Need help with my sunroof in my 1986 560SEC - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 09-04-2018, 09:59 AM Thread Starter
Date registered: Sep 2017
Vehicle: 1986 560 SEC
Quoted: 14 Post(s)
Hi Guys
I also have a cursed sunroof.
Where can I find parts for it - need the drive cable and brackets/arm brackets
THANKS guys
theforce88 is offline
post #2 of 7 (permalink) Old 09-04-2018, 10:59 AM
mclare's Avatar
Date registered: Aug 2008
Vehicle: 2012 CL550 4MATIC Coupe
Quoted: 311 Post(s)
Send a message via Yahoo to mclare Send a message via Skype™ to mclare
I probably have a master list made up. PM me your email and I'll send what I have. You should also check out my rebuild threads on how to fix it all. If I were you I would reach out to @bondavi or @jonwhite99 and replace your metal roof with a W140 Glass roof capsule. Same amount of work, but you'll get a better end product.
Current Stable:
2012 CL550 C4 4MATIC Coupe
Past cars:
1991-560 SEC AMG - Coupe - 199/261 - 300 HP Custom Built Motor - Highly Modified Coupe.
1990-560 SEL - Sedan - 199/261 - Stock. Euro Headlamps & Wipers
1987 560 SEC Black/Tan
1988 420 SEL Champagne/Brown
mclare is offline
post #3 of 7 (permalink) Old 09-04-2018, 11:09 AM
humblejoe's Avatar
Date registered: Feb 2007
Vehicle: 04 odyssey (265k) 1995 E320 wagon (295k)
Quoted: 329 Post(s)
Theforce...I have an entire 040 Cassette (unbolt the whole sunroof in one piece) in excellent condition, as well as a motor if you need that as well.
PM if interested. I'm 45 min west of Philly.
GreenT likes this.
"alte Schulqualität"
W124, One of the last great gifts of West Germany
humblejoe is offline
post #4 of 7 (permalink) Old 09-04-2018, 12:24 PM
mclare's Avatar
Quoted: 311 Post(s)
If you need help with the R&R, I have done many of them. Also, the cable, or "Rope" as Mercedes calls them HAS TO BE replaced and it should be still available and has a new and improved design to it.
Current Stable:
Past cars:
mclare is offline
post #5 of 7 (permalink) Old 09-05-2018, 03:47 PM Thread Starter
Quoted: 14 Post(s)
Does the sunroof in my 86 suppose to only tilt or its suppose to slide back as well?
Thanks guys
post #6 of 7 (permalink) Old 09-06-2018, 01:16 AM
ianrandom's Avatar
Date registered: Jul 2008
Vehicle: 1986/1990 W126
Quoted: 1181 Post(s)
Yes should do both. The tilt function can get more fragile after years of no lubricating and baking in the heat. Also the seal can get in the way when it gets old and hamper the movement.
Parts should be available from MB. The arms can be wickedly expensive but there was a solution posted up recently. Check the search archives or DIY thread I would.
As mentioned above, if its bad it's sometimes easier to change the whole cartridge since it comes out as a package. Not as hard as yours think although seats and headliner need to come out. Then some folks have changed theirs too the next model on which is glass.
'86 420SE
'90 420SEC
Daily transport 9spd Giant DH Comp downhill bike
ianrandom is offline
post #7 of 7 (permalink) Old 09-06-2018, 04:11 AM Thread Starter
Quoted: 14 Post(s)
Anyone can help me with video/instruction how to replace the whole cartridge ?
Thanks
