got tri - y headers - now what - Page 6 - Mercedes-Benz Forum
post #51 of 169 (permalink) Old 03-04-2019, 10:25 PM Thread Starter
vdubpower's Avatar
Date registered: Nov 2003
Vehicle: 1985 500sel and 500sec 2012 E63 1989 Porsche 911
Quoted: 554 Post(s)
Originally Posted by bondavi View Post
Logs without cats or resonators, circa 2009:
https://www.youtube.com/watch?v=ZltJmT9O7og
oh i do like that so much
how was it driving though? droney?
1985 500SEL Euro Nautic Blue - A Classic Beauty
1985 500SEC Euro Nautic Blue
1989 Porsche 911 Carrera Silver Anniversary Edition
2012 E63 AMG Iridium Silver - Performance Package
vdubpower is offline
post #52 of 169 (permalink) Old 03-04-2019, 10:26 PM Thread Starter
vdubpower's Avatar
Quoted: 554 Post(s)
i watched this video, very good and informative
seems key is know the CFM produced by the flow of the motor when determining the proper set up
Black Swan likes this.
post #53 of 169 (permalink) Old 03-05-2019, 10:09 PM Thread Starter
vdubpower's Avatar
Quoted: 554 Post(s)
Mufflers arrived as per KRH recommendations from the Magnaflow/Wheelerdealers design.
Kim why with the rear muffler are we going 2.5 in out, when all the tubing recommended was 2.25 as with the middle resonator...
So next i visited local muffler shops....everyone uses aluminized tubing, too expensive for them to buy mandrel bender and use stainless
i figure i live in cali, im not worried about rust....do i need to do stainless....
I know using a Mandrel leads to some narrowing of the bends, but other option is the shop welds U bends to each section.....that willbe $$
one quote i had is 1800-2000..thats to much for this wallet
ive already have 2100 in my try y components after ceramic and smoothening the flanges
i still need to pay for install then paint work for body down the road
post #54 of 169 (permalink) Old 03-06-2019, 11:10 AM
Chicky's Avatar
Date registered: Apr 2007
Vehicle: 1991 R129 500SL
Quoted: 101 Post(s)
Thumbs up
Bought the same items also,after reading KRH's recommendation, but having them shipped via the slow boat to Manila
Chicky is offline
post #55 of 169 (permalink) Old 03-06-2019, 10:51 PM Thread Starter
vdubpower's Avatar
Quoted: 554 Post(s)
reviewing some film
post #56 of 169 (permalink) Old 03-07-2019, 02:14 AM
KRH
KRH's Avatar
Date registered: Nov 2009
Vehicle: 87 Euro500HVSEC. 88 Euro 560HVSEC. 89 Euro 560HVSEL
Quoted: 539 Post(s)
You get the 2.25" pipes flaired to 2.5" where they connect/weld into the rear muffler
I just followed what Magnaflow did in their R&D testing and end result of what they chose and what was installed on Bobs WB coupe in the video
by
, on Flickr" border="0" />
87 White Euro 500 "ECE" 265hp SEC
88 Black Euro 560 "RUF"300hp SEC
89 Blue Euro 560 "RUF" 300hp Hydro SEL
KRH is offline
post #57 of 169 (permalink) Old 03-07-2019, 02:18 PM Thread Starter
vdubpower's Avatar
Quoted: 554 Post(s)
got it, hope its not an issue for my tail pipe tips because i bought the amg replica ones and they may be 2 inch diameter at inlet...i isuppose a shop can figure how to get from 2.5 to 2
post #58 of 169 (permalink) Old 03-09-2019, 02:58 PM Thread Starter
vdubpower's Avatar
Quoted: 554 Post(s)
so i am going to return the rear muffler with the 2.5 inch in and out, for the same design with 2.25 ...it is 11385 model number
issue is that the tips i purchased only have a 2 inch inlet so the transition to the 2.5 muffler would be not ideal. ....this is all info per a well reputed muffler shop.
and i think i may give a go with an x pipe out front and see what happens 10790
post #59 of 169 (permalink) Old 03-15-2019, 02:16 PM
Date registered: Jul 2011
Vehicle: '87 560 SEC, Pearl Grey/blue; 300,000+ mi; '07 CLS 550, Barolo/stone; 90,000+ mi
Quoted: 40 Post(s)
Originally Posted by MBL87560SEC View Post
Hey vdub,
Congratulations & well done!
From personal experience, I know you will really enjoy the results gained.
The parts image is from the iauto.It site. MouseOver the numbers shows the quantity needed & where. Click on the diagram number, the parts list displays with your selection highlighted.
For example, you'll need a couple of 209 support brackets & ditto to the 251 hardware kits.
[I used aftermarket for the kits, MB for the brackets.]
https://www.iauto.lt/mercedes-benz/C...oups_ID=430620
*As the site is not in English, I use the Chrome browser as it will do an on-the-fly translation.*
Though the pages do NOT show the manifold to heads gaskets & hardware, I do have a parts invoice somewhere around here that has ALL those items needed listed. I will dig around for you after breakfast.
Cheers,
MBL
MBL,
Does this mean we would need two of each part number for 209 and 251, and are they available from usual U.S. MB dealers/parts suppliers? (The site looks to be maybe in Slovene or something similar). When we give them to the exhaust shop, will it be readily apparent to them how the parts are to be used?
Thanks,
Drew
DrewPT is offline
post #60 of 169 (permalink) Old 03-15-2019, 04:14 PM
MBL87560SEC's Avatar
Date registered: Jul 2004
Vehicle: 1991 500SEC sub 50K mi. 1987 560SEC Now 150K mi. 2018
Quoted: 407 Post(s)
Originally Posted by DrewPT View Post
MBL,
Thanks,
Drew
Hey Drew:
The L & R downpipe supports for Tri-Y are exactly the same as the US version [only to the right side] as there are two pipes involved. Try-Y needs another support bracket + hardware, as the transition is four into two, just a bit downstream of brackets... As you see, it's is supported just UPstream of the flanges and before the pipes merge.
We are gettin' there!
M.
US version pictured first time, followed by the Tri-Y install.
ID:	2496538   Click image for larger version
91 500SEC EURO Germany
87 560SEC USA 49 State Version
MBL87560SEC is offline
Custom Tri Wye Headers for $1200.00 - Who wants a set? mclare W126 S,SE,SEC,SEL,SD,SDL Class 77 01-16-2014 10:55 AM
M117 SLC - Will Tri Y headers fit??? StreekG R/C107 SL/SLC Class 3 12-06-2009 12:30 PM
ECU Tuning Options Williams707 C208/A208 CLK-Class 30 11-10-2009 09:24 PM
R107 M117 Tri Y headers and Down Pipes jhodg5ck For Sale/Wanted/Trade/Giveaway 5 10-07-2009 02:26 PM
Open down pipes on tri y AMG cast headers jhodg5ck W126 S,SE,SEC,SEL,SD,SDL Class 10 08-08-2005 09:11 AM
