New vibration - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 10-30-2018, 12:41 PM Thread Starter
Mercrazy's Avatar
Date registered: Jun 2018
Vehicle: 1988 420 sel
Quoted: 5 Post(s)
New vibration
Ok i put new tires on the my 88 420 before the new tires it didnt vibrate the tires are balanced and checked twice its not the tires. The vibration is in the back half of the car. It vibrates above 45 mph about 70 kph im thinking its the center drive shaft support or the cv axles. Please help
Mercrazy is offline
post #2 of 8 (permalink) Old 10-30-2018, 01:51 PM
gogi's Avatar
Date registered: Jan 2008
Vehicle: 1991 560sec. 1969 280SL
Quoted: 236 Post(s)
You might have tire thatís out of round.
gogi is offline
post #3 of 8 (permalink) Old 10-30-2018, 01:53 PM
Richter Rox's Avatar
Date registered: Aug 2016
Vehicle: 1988 560 sec
Quoted: 185 Post(s)
If it did not vibrate before the new tires were installed and vibrated right after the new tires were installed it is the tires . Do you have spacers or hub centric Rings on your car ?
swap the fronts to the rear of the car and take it for a drive. Are your rims stock?
Richter Rox is offline
post #4 of 8 (permalink) Old 10-30-2018, 02:01 PM Thread Starter
Mercrazy's Avatar
Quoted: 5 Post(s)
Everything is stock no spacers no rings
Mercrazy is offline
post #5 of 8 (permalink) Old 10-31-2018, 03:02 AM
ianrandom's Avatar
Date registered: Jul 2008
Vehicle: 1986/1990 W126
Quoted: 1179 Post(s)
@Mercrazy , you're gonna need to fill in some profile information. Your other thread on this got auto moderated by the system as sometimes happens, as it thinks people without profile info are spammers.
I unmoderate them if I see them, it depends on us noticing them though and if we're browsing on mobile devices it is a lot harder to notice. So some people without profile information never get their questions answered.
If you're having trouble, try on a PC.
wooky_chew_bacca likes this.
'86 420SE
'90 420SEC
Daily transport 9spd Giant DH Comp downhill bike
ianrandom is online now
post #6 of 8 (permalink) Old 10-31-2018, 07:09 AM
Tbilisi79's Avatar
Date registered: Oct 2005
Vehicle: 420SEL
Quoted: 107 Post(s)
Send a message via Yahoo to Tbilisi79
Ah the pain of solving vibrations.
If all was well before I would suspect the new tires, balancing equipment or install. If the shop that did the work doesnít maintain its equipment, itís possible their balancer is not up to spec.
I assume you checked of all the wheel bolts are tight.
You can go all out and have them Road force balance the tires to wheels. Itís about $30 a tire.
If that doesnít solve it, Iíd say itís the new tires.
Which tire did you get ?
1992 Lincoln Mark VII LSC
2008 Lexus LS460
1990 Mercedes 420SEL
Tbilisi79 is offline
post #7 of 8 (permalink) Old 10-31-2018, 08:03 AM
luckymike's Avatar
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1989 560SEL, 1995 E420
Quoted: 576 Post(s)
One last check on the tires is to move the rears to the front and see if the vibration is now evident in the steering wheel. If not, I'd be looking at the driveshaft.
luckymike is offline
post #8 of 8 (permalink) Old 10-31-2018, 08:48 AM Thread Starter
Mercrazy's Avatar
Quoted: 5 Post(s)
I jacked the rear up and took the tires off and got it to speed and it still vibrates i let it spin in idle and it looks like my drive shaft is bouncing so im thinking its the center support bearing or its bent
luckymike likes this.
Mercrazy is offline
