High idle - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 12-11-2018, 10:58 AM Thread Starter
gogi's Avatar
Date registered: Jan 2008
Vehicle: 1991 560sec. 1969 280SL
Quoted: 232 Post(s)
High idle
I have no vacuum leaks, tried another idle control module and a idle control slide valve. The high idle is intermittent and is 1000rpm when it gets normal itís 550-650. Iíve unplugged the TPS and the idle shoots up so, thatís functional.
Thoughts please. Thanks.
gogi is offline
post #2 of 13 (permalink) Old 12-11-2018, 01:02 PM
ianrandom's Avatar
Date registered: Jul 2008
Vehicle: 1986/1990 W126
Quoted: 1161 Post(s)
I will say try some more valves and idle units if you can. I had three faulty valves but didn't imagine all 3 could be faulty. Took me ages to figure out that's all it was.
'86 420SE
'90 420SEC
Daily transport 9spd Giant DH Comp downhill bike
ianrandom is online now
post #3 of 13 (permalink) Old 12-11-2018, 04:12 PM
luckymike's Avatar
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1989 560SEL, 1995 E420
Quoted: 553 Post(s)
Look closely at the wiring at the idle control valve. I believe it was 281lxm who had broken wiring that was causing a problem.
281lxm likes this.
luckymike is offline
post #4 of 13 (permalink) Old 12-11-2018, 04:24 PM
281lxm's Avatar
Date registered: Dec 2011
Vehicle: 1991 560 SEC 1994 E500 2014 E350 Cab
Quoted: 435 Post(s)
I agree, pull electrical plug from the valve. If idle stays High, you have broken wires or a stuck valve. I recently gave Euro500 a length of wire with a cap for the same harness - this case it was the temp sensor. If you are board, rebuilding that harness for temp, idle 6Ē up with heavier gauge wire a d hear rated shrink is a good mod.
_____________________________________________
1991 560SEC 199 /268, 17" RS90'S, Eibach springs, Bilstein HD shocks, Custom rear sway bar, Euro Headlights, Custom ceramic coated headers and down pipes with stainless dual exhaust, W140 glass sunroof, dog ear trunk spoiler, OEM Skid Plate, Euro bumpers, wood refinish and restored.
281lxm is offline
post #5 of 13 (permalink) Old 12-11-2018, 04:34 PM Thread Starter
gogi's Avatar
Quoted: 232 Post(s)
I wish it were that simple. There is no break in the wiring my high idle is no more than 950 to 1k rpm. If I unplug the ICV the idle shoots up past 1500rpm. If I unplug the ICM it shoots up the same. The idle is intermittently going up.
gogi is offline
post #6 of 13 (permalink) Old 12-11-2018, 04:42 PM
281lxm's Avatar
Quoted: 435 Post(s)
Are you calling the Idle Control Relay The ICM?
281lxm is offline
post #7 of 13 (permalink) Old 12-11-2018, 04:47 PM
281lxm's Avatar
Quoted: 435 Post(s)
I donít have all the values here at the dinner table but voltage checks at each connection and possibly at X11 DS fender.
281lxm is offline
post #8 of 13 (permalink) Old 12-11-2018, 05:47 PM Thread Starter
gogi's Avatar
Quoted: 232 Post(s)
Yes, idle contro module or relay.
281lxm likes this.
gogi is offline
post #9 of 13 (permalink) Old 12-11-2018, 06:53 PM
281lxm's Avatar
Quoted: 435 Post(s)
Check your ovp relay, perhaps change the fuses. Or just replace with MB version. These things donít respond well to battery tender, so precaution would be to unplug the relay while it trickles.
281lxm is offline
post #10 of 13 (permalink) Old 12-13-2018, 06:32 PM
RNT
RNT's Avatar
Date registered: Jul 2007
Vehicle: 1985 Mercedes 380SE Metallic Navy Blue
Quoted: 4 Post(s)
I have had high idle prob for a while. At start I have high idle 1200 and it stays there. Some days but not always, it starts at 5-600 and after a while it jumps quickly to 12-1300.
My question is: Aside from the Idle Control Valve, is there anything else that could cause the problem? I have replaced all fuses.
RNT is offline
