week of cold before things turn around.
Any thoughts.
gogi is offline
post #7 of 9 (permalink) Old 03-04-2019, 11:44 AM
HardwayMB's Avatar
Quoted: 73 Post(s)
You are certainly on the right track Gogi. Best to see what was done before doing anything else. The seat belt buckle also turns off the "fasten seat belt" strobe in the dome light and depending on the wiring configuration, the power to the rear dome light may travel through control control box for the presenter. If the presenter was acting irratic, there is a good chance one of the micro switches on the arm assembly is bad or out of adjustment as they tell the control box when the arm is extended and retracted. Who knows, fixing the presenter may only require plugging the harness back in to the control box and adjusting a micro switch.
post #8 of 9 (permalink) Old 07-11-2019, 10:24 AM Thread Starter
gogi's Avatar
Quoted: 235 Post(s)
Originally Posted by MBL87560SEC View Post
Hi there,
M.
Well I finally got around to checking my seatbelt extender. It turns out one of the plugs on my controller was unplugged just like yours. Reconnecting the plug made the ext arm go all the way out and the motor keeps running. So I took off the right rear trim panel and found both the plastic gears in very good shape. Removed assembly and examined, everything looked ok,
After making several attempts at adjustment of micro switches I was not able to reverse polarity of the motor or even able to make the extender stop at the end of its travel out. It was a very hot day for me today so after spending an hour or so checking things out I had enough of the heat. So tomorrow I will test all three switches for continuity. If the switchís test ok, I will be lead to believe I need a new controller, which I very much dought.
Any thoughts would be much appreciated. Thanks all.
gogi is offline
post #9 of 9 (permalink) Old 07-12-2019, 08:30 PM Thread Starter
gogi's Avatar
Quoted: 235 Post(s)
Update.
Upon further investigation found the control relay for the passenger side belt presenter faulty. Sent pm to bsclifton and also found one on eBay. Waiting for response.
jsebastian likes this.
gogi is offline
Seatbelt Presenter on 1993 300CE Thom64 W124 E,CE,D,TD Class 1 10-13-2011 09:23 AM
Seatbelt Presenter on 1993 300CE Thom64 General Mercedes-Benz 1 10-11-2011 08:52 PM
Seatbelt presenter relay jikian W124 E,CE,D,TD Class 5 09-28-2011 09:00 AM
Seatbelt Presenter!!! SEC380 W126 S,SE,SEC,SEL,SD,SDL Class 6 03-13-2008 09:18 PM
Coupe Seatbelt Presenter & Rear Window alydon W126 S,SE,SEC,SEL,SD,SDL Class 5 09-24-2006 12:39 PM
