Coupe windows scratched. - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 09-06-2018, 06:07 AM Thread Starter
BGW500's Avatar
Date registered: Jun 2018
Vehicle: 85 Mercedes 500 SEC
Quoted: 40 Post(s)
The rear windows in my SEC look as though they are scratching on the outside when they are put down and up. Has anyone had that issue? What did you do to fix it? I'm reluctant to put them down until I can fix it.
BGW500 is offline
post #2 of 15 (permalink) Old 09-06-2018, 07:45 AM
Richter Rox's Avatar
Date registered: Aug 2016
Vehicle: 1988 560 sec
Quoted: 184 Post(s)
yes my passenger window has these scratches. the rubber seals at the base of the window have some grit or sand on them. you need to clean those seals by either removal and cleaning or lower the window and clean them.
try slipping a thin sheet of plastic or cardboard between the window and seal before you lower it . use a folder file or something similar .
Richter Rox is online now
post #3 of 15 (permalink) Old 09-06-2018, 08:12 AM Thread Starter
BGW500's Avatar
Quoted: 40 Post(s)
Thanks I did go and have a look. Can you replace that rubber trim? Mine are old and brittle one side has a crack in the middle of them.
BGW500 is offline
post #4 of 15 (permalink) Old 09-06-2018, 11:34 AM
Quoted: 184 Post(s)
never replaced them myself but I am sure they can be replaced . see if the part is available a dealer site or epc .
post #5 of 15 (permalink) Old 09-06-2018, 02:05 PM
liviu165's Avatar
Date registered: Aug 2013
Vehicle: 1989 MB 420SEL, 1991 560SEC
Quoted: 617 Post(s)
The outside wiper gasket has some felt surface where it contacts the glass. Yes, if sand gets there, when you lower the window it will scratch the glass. I just bought new ones for my 1991, the part numbers are 1266700138 and 1266700238. I am assuming yours are the same.
First you pull up the chrome molding that is on the outside. Be careful not to bend it (it has 5 clips that hold it to the car). Then the gasket. The clips actually secure the molding and the gasket at the same time. The gasket may come out at the same time with the molding.
It happens that I have the passenger side out and tonight I plan on putting it back on the car. I will take some pictures and post them for you to see.
EDIT: i bought mine from the dealer. First was 168.00 USD and second 169.40USD (shipping and tax extra).
liviu165 is online now
post #6 of 15 (permalink) Old 09-06-2018, 07:46 PM
vdubpower's Avatar
Date registered: Nov 2003
Vehicle: 1985 500sel and 500sec 2012 E63 1989 Porsche 911
Quoted: 538 Post(s)
buy some moleskin felt and apply that to the edge
1985 500SEL Euro Nautic Blue - A Classic Beauty
1985 500SEC Euro Nautic Blue
1989 Porsche 911 Carrera Silver Anniversary Edition
2012 E63 AMG Iridium Silver - Performance Package
vdubpower is offline
post #7 of 15 (permalink) Old 09-06-2018, 08:27 PM
liviu165's Avatar
Quoted: 617 Post(s)
Here are the pictures at assembly. For disassemby just start in reverse order.
ID:	2452323   Click image for larger version
ID:	2452325   Click image for larger version
ID:	2452327   Click image for larger version
ID:	2452329   Click image for larger version
AxelWulff and luckymike like this.
post #8 of 15 (permalink) Old 09-06-2018, 09:41 PM
luckymike's Avatar
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1989 560SEL, 1995 E420
Quoted: 535 Post(s)
Gorgeous. I want to do this project!
liviu, you might want to push your rear seat belt buckles into the cutout in the rear seat cushion so they don't put a permanent dent in the seat back.
liviu165 likes this.
luckymike is online now
post #9 of 15 (permalink) Old 09-06-2018, 11:10 PM
magicbigdaddy's Avatar
Date registered: Dec 2006
Vehicle: 1989 560 SEC - V-8 Kompressor - 95 E320 Estate
Quoted: 322 Post(s)
OMG skinning poor little Moles. First it was Minks, now Moles.
1989 560 SEC Supercharged - 317+ rwhp - H&R lowered - OZ 3 piece staggered wheels - upgraded brakes - AMG Tri-Y's - Bergwerks FGS - a true Euro Rod
1981 500SE euro AMG
1985 euro 500SEC
1986 560 SEC
1985 500SEL
1989 560SEC
1990 560SEL
1987 euro 560SEL 300hp 822 engine option
magicbigdaddy is offline
post #10 of 15 (permalink) Old 09-07-2018, 04:58 AM Thread Starter
BGW500's Avatar
Quoted: 40 Post(s)
Thanks for the pictures and advice. Luckily I checked back because I didn't get an email about a reply.
BGW500 is offline
