Bought a non-running 420sel and found a surprise in the records. How screwed am I? - Page 2 - Mercedes-Benz Forum
post #11 of 37 (permalink) Old 12-01-2018, 09:51 AM Thread Starter
flynscot96's Avatar
Date registered: Nov 2018
Vehicle: 1991 300D 2.5 - 1989 420SEL -2015 GLK350
Quoted: 7 Post(s)
Originally Posted by 281lxm View Post
If you are part of the mb club in dallas reach out to Alabasi, he has engines in his shop. If you want to pm me your name and contact info and I can have him reach out
Oh, yes. I致e seen some of his posts, I think. Seems like a cool person.
I知 out flying right now (pilot), but will PM maybe this evening when I get to the overnight.
flynscot96 is offline
post #12 of 37 (permalink) Old 12-01-2018, 10:28 AM
John350's Avatar
Date registered: Nov 2014
Vehicle: 1990 350SDL, "Grandpa's Roadster" Project Car
Quoted: 799 Post(s)
If the valves got bent slightly, it might have taken 25,000 miles for them to finally burn to the point where they cause the engine to stall at idle. I'd suggest a boroscope inspection. If the valves are burnt to the point where they are not round, don't run it any more; pieces can start falling off next.
flynscot96 likes this.
John
"Real engines don't have spark plugs!"
John350 is offline
post #13 of 37 (permalink) Old 12-01-2018, 01:13 PM Thread Starter
flynscot96's Avatar
Quoted: 7 Post(s)
‘scoping was something I was contemplating. Thanks for confirming. Is there an at-home scope that’s of decent quality?
post #14 of 37 (permalink) Old 12-02-2018, 12:41 AM
Richter Rox's Avatar
Date registered: Aug 2016
Vehicle: 1988 560 sec
Quoted: 184 Post(s)
If it comes to it i would rather swap in a 560 motor than do a top end job , if you are doing the work yourself the cost and time involved would be similar .
Richter Rox is offline
post #15 of 37 (permalink) Old 12-04-2018, 09:18 AM Thread Starter
flynscot96's Avatar
Quoted: 7 Post(s)
John350 got me thinking seriously about borescoping this thing before proceeding further.
全cope arrived last night. I値l turn it trough by hand and hopefully have a decent look at the pistons and valves sometime today or tomorrow. If all looks decent, I値l follow up with a compression and leak test.
At that point, we値l hopefully know what direction to start looking.
luckymike and Eddieba like this.
post #16 of 37 (permalink) Old 12-05-2018, 03:16 AM
Tom Kaiser's Avatar
Date registered: Jul 2010
Vehicle: 1989 SEL 560
Quoted: 134 Post(s)
What brand scope did you purchase and a relative price if you don't mind? Thanks - Tom
Tom Kaiser is offline
post #17 of 37 (permalink) Old 12-05-2018, 09:11 AM Thread Starter
flynscot96's Avatar
Quoted: 7 Post(s)
I did some digging around and found this one reviewed by a guy on YouTube who was inspecting his own heads. Seemed decent, and at ~$35USD, pretty inexpensive. Many uses.
This is an updated version from the one in the video I watched-- it has a stiffer cord that is more easily twisted/manipulated inside the bore without having to add reinforcement/stiffness, has an adjustable light source, and is rechargeable, so you can use it cordlessly. It transmits wirelessly to iPhone or Android via WiFi. Comes with a mirror attachment to look up towards the valves, or there are a couple of different ways to get the camera to bend back on itself for a direct look up at the valves.
Pretty cool. I played around with it yesterday and it gives really good detail. Hopefully will be able to get it into my engine today. I'll post pics of the bores/pistons/valves if it works out OK.
Eddieba likes this.
post #18 of 37 (permalink) Old 12-05-2018, 10:35 AM
Date registered: Feb 2008
Vehicle: Too many to list
Quoted: 1508 Post(s)
If you can take some screenshots on your phone and post them
tusabes is online now
post #19 of 37 (permalink) Old 12-05-2018, 05:20 PM Thread Starter
flynscot96's Avatar
Quoted: 7 Post(s)
Uploaded some video of the car (walkaround and under-valve-cover inspection).
Haven't had a chance to 'scope the engine yet, but I did put manage to clean up under the hood, scrape off the old hoodliner (it was baaaad), pull the valve covers, and do an initial visual inspection of the valvetrain.
Timing chain and guides look good, no slop or looseness. You can definitely tell something was up with the left bank at one time, though-- there is evidence of the chain eroding the edge of the valve-cover gasket seat slightly on the inboard side above the chain guide. Cam lobes look good (maybe even great). Oiler tubes are intact and the plastic clips holding them in are tight. Clean under the valve covers. So far so good. Pulled the fan, but ran out of daylight before I could pull the plugs and turn over the engine for a borescoping. Hopefully tomorrow if the rain isn't too bad.
post #20 of 37 (permalink) Old 12-05-2018, 06:32 PM
Date registered: Jun 2018
Vehicle: 1991 350SD
Quoted: 5 Post(s)
Chain jumped over
What you have is bent valves on driver side. It is common problem with 116 and 117 engines. Chain rail on driver side (most likely lower rail) broke and part of it got between chain and crankshaft gear, the chain got on the top of the camshaft gear on driver side, cracked the valve cover and jumped over the gear. The valve timing got out of sync, pistons and valves hit each other and now you have bent valves. that is why you have problem with compression on driver side and car runs rough. They should have pulled the driver side head and replace bent valves. Most likely only the driver side has problem. When the chain nylon rails are new they are flexible, but over the years from heat and age they became fragile like glass and when the stretched chain flaps around (usually in the morning) it cracks the rail before the chain tensioner puts enough tension on it. I saw it way too many times over my 40 years working on Benzes, even on low mileage cars (70-80K).
pepaglobal is offline
