got tri - y headers - now what - Page 2 - Mercedes-Benz Forum
post #11 of 169 (permalink) Old 02-06-2019, 11:45 PM Thread Starter
vdubpower's Avatar
Date registered: Nov 2003
Vehicle: 1985 500sel and 500sec 2012 E63 1989 Porsche 911
Quoted: 545 Post(s)
but the egr doesnt use a bracket like that? its just a hole with threads on one part of the header right?
1985 500SEL Euro Nautic Blue - A Classic Beauty
1985 500SEC Euro Nautic Blue
1989 Porsche 911 Carrera Silver Anniversary Edition
2012 E63 AMG Iridium Silver - Performance Package
vdubpower is offline
post #12 of 169 (permalink) Old 02-07-2019, 03:33 AM
Richter Rox's Avatar
Date registered: Aug 2016
Vehicle: 1988 560 sec
Quoted: 184 Post(s)
The block off plate is for the intake manifold side, to plug the header i would use a threaded plug that way if at a later date the egr valve could be reattached if necessary.
MBL87560SEC likes this.
Richter Rox is offline
post #13 of 169 (permalink) Old 02-07-2019, 06:56 AM Thread Starter
vdubpower's Avatar
Quoted: 545 Post(s)
Why would one block the intake manifold. What am I missing here
post #14 of 169 (permalink) Old 02-07-2019, 07:31 AM
MBL87560SEC's Avatar
Date registered: Jul 2004
Vehicle: 1991 500SEC sub 50K mi. 1987 560SEC Now 150K mi. 2018
Quoted: 398 Post(s)
The recirculated exhaust gasses are fed/drawn into the inlet manifold with intake vacuum.
91 500SEC EURO Germany
87 560SEC USA 49 State Version
MBL87560SEC is offline
post #15 of 169 (permalink) Old 02-07-2019, 08:43 AM Thread Starter
vdubpower's Avatar
Quoted: 545 Post(s)
I need a visual. I'll look in my bag later today.
post #16 of 169 (permalink) Old 02-07-2019, 01:03 PM
corellian corvette's Avatar
Date registered: Dec 2014
Vehicle: 1991 560SEC
Quoted: 164 Post(s)
I just got a brass metric plug from the hardware store to cap the EGR hole on my Euro exhaust. Should be the same as the Try-y. I assume you're not running EGR?
There should be a pic in my engine swap thread - find a pic of the drivers side manifold you'll see the brass cap. Can't leave that open you'll have a massive exhaust leak.
1991 560 SEC Euro
1986 420 SEL
1985 500 SEC (US)
1983 500 SEC (Euro)
corellian corvette is offline
post #17 of 169 (permalink) Old 02-07-2019, 02:44 PM
liviu165's Avatar
Date registered: Aug 2013
Vehicle: 1989 MB 420SEL, 1991 560SEC
Quoted: 624 Post(s)
Originally Posted by vdubpower View Post
I need a visual.
Here is the where the flange would go. However, I would not recommend doing that because of the trouble you'd have to go to get to that area and because of the CA emission laws. That would be done only when you remove the intake assembly and plan on refreshing the rubber rings between the two intakes.
If you do have the hole plugged in the intake (that's my understanding ), then most likely you should not worry about that flange.
If you do still have the EGR operational (because of the CA emission laws), just transfer it to the tri-y and do not connect its vacuum line to it (remove the vacuum line and plug the port on the vacuum valve) and reconnect the vacuum tube before you have your emission testing done. The vacuum is what is opening it, and if no vacuum to the EGR then no exhaust gases in the intakle, it's that simple.
Anyway, the EGR issues is probably your easiest part of the entire job you are planing.
Tom Kaiser and Richter Rox like this.
liviu165 is offline
post #18 of 169 (permalink) Old 02-07-2019, 03:37 PM
KRH
KRH's Avatar
Date registered: Nov 2009
Vehicle: 87 Euro500HVSEC. 88 Euro 560HVSEC. 89 Euro 560HVSEL
Quoted: 533 Post(s)
I agree with liviu - leave it all in place as if it is functioning but disconnect & plug the vacuum line.
The amount of carbon buildup/mess that EGR system makes to the plenum chamber & intake runners & back of valves etc is not good.
by
, on Flickr" border="0" />
87 White Euro 500 "ECE" 265hp SEC
88 Black Euro 560 "RUF"300hp SEC
89 Blue Euro 560 "RUF" 300hp Hydro SEL
KRH is offline
post #19 of 169 (permalink) Old 02-07-2019, 06:26 PM
Date registered: Jul 2011
Vehicle: '87 560 SEC, Pearl Grey/blue; 300,000+ mi; '07 CLS 550, Barolo/stone; 90,000+ mi
Quoted: 37 Post(s)
One of the Tr-Y's I just sent off to Swain Tech has a brass fitting that looks like a little pipe/valve--is this the EGR and do I need to do anything with it during installation?
DrewPT is offline
post #20 of 169 (permalink) Old 02-07-2019, 11:09 PM Thread Starter
vdubpower's Avatar
Quoted: 545 Post(s)
My sec has NO Egr, the hole on the euro logs currently on the car is already plugged with a bolt or something
on my SEL, there is egr and i have no idea if its functioning...maybe...we removed lamda box that wastn functioning and frequency valve when i did the top end rebuild...anything that was non OEM
probably will chop off my old cats eventually on the sel...
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
nehuge
Custom Tri Wye Headers for $1200.00 - Who wants a set? mclare W126 S,SE,SEC,SEL,SD,SDL Class 77 01-16-2014 10:55 AM
M117 SLC - Will Tri Y headers fit??? StreekG R/C107 SL/SLC Class 3 12-06-2009 12:30 PM
ECU Tuning Options Williams707 C208/A208 CLK-Class 30 11-10-2009 09:24 PM
R107 M117 Tri Y headers and Down Pipes jhodg5ck For Sale/Wanted/Trade/Giveaway 5 10-07-2009 02:26 PM
Open down pipes on tri y AMG cast headers jhodg5ck W126 S,SE,SEC,SEL,SD,SDL Class 10 08-08-2005 09:11 AM
