Timing chain - look at mine and advise - Mercedes-Benz Forum
post #1 of 21 (permalink) Old 02-26-2019, 10:52 AM Thread Starter
nugent's Avatar
Date registered: Jul 2005
Vehicle: 2008 E350 110k, 2000 E320 143k, 1983 380SEC 240k
Quoted: 117 Post(s)
I took off the RHS valve cover to check my timing chain, sprocket, guide and tensioner. This is what I found and I would like some suggestions about how to proceed. The vehicle is a 1983 380SEC with 239k miles. I have owned it for three years and have no maintenance record of timing chain work. It runs great. I previously asked for a how-to at https://www.benzworld.org/forums/w12...ing-chain.html
I was able to lift a link off the sprocket with my fingers about 1 mm. So just a little bit of play. In the first photo I rotated the engine to 0 deg. The next photo shows the position of the cam. Then I continued until the cam marks lined up, and a photo of the associated crank position - about 7 deg off.
Continues on next post...
ID:	2492010   Click image for larger version
ID:	2492012   Click image for larger version
ID:	2492014   Click image for larger version
nugent is offline
post #2 of 21 (permalink) Old 02-26-2019, 11:05 AM Thread Starter
nugent's Avatar
Quoted: 117 Post(s)
Here are some pics of the chain, sprocket , tensioner and guide. All seem ok, except some scoring of the tensioner. The oiler tube is securely attached (not shown).
Also the inside of the cover, which has some crud, but no marks.
My question: Should I change out the chain and/or the tensioner, guides, sprockets? Or, if it is not broken, not fix it?
I feel that doing all is too much of a stretch for my abilities and facilities. There is a local shop I would trust with the job, but $$. But ruining the engine, $$$$.
ID:	2492020   Click image for larger version
ID:	2492022   Click image for larger version
ID:	2492024   Click image for larger version
ID:	2492026   Click image for larger version
ID:	2492030   Click image for larger version
nugent is offline
post #3 of 21 (permalink) Old 02-26-2019, 11:10 AM
MBL87560SEC's Avatar
Date registered: Jul 2004
Vehicle: 1991 500SEC sub 50K mi. 1987 560SEC Now 150K mi. 2018
Quoted: 396 Post(s)
Hi there nugent,
In your previous positing a month ago, you reported the previous owners had told you the car had the updated double row timing chain.
To state the obvious, that is not the case.
This one needs that update as you can see here...
That's the 'Full Monte' as it were.
From your description here, the chain sounds pretty stretched and loose...
The earlier timing chain tensioner tends to bleed down and when the engine is started again the loose chain can 'slap' the now brittle plastic guides,,, etc..
It can all cascade down hill in a heartbeat....
Thats not what you want to hear, I'm sure...
Malcolm.
nugent likes this.
91 500SEC EURO Germany
87 560SEC USA 49 State Version
MBL87560SEC is offline
post #4 of 21 (permalink) Old 02-26-2019, 11:13 AM
bondavi's Avatar
Date registered: Sep 2004
Vehicle: 1983-2007 MB's
Quoted: 832 Post(s)
You're running the single, not dual chain, so best insurance is to just do the chain/guides, your guides are getting up there was far as color, but it does look like they were replaced at one point already due to the lightness of the plastic color.
nugent likes this.
bondavi is offline
post #5 of 21 (permalink) Old 02-27-2019, 09:49 AM Thread Starter
nugent's Avatar
Quoted: 117 Post(s)
I have enquired at a few local MB shops for an estimate to replace the timing chain and associated bits. Two have said they will get back to me. Will update when I get a response. Anyone have a $ number?
nugent is offline
post #6 of 21 (permalink) Old 02-27-2019, 10:13 AM
281lxm's Avatar
Date registered: Dec 2011
Vehicle: 1991 560 SEC 1994 E500 2014 E350 Cab
Quoted: 435 Post(s)
Below a grand if you just change the chain, if you need to remove the timing cover and the water pump and sprockets and radiator to install a new front seal and the lower sprocket, lower guides and double row setup, I would say double that to 1800-2100
_____________________________________________
1991 560SEC 199 /268, 17" RS90'S, Eibach springs, Bilstein HD shocks, Custom rear sway bar, Euro Headlights, Custom ceramic coated headers and down pipes with stainless dual exhaust, W140 glass sunroof, dog ear trunk spoiler, OEM Skid Plate, Euro bumpers, wood refinish and restored.
281lxm is offline
post #7 of 21 (permalink) Old 03-06-2019, 05:41 PM
Date registered: Jan 2017
Vehicle: 1982 380SEC, 2014 ML350 4Matic
Quoted: 9 Post(s)
Youre on borrowed time. Kind of fun to see a chain that actually lasted that long.
281lxm likes this.
1982sec380 is offline
post #8 of 21 (permalink) Old 03-07-2019, 06:22 AM
gogi's Avatar
Date registered: Jan 2008
Vehicle: 1991 560sec. 1969 280SL
Quoted: 226 Post(s)
Just do it yourself, youd be surprised at how relatively easy it is. Those guides indicate a need for replacement.
gogi is offline
post #9 of 21 (permalink) Old 03-07-2019, 07:48 AM
281lxm's Avatar
Quoted: 435 Post(s)
The job is on a single row chain 380sec. Timing case needs to come off along with everything attached to it. Crank sprocket, cam sprockets, upper and lower guides. While you are in there items would be the water pump and gasket, Tstat, short hose, belts, reseal of PS if needed, crank seal and so on and so forth. Basic job for 560 is easy, but to bring the 380 up to MB TSB with double row, after all this time would likely encounter much more shop time by a pro or by a lay person.
281lxm is offline
post #10 of 21 (permalink) Old 03-07-2019, 08:42 AM Thread Starter
nugent's Avatar
Quoted: 117 Post(s)
Originally Posted by 281lxm View Post
...but to bring the 380 up to MB TSB with double row, after all this time would likely encounter much more shop time by a pro or by a lay person.
Thank you and 1982sec380 and gogi for your thoughtful comments. Having done some research I have decided that due to my lack of a garage, some tools and general inexperience, I will either take it to a shop, or run it into the ground.
I had not heard back from the two shops I asked, so I called again this morning. The first gave me a ballpark $500 - $700. The second gave a ballpark $5,000 (!) to install a double-row chain and will get back to me on just replacing the single-row, which naturally should include the guides and tensioner. Apparently their approach is to replace single-row chains every 35,000 miles. Both are reputable Mercedes indie shops.
BTW 1982sec380, I can't imagine the chain is original, never replaced. But I have no way of knowing how old it really is.
1982sec380 likes this.
nugent is offline
Stalling Again DP W201 190-Class 2119 11-14-2018 04:16 PM
1986 560SL and it's mine! canswede R/C107 SL/SLC Class 12 06-30-2017 08:43 AM
Bose Radio...Bad Advise BobRR3 R129 SL-Class 3 10-07-2010 06:10 PM
1995 w124 E200 - timing chain question BenzLadin W124 E,CE,D,TD Class 4 12-03-2008 05:54 AM
S600. One last try. Need some advice lesrrt W140 S-Class 1 10-16-2007 10:05 AM
