Lower Control Arm Bushing - Page 2 - Mercedes-Benz Forum
post #11 of 13 (permalink) Old 01-13-2019, 05:43 PM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 68 250S, 91 300se, 98 SL500, 450SEL 6.9, 14 CLS550 Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 829 Post(s)
When all else fails, just read the manual:
https://www.startekinfo.com/StarTek/...sis/33-200.pdf
https://www.startekinfo.com/StarTek/...ram/matrix.htm
yes, the new bushing must be oriented correctly, and dont use grease when installing them. Any good shop with a press can get them in for you.
Faiz Jan likes this.
rumb is offline
post #12 of 13 (permalink) Old 01-15-2019, 05:10 AM
HardwayMB's Avatar
Date registered: Jan 2018
Vehicle: 1988 560 SEC
Quoted: 73 Post(s)
As others have said, if one component is failing, chances are others are not far behind. I am currently in the middle of refreshing my front suspension and have taken lots of pictures along the way.
https://www.benzworld.org/forums/w12...thread-11.html
@liviu165 has a great write up here that shows the orientation of the bushings. There is also a specific tool to press the bushing end caps on. He has the MB specific tool but also built his own. Definitely worth a read. I actually sent my LCAs to him as none of the local indy mechanics have inspired any confidence in me.
On page two @MT_Merc indicates the flats of the bushings are to be level with the ground when they are installed.
https://www.benzworld.org/forums/w12...ol-advice.html
liviu165 and Faiz Jan like this.
HardwayMB is offline
post #13 of 13 (permalink) Old 01-15-2019, 06:06 AM
liviu165's Avatar
Date registered: Aug 2013
Vehicle: 1989 MB 420SEL, 1991 560SEC
Quoted: 626 Post(s)
Thanks, Jeff. The flats are supposed to be paralel with the flat on the LCA wich will hold the spring's plate (middle picture, just before the bushing was pressed in)
I actually do not have the MB specific tool, but inspired my tools from the pictures in the FRM. I googled the MB tool to press the bushings, but I was never able to find one single actual picture of it. In the end I made my own (first picture) and they worked perfectly.
ID:	2481812   Click image for larger version
ID:	2481814   Click image for larger version
liviu165 is online now
