got tri - y headers - now what - Page 11 - Mercedes-Benz Forum
post #101 of 112 (permalink) Old 04-14-2019, 06:03 PM
Date registered: Jul 2011
Vehicle: '87 560 SEC, Pearl Grey/blue; 300,000+ mi; '07 CLS 550, Barolo/stone; 90,000+ mi
Quoted: 27 Post(s)
Originally Posted by vdubpower View Post
learned today that the downpipes were supposed to have some sort of insulation on them...mine didnt
The factory originals were "aluminized" steel--coated with aluminum as an extra measure of protection, but over time chip and lead to rust rot. I was fortunate to obtain some aftermarket production downpipes that were either stainless or high-chromoly steel (perhaps yours are the same type), and sent them to SwainTech for the "White Lightning" coating (for heat dampening and some modicum of corrosion protection). It penetrates the pores and is applied in three coats, so they are assuming some chipping over time and still protection is embedded in the steel.
DrewPT is offline
post #102 of 112 (permalink) Old 04-14-2019, 08:46 PM Thread Starter
vdubpower's Avatar
Date registered: Nov 2003
Vehicle: 1985 500sel and 500sec 2012 E63 1989 Porsche 911
Quoted: 519 Post(s)
yeah i had mine blasted and ceramic coated...probably similar to what you had done
my issue now obviously is this fitment issue with the driver side ...im gonna have to have someone heat bend them i guess, if thats even possible ...and then im sure my coating will get messed up...
1985 500SEL Euro Nautic Blue - A Classic Beauty
1985 500SEC Euro Nautic Blue
1989 Porsche 911 Carrera Silver Anniversary Edition
2012 E63 AMG Iridium Silver - Performance Package
vdubpower is online now
post #103 of 112 (permalink) Old 04-15-2019, 06:48 PM
Quoted: 27 Post(s)
Hopefully its just an issue of having to change smushed transmission and/or engine mounts as others have suggested--I can't imagine trying to heat bend those things.
DrewPT is offline
post #104 of 112 (permalink) Old 04-15-2019, 09:26 PM Thread Starter
vdubpower's Avatar
Quoted: 519 Post(s)
yeah i dunno, all mounts are confirmed good, mechanic checked, ive checked, they are solid
post #105 of 112 (permalink) Old 04-16-2019, 01:38 AM
Date registered: Feb 2008
Vehicle: Too many to list
Quoted: 1438 Post(s)
They just need to be bent up more towards the car, right ? Seems you could just jack the car up , by the down pipe itself , to push it upwards.
tusabes is offline
post #106 of 112 (permalink) Old 04-16-2019, 04:02 AM
MBL87560SEC's Avatar
Date registered: Jul 2004
Vehicle: 1991 500SEC sub 50K mi. 1987 560SEC Now 150K mi. 2018
Quoted: 372 Post(s)
vdub,
I've been puzzling about your left side pipe fitment issue for days, and there is one factor you had mentioned, as yet to be considered here.
In your post 91, something you wrote caught my eye this morning:
we really dont know what we should do...tony was thinking the exhaust shop could heat the pipes to help get it around..i dont know
we rechecked the headers again and again to make sure they were correct....obviously they can only fit in one position right?
You had said back in post 21 that you'd had the manifold flanges 'cleaned up' / machined and posted a pic .. Why was this done please? Had there been a gouge on a sealing surface perhaps? Were the left & right side manifolds ground together? Were the four ground individually? How were they keyed to a common reference point? How much material was removed?
The reason I bring this up is that in machining them thinner [as was done here], effectively tucks the exhaust in closer to the centerline of the engine. Furthermore, if by happenstance, the manifold[s] were ever so slightly rotated off plane [and surfaces ground], it would follow that [when mounted], this rotation would amplify outwards... Just sayin'...
I realize this is but a possibility, a longshot really rather than a probability here.. It's only thousanths of an inch after all.. That said, it is an aspect now that the manifold mating surfaces have been altered, back in February. Material removed here alters the 'reference point'... the spacial geometry if you will. Done without due care, ..... one questions.......
In my Tri-Y readings since 2004, in all the threads discussing Tri-Ys here on BW, and other sites I've similarly researched, I believe this is the first time I have read of header flanges being machined.
Going forward, to gain more clearance, has your tech discussed remounting the left side manifolds while doubling up on the exhaust port flange gaskets?
Look, I don't even know if this is feasible, but if so, by doing, it seems possible to move/shim the manifold inlets/outputs & downpipes outward/downwards, thus further away from the 'engine centerline'*, gaining clearance [at the bell housing] you don't have at present.
If this were even possible, would the effort/expense be worth it?
It's an idea anyways...
M
* At the same oblique angle [from the vertical] as the exhaust ports / mounting flanges.
91 500SEC EURO Germany
87 560SEC USA 49 State Version
MBL87560SEC is offline
post #107 of 112 (permalink) Old 04-16-2019, 04:17 AM
Quoted: 372 Post(s)
Though he did say "get it lifted up to use the brackets and clamp.." in post 91, I thought he was talking about lack of clearance drivers' side.. downpipe to bell housing/transmission.. "part of tube is really close to the transmission ....like i can barely slide a piece of paper in between...." His pic shows it right ON the bell housing in post 93..
With all the joints, flanges, support brackets .. there ought to be enough wiggle room.. but apparently, in this case there just isn't..
post #108 of 112 (permalink) Old 04-16-2019, 08:49 AM
Das 420's Avatar
Date registered: Jul 2013
Vehicle: 1990 420 SEL, 1990 560sel, 1991 300e
Quoted: 108 Post(s)
Originally Posted by MBL87560SEC View Post
I realize this is but a possibility, a longshot really rather than a probability here.. It's only thousanths of an inch after all.. That said, it is an aspect now that the manifold mating surfaces have been altered back in February..
Im getting ready to install my Try-y's so ive been following this thread, with the understanding that they are a tight fit on our cars.
Im wondering if the ports got machined at a slight angle, just 0.5-1 deg of offset angle when machining the flanges could possibly cause 1/2" or more of in/out movement at the collector flange.
On a side note, what are the recommended bolts to be used on the heads when mounting the manifolds. Do folks just order up original mb, or go with something different like a stainless bolt with stainless washers? I prefer not to reuse the originals as they are not the best looking.
MBL87560SEC likes this.
In the Shop so far...
90 420SEL
90 560SEL
05 Crossfire SRT-6
02 AM General H1
Das 420 is offline
post #109 of 112 (permalink) Old 04-16-2019, 09:15 AM
Quoted: 372 Post(s)
*[For clarity, it was the exhaust manifold flanges that were ground.]*
Hey Das, I could be wrong, and I believe what you said above is a distinct possibility here. As you say, the slightest deviation from 'plane' will amplify as the distance grows...
There are studs on the bottom, bolts on the tops. Thanks to the generosity of the fellow BW member I obtained my headers/downpipes from [Alydon], I used all new Mercedes hardware to mount them & downpipes, to the car
MBL
post #110 of 112 (permalink) Old 04-16-2019, 04:07 PM
Stutz's Avatar
Date registered: Oct 2009
Vehicle: 1999 500SL, 1988 SEC
Quoted: 219 Post(s)
Das420, I used all studs just to make sure I did not strip any threads. Seemed to work ok. Purchased them from MB but would think any exhaust brand stud would work
Stutz is offline
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
vdubpower
Custom Tri Wye Headers for $1200.00 - Who wants a set? mclare W126 S,SE,SEC,SEL,SD,SDL Class 77 01-16-2014 10:55 AM
M117 SLC - Will Tri Y headers fit??? StreekG R/C107 SL/SLC Class 3 12-06-2009 12:30 PM
ECU Tuning Options Williams707 C208/A208 CLK-Class 30 11-10-2009 09:24 PM
R107 M117 Tri Y headers and Down Pipes jhodg5ck For Sale/Wanted/Trade/Giveaway 5 10-07-2009 02:26 PM
Open down pipes on tri y AMG cast headers jhodg5ck W126 S,SE,SEC,SEL,SD,SDL Class 10 08-08-2005 09:11 AM
