560 SEC oil consumption - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-25-2018, 09:09 AM Thread Starter
Date registered: Jan 2007
Vehicle: 1979 280 SLC, 1987 560SEC, 1995 E280T
Quoted: 6 Post(s)
Dear MB enthusiasts,
I'm running out of possibilities to explain increased oil consumption of my 1987 560SEC especially at highway speeds (around 3 liters for every 1000km). My first guess was the valve stem seals but the spark plugs are dry and light brown. Piston rings are another possibility but I'm having perfect compression on all eight cylinders (about 9kg).
There are no leaks that would explain such an amount of oil being lost and I don't notice smoke coming out of the exhaust either (except grey smoke under hard acceleration at highway speed which I suspect is just burnt gasoline).
Am I overlooking something?
Your suggestions would be much appreciated.
Tempur
tempur is offline
post #2 of 5 (permalink) Old 10-25-2018, 09:57 AM
Tom Kaiser's Avatar
Date registered: Jul 2010
Vehicle: 1989 SEL 560
Quoted: 140 Post(s)
Tempur
I just replaced the valve stem seals on my 560 and it appears that my oil consumption has dropped to zero. I don't have enough miles yet to be absolutely certain but it sure looks good at this point.
I was not able to detect smoke coming out of the exhaust but I used to have little black dots on the concrete below the tailpipe frequently. Since the valve stem job those black dots no longer appear after a start up.
mramay and 281lxm like this.
Tom Kaiser is offline
post #3 of 5 (permalink) Old 10-25-2018, 08:43 PM
Date registered: Feb 2008
Vehicle: Too many to list
Quoted: 1549 Post(s)
My guess is also valve stem seals
tusabes is offline
post #4 of 5 (permalink) Old 10-28-2018, 05:07 PM
Stutz's Avatar
Date registered: Oct 2009
Vehicle: 1999 500SL, 1988 SEC
Quoted: 257 Post(s)
Before I redid the heads I changed the valve seals and fiund the old ones to be very brittle. The cost of these are negligible (lot of work though) and I doubt its rings. If it does not leak oil then its the seals
Stutz is offline
post #5 of 5 (permalink) Old 10-29-2018, 04:43 AM
John350's Avatar
Date registered: Nov 2014
Vehicle: 1990 350SDL, "Grandpa's Roadster" Project Car
Quoted: 824 Post(s)
Leaky valve guide seals will often show up as blue smoke under heavy engine braking. If you can get someone to follow you, run the engine up to high speed in the lowest gear you have, then close the throttle abruptly and let the engine slow the car. The high manifold vacuum pulls oil past the seals and you should see blue smoke in the tailpipe.
Tom Kaiser likes this.
John350 is offline
