Rear window defroster - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-09-2018, 06:36 AM Thread Starter
Tom Kaiser's Avatar
Date registered: Jul 2010
Vehicle: 1989 SEL 560
Quoted: 134 Post(s)
While testing to see if my vehicle starts better in cold weather I am able to document that the rear window defroster is not functioning properly. Has anyone seen this defrost pattern before and what is the solution?
ID:	2471766   Click image for larger version
ID:	2471768   Click image for larger version
Tom Kaiser is offline
post #2 of 3 (permalink) Old 12-09-2018, 06:56 AM
281lxm's Avatar
Date registered: Dec 2011
Vehicle: 1991 560 SEC 1994 E500 2014 E350 Cab
Quoted: 435 Post(s)
If you have ever seen the glass edge not installed, you may have seen the silver metal along the lower vertical edge and curve. Possible that the copper wires have pulled away as the glass separates over time or they have just broken the contact. For me, the few times I need to defrost, i just scrape. I removed the plug from the switch to avoid heating the glue that holds the glass halves together.
_____________________________________________
1991 560SEC 199 /268, 17" RS90'S, Eibach springs, Bilstein HD shocks, Custom rear sway bar, Euro Headlights, Custom ceramic coated headers and down pipes with stainless dual exhaust, W140 glass sunroof, dog ear trunk spoiler, OEM Skid Plate, Euro bumpers, wood refinish and restored.
281lxm is offline
post #3 of 3 (permalink) Old 12-09-2018, 09:31 AM
kevdupuis's Avatar
Date registered: May 2016
Vehicle: 1985 300 TD 1981 300 SD
Quoted: 37 Post(s)
Yours is in better shape than mine I only get one thin line across the the middle, once I have some extra time I'll stop in at a local glass shop and see if they have or can get an after market defroster grid and have that installed on my 81.
kevdupuis is offline
