Hirschman Antenna wiring help - Page 2 - Mercedes-Benz Forum
post #11 of 15 (permalink) Old 04-14-2019, 06:00 PM
mclare's Avatar
Date registered: Aug 2008
Vehicle: 2012 CL550 4MATIC Coupe
Quoted: 311 Post(s)
Send a message via Yahoo to mclare Send a message via Skype™ to mclare
I have them.
Current Stable:
2012 CL550 C4 4MATIC Coupe
Past cars:
1991-560 SEC AMG - Coupe - 199/261 - 300 HP Custom Built Motor - Highly Modified Coupe.
1990-560 SEL - Sedan - 199/261 - Stock. Euro Headlamps & Wipers
1987 560 SEC Black/Tan
1988 420 SEL Champagne/Brown
mclare is offline
post #12 of 15 (permalink) Old 04-14-2019, 07:36 PM
Date registered: Apr 2018
Vehicle: 1988
Quoted: 7 Post(s)
Originally Posted by mclare View Post
I have them.
Id appreciate seeing them.
I have an opposite setup than you had in that I have 6 wires on the harness side and 4 wires on the antenna.
Im trying to get the antenna to work. So far no luck.
TIA
Ron
Massauto
Massauto is offline
post #13 of 15 (permalink) Old 04-26-2019, 08:58 AM
mclare's Avatar
Quoted: 311 Post(s)
TIA
Ron
Massauto
Have you taken the antenna apart and made sure everything was intact inside? They do corrode over time.
Do you know how to open the case?
Current Stable:
Past cars:
mclare is offline
post #14 of 15 (permalink) Old 04-26-2019, 01:08 PM
Vehicle: 1988
Quoted: 7 Post(s)
Thanks everyone for the tips. Finally got it connected up properly. The reason it didn’t work when I first wired it in was because the fuse was blown (yes, I checked it before I got the replacement antenna).
I appreciate the advice!
Ron
Massauto
MBL87560SEC and luckymike like this.
Massauto is offline
post #15 of 15 (permalink) Old 07-09-2019, 03:13 PM
Date registered: Nov 2018
Vehicle: 89 560SEC
Quoted: 7 Post(s)
Originally Posted by MBL87560SEC View Post
Hi again, Jim,
Thank you for that last bit! Lol!
I found these diagrams for the sound system [as of MY 1988 starting with 9/88 Production].
The next one is for MY 1991, so I surmise these ought to apply to your situation..
Here's hoping this will shed some light.
The 'always ON' Red/White goes to antenna & the trunk light.
Blue is powered when the radio is powered ON and provides trigger for the antenna to rise & stay UP.
Blue/Green & Blue/Yellow are from the antenna switch. ***
Black powers the Amplifier, as you can see...
Brown is the Ground supply.
*** As yours has no switch, then you can safely disregard these two.. Tape 'em off, whatever..]
In addition, BLUE & BLUE/WHITE speak the same language here..
In case the small print is too much, here are the same converted to .pdf .
Good luck man,
MBL
P.S. Thanks for putting up with my earlier silliness....
Thank you for posting this information. I was going a little crazy trying to figure out how the audio wiring was configured in my 89 560SEC, when trying to remove an aftermarket one and going back to stock
Those 2 diagrams fully explained it!
MBL87560SEC likes this.
elislider is online now
W220 2006 S500 4Matic antenna wiring question dnorwood General Mercedes-Benz 1 01-21-2018 02:33 PM
Antenna wiring golfboy W124 E,CE,D,TD Class 7 05-14-2017 11:34 AM
Comand 2.0 Nav loses its location .... RJV W163 M-Class 11 08-22-2014 08:48 AM
Cellphone Antenna Discussion wallyp W220 S-Class 28 01-13-2014 12:28 PM
Antenna wiring schematic dwaink W201 190-Class 2 03-01-2012 10:51 PM
