New owner of a '89 560 sel, need help with some issues - Page 3 - Mercedes-Benz Forum
post #21 of 31 (permalink) Old 01-28-2019, 07:46 PM
281lxm's Avatar
Date registered: Dec 2011
Vehicle: 1991 560 SEC 1994 E500 2014 E350 Cab
Quoted: 435 Post(s)
Originally Posted by LouC13 View Post
Also this is a question that has been asked a million times but what spark plugs do you guys go with. I know they are non resistor plugs, any exact model numbers. Are Bosch ok?
Mb plugs from the dealer
_____________________________________________
1991 560SEC 199 /268, 17" RS90'S, Eibach springs, Bilstein HD shocks, Custom rear sway bar, Euro Headlights, Custom ceramic coated headers and down pipes with stainless dual exhaust, W140 glass sunroof, dog ear trunk spoiler, OEM Skid Plate, Euro bumpers, wood refinish and restored.
281lxm is offline
post #22 of 31 (permalink) Old 02-08-2019, 06:33 AM Thread Starter
LouC13's Avatar
Date registered: Jan 2019
Vehicle: 1989 560SEL
Hi again,
So I was waiting for parts to come in and havent had much time to work on the car, but I finally got the ke-injection system off the engine. Hit a couple of snags... it was very hard to pull the unit off, broke the thermo sensors and had to order new ones, broke 2 of the mounts that the unit sits on but other than that not too bad. How did you guys remove the broken mounts? It's just the threaded part sticking into the engine and the top half broke off. Too hard to twist our by hand and cant really get a grip on them to twist them out. Today and tomorrow I'm gonna clean everything out and start reinstalling. Looks like its gonna be tough putting everything back together. And routing everything the right way.
LouC13 is offline
post #23 of 31 (permalink) Old 02-08-2019, 07:02 AM
281lxm's Avatar
Quoted: 435 Post(s)
pics of what you have done help when more tenured owners know parts by their names. Also, you do get better and more attentive help when people know where you reside (large city/state or country outside USA).
wooky_chew_bacca likes this.
281lxm is offline
post #24 of 31 (permalink) Old 02-08-2019, 07:16 AM Thread Starter
LouC13's Avatar
Ok I did manage to snap a couple of pictures. The mounts are actually called rubber buffers I think and I thought I had already entered my location but I'll check again. Here's some pictures
ID:	2487796   Click image for larger version
LouC13 is offline
post #25 of 31 (permalink) Old 02-08-2019, 10:29 AM
luckymike's Avatar
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1989 560SEL, 1995 E420
Quoted: 547 Post(s)
Just put a pair of ViceGrips on the edges or a pliers. You don't usually need much movement before it will spin out by hand.
luckymike is online now
post #26 of 31 (permalink) Old 02-08-2019, 03:06 PM
corellian corvette's Avatar
Date registered: Dec 2014
Vehicle: 1991 560SEC
Quoted: 164 Post(s)
That works. Or you can dremel a line across the center and use a flat bladed screw driver. They aren't in there that tight.
Be careful when getting spark plugs from the dealer - many have reported them giving resistor plugs as well, which you'd also get from the parts store. You want to make sure there is no R in the part number. I use NGK BP5ES with no problems.
1991 560 SEC Euro
1986 420 SEL
1985 500 SEC (US)
1983 500 SEC (Euro)
corellian corvette is offline
post #27 of 31 (permalink) Old 02-09-2019, 05:16 PM
wooky_chew_bacca's Avatar
Date registered: Oct 2009
Vehicle: '91 560SEC, '91 300SE (sold), '98 Yota, '02 S-10 Hauler
Quoted: 1275 Post(s)
Nice PIC of what you are working on BUT how do we even know it's a Mercedes or on this planet we call home (Earth) ? (hint hint nudge nudge) Fill out your profile with some important info such the particular model you have and just as important, where on this rock you are hailing (residing) from. It DOES make a difference because if the steering wheel is on the wrong side of the car there are some engine parts that won't fit it (maybe they will, but we don't know)
That piece shown simply screws in, once cracked loose it'll just spin out for the replacement to go in
Top of page goto "UserCP", works better done on a PC and not a phone
Some days it's just not worth chewing through the restraints
My Stable:
'91 560SEC "Ursula"
'91 300SE (sold) "Sadie"
'11 Suzuki SX4 Sport Sedan
'02 S-10 Truck
'72 SeaBird boat, "Riff Raft", overhaul restarted
Dif-tor heh smusma
I'm surprised that NOBODY has asked me what this is / means
LOL
wooky_chew_bacca is offline
post #28 of 31 (permalink) Old 02-13-2019, 08:16 AM Thread Starter
LouC13's Avatar
Took some doing and some swearing but I did manage to get them off, thanks for the help
LouC13 is offline
post #29 of 31 (permalink) Old 02-13-2019, 08:17 AM Thread Starter
LouC13's Avatar
Thanks I also went with the NGk Bp5ES. The caps on top of the spark plugs come off.
LouC13 is offline
post #30 of 31 (permalink) Old 02-13-2019, 08:18 AM Thread Starter
LouC13's Avatar
Copy that thanks, I put my phone on desktop mode and was able to edit my info and I managed to replace the buffers. Thanks.
LouC13 is offline
560 SEL start up issues Amaze126 W126 S,SE,SEC,SEL,SD,SDL Class 5 07-01-2015 05:33 PM
560 SEL Climate Control issues, please help exbert W126 S,SE,SEC,SEL,SD,SDL Class 1 10-19-2012 06:28 PM
1989 560 SEL New Member/New Owner ronohlenkamp W126 S,SE,SEC,SEL,SD,SDL Class 11 06-05-2010 10:28 PM
W126 560 SEL Info TasmanianDevil W140 S-Class 14 01-03-2010 05:05 AM
W140 (99 S500) owner looking at 2 W126's (89 and 90 560 SEL) - Any advice wlevan17 W126 S,SE,SEC,SEL,SD,SDL Class 24 06-21-2008 10:06 AM
