Best lubricants for ... - Page 3 - Mercedes-Benz Forum
post #21 of 29 (permalink) Old 01-04-2019, 12:30 AM
Date registered: Dec 2012
Vehicle: 89 190E2.6- 5-speed Manual, 95 E320 Sportsline-sold, 2001 E320 4matic Wagon-sold
Quoted: 533 Post(s)
Send a message via Skype™ to dolucasi
I got mine from the JY. It looked clean so I opened it up prior to purchasing for something like $25. Sure enough was very clean inside. Cleaned up some more, greased the gear mechanism and lubed the mast. Works perfectly. I can't believe I let the car without a functioning antenna for nearly 20 years. It was from the same model years so the antenna switch on the dashboard works perfectly.
Maybe LuckyMike did the same. Cars are abundant (still) in the JY's around here, but not for long, I'm afraid.
- Cheers
dolucasi is offline
post #22 of 29 (permalink) Old 01-04-2019, 12:47 AM
bsclifton's Avatar
Date registered: Jan 2008
Vehicle: 1991 560SEC / 2007 S550
Quoted: 124 Post(s)
- Cheers
The wipes were the ones I was interested in Would be great to know more about that
1991 560SEC; 145,187 miles
2013 GL550; 99,960 miles
Previous cars
2007 S550; 146,541 miles (sold)
2009 C300; 95,861 miles (sold)
2006 S430; 101,719 miles (sold)
2001 SL500; 114,032 miles (sold)
1986 560SEL; 150,276 miles (hit by drunk driver)
bsclifton is offline
post #23 of 29 (permalink) Old 01-04-2019, 10:26 AM
macdeity's Avatar
Date registered: Aug 2009
Vehicle: 1984 500SEC AMG Euro "Das Model"
Quoted: 76 Post(s)
I just ordered a box of lubricants from Kent at Mercedessource and use all that. He did not have the purpose of each lubricant specified, so I ask him for a list and he sent it out.
Door hinges, hood, window regulators, seat tracks, antenna, engine seals, etc, etc, everything seems to be covered.
I know it is expensive (like $60) but it is all there with all the application tubes etc. and I don't have to worry about all the details and it comes in a tray box nice and neat.
- Cheers!
Would you mind posting that list to help all of us in putting together our own kits, thanks.
wooky_chew_bacca likes this.
Just when I thought I was out...they pull me back in
macdeity is offline
post #24 of 29 (permalink) Old 01-04-2019, 11:50 AM
Quoted: 533 Post(s)
Will do when I get home. At least the type of lubricant will be there not necessarily the brand.
Honestly, you would end up with more material if purchased individually but will be spending $60 at the end though for the entire collection.
The stuff Kent includes is good for 3 cars for a good dozen years or more it seems.
Disclaimer: I'm not related to Kent, just enjoy his videos, so this is my way of donating to the cause.
I'll post my cheat-sheet when I get home as it is in that very same lubricant tray.
- Cheers!
dolucasi is offline
post #25 of 29 (permalink) Old 01-04-2019, 02:46 PM
magicbigdaddy's Avatar
Date registered: Dec 2006
Vehicle: 1989 560 SEC - V-8 Kompressor - 95 E320 Estate
Quoted: 324 Post(s)
Here is a relatively new all purpose lubricant I have been using for over a year. Much better than WD and others. I do like the Tri-flow as well. This stuff works well on hinges, linkages, locks and is rubber friendly. Haven't performed a comparison to AstroGlide. Ultralube.com
1989 560 SEC Supercharged - 317+ rwhp - H&R lowered - OZ 3 piece staggered wheels - upgraded brakes - AMG Tri-Y's - Bergwerks FGS - a true Euro Rod
1981 500SE euro AMG
1985 euro 500SEC
1986 560 SEC
1985 500SEL
1989 560SEC
1990 560SEL
1987 euro 560SEL 300hp 822 engine option
magicbigdaddy is offline
post #26 of 29 (permalink) Old 01-04-2019, 03:00 PM
281lxm's Avatar
Date registered: Dec 2011
Vehicle: 1991 560 SEC 1994 E500 2014 E350 Cab
Quoted: 435 Post(s)
Originally Posted by bsclifton View Post
Where do you get these? I have a Hirschmann universal antenna fitted (was there when I bought the car) with a bent mass which is totally nasty. Probably easier to just buy a new mast, but would be great to know where to order once I get it sorted
I got them from Ebay, of course. Take the whole thing apart, clean decades of crap out of it with brake clean, dry and lube with a synthetic lube, lather up the gears and tracks of the motor assembly/worm gear. I replaced some broken gears on my E500 and both masts. Slippery and silent.
_____________________________________________
1991 560SEC 199 /268, 17" RS90'S, Eibach springs, Bilstein HD shocks, Custom rear sway bar, Euro Headlights, Custom ceramic coated headers and down pipes with stainless dual exhaust, W140 glass sunroof, dog ear trunk spoiler, OEM Skid Plate, Euro bumpers, wood refinish and restored.
281lxm is offline
post #27 of 29 (permalink) Old 01-04-2019, 06:41 PM
Quoted: 533 Post(s)
Here's Kent's kit. Highly recommend just ordering from MercedesSource and be done with it.
Sure you can save 20 bucks if you order everything separately if you have the patience to learn everything about lubricants.
Also included are some empty containers and applicators you can use for things like ATF (throttle actuators/linkage), etc. not included in the kit.
- Cheers!
dolucasi is offline
post #28 of 29 (permalink) Old 01-04-2019, 10:07 PM
macdeity's Avatar
Quoted: 76 Post(s)
dolucasi, thanks for the great info, will come in very handy!
macdeity is offline
post #29 of 29 (permalink) Old 01-08-2019, 04:54 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 64 Post(s)
Misc Lubricants : i. had raised this question a few years back whilst in process of lubricating the heater fan motor.
I have mostly used ATF for accelerator linkages and fan motor bushes as required.
Newer lubricants available now, preferably, someone opting for mso2 -- molybdenum disulphide -- synthetic oil , graphite oil ,or similar lubricant that will not oxidise over time or have better retention properties ?
adler is offline
