Oil Pan Gasket - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 12-20-2018, 08:29 AM Thread Starter
hugo2648's Avatar
Date registered: Aug 2007
Vehicle: 90 420SEL, 00 BMW X5, 00 Lexus RX300, 01 Chrysler Town and Country
Quoted: 98 Post(s)
Oil Pan Gasket
I need to change the O-ring in the oil level sender. It is leaking. I understand that the sender needs to be installed from inside so the pan has to be dropped.
It appears that there is an upper and a lower oil pan gasket. Which one do I need to order? Or both? Is there more than one joint at the block so two different gaskets are needed.
I guess all can be answered by looking at the car but I am at work and wanted to get the order for the gasket going.
hugo2648 is offline
post #2 of 6 (permalink) Old 12-20-2018, 08:36 AM
liviu165's Avatar
Date registered: Aug 2013
Vehicle: 1989 MB 420SEL, 1991 560SEC
Quoted: 623 Post(s)
Only the lower pan gasket. Replacing the sump end (1021860007) at this time would be nice, but not necessary.
luckymike likes this.
liviu165 is offline
post #3 of 6 (permalink) Old 12-20-2018, 06:50 PM
Tom Kaiser's Avatar
Date registered: Jul 2010
Vehicle: 1989 SEL 560
Quoted: 134 Post(s)
Be sure to rotate the engine so that the crankshaft counter weight is not blocking the oil sender unit inside the oil reservoir area. The oil sender unit pushes into the engine and it needs room so that it can be removed without damage.
Tom Kaiser is offline
post #4 of 6 (permalink) Old 12-20-2018, 08:01 PM
MBL87560SEC's Avatar
Date registered: Jul 2004
Vehicle: 1991 500SEC sub 50K mi. 1987 560SEC Now 150K mi. 2018
Quoted: 396 Post(s)
In addition to wisdom already offered, I post.....
This gasket for lower sump will be sufficient.
I had this job done at an oil change, turning the crankshaft to accommodate needs....
MBL
91 500SEC EURO Germany
87 560SEC USA 49 State Version
MBL87560SEC is offline
post #5 of 6 (permalink) Old 12-21-2018, 08:58 AM
Date registered: Sep 2016
Vehicle: 1986 420 SEL
Quoted: 29 Post(s)
It is the lower gasket. I used a little bit of hylomar to help seal the gasket. I didn't have to rotate the crank, I guess I lucked out. It's a very easy job in comparison to pulling the oil pan on a number of other cars (like an old porsche 944 or 928).
EEBreh is offline
post #6 of 6 (permalink) Old 12-23-2018, 04:56 PM
281lxm's Avatar
Date registered: Dec 2011
Vehicle: 1991 560 SEC 1994 E500 2014 E350 Cab
Quoted: 435 Post(s)
And while you are in there, change the sump rubber pickup and screen.
_____________________________________________
1991 560SEC 199 /268, 17" RS90'S, Eibach springs, Bilstein HD shocks, Custom rear sway bar, Euro Headlights, Custom ceramic coated headers and down pipes with stainless dual exhaust, W140 glass sunroof, dog ear trunk spoiler, OEM Skid Plate, Euro bumpers, wood refinish and restored.
281lxm is offline
