HVAC erratic - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 07-23-2018, 06:30 AM Thread Starter
Date registered: Nov 2006
Vehicle: 83 500SL (Used, from original owner) 85 380 SE (new) 07 CLS 63 AMG (new) 18 GLC 300 (new)
Quoted: 30 Post(s)
HVAC erratic
On my 85 380SE, 139000 miles, bought new, there is intermittently no fan response to the HVAC console pushbuttons. The compressor does appear to engage properly but the fan does not come on regardless of which button is pressed. So far it has always spontaneously recovered and works completely normally including a/c when it does function. The malfunction seems erratic and random. The HVAC control unit is all original to the car. Any thoughts would be appreciated.
highleymd is offline
post #2 of 6 (permalink) Old 07-23-2018, 06:31 AM
mclare's Avatar
Date registered: Aug 2008
Vehicle: 2012 CL550 4MATIC Coupe
Quoted: 311 Post(s)
Send a message via Yahoo to mclare Send a message via Skype™ to mclare
Does it work, but just blow through the defroster and footwell?
Current Stable:
2012 CL550 C4 4MATIC Coupe
Past cars:
1991-560 SEC AMG - Coupe - 199/261 - 300 HP Custom Built Motor - Highly Modified Coupe.
1990-560 SEL - Sedan - 199/261 - Stock. Euro Headlamps & Wipers
1987 560 SEC Black/Tan
1988 420 SEL Champagne/Brown
mclare is offline
post #3 of 6 (permalink) Old 07-23-2018, 07:03 AM
John350's Avatar
Date registered: Nov 2014
Vehicle: 1990 350SDL, "Grandpa's Roadster" Project Car
Quoted: 808 Post(s)
Check the fuse. It should be in a separate fuse holder. They tend to crack and not work reliably. The crack can be hard to see. If your fuse is still in the fuse box, it isn't up to the task, which could also be the problem. (That's why they've been moved...)
John
"Real engines don't have spark plugs!"
John350 is offline
post #4 of 6 (permalink) Old 07-23-2018, 08:20 AM
luckymike's Avatar
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1989 560SEL, 1995 E420
Quoted: 576 Post(s)
This sounds like the old ignition switch problem.
My fan would randomly cut out. I finally wiggled the key one time when it was happening. Fan started right up. I replaced the ignition switch and no more problems.
Turn the key as far left as you can without turning off the car and also to the right and see if that fixes it.
luckymike is online now
post #5 of 6 (permalink) Old 07-31-2018, 08:44 AM Thread Starter
Quoted: 30 Post(s)
Thanks for the responses, I will check those things. When the fan does work, the entire system is normal, air vents all put out air when they should. Kent at Mercedessource says the problem is often the fan motor itself, especially the motor brushes which wear down by this age/mileage. Fortunately, the blower assembly is easy to extract above the passenger footwell in a 126, much harder in some other models. I will check that also.
post #6 of 6 (permalink) Old 07-31-2018, 09:54 AM
281lxm's Avatar
Date registered: Dec 2011
Vehicle: 1991 560 SEC 1994 E500 2014 E350 Cab
Quoted: 436 Post(s)
Power wire to the fan was loose on mine, and finally fell off the spade. After i changed the blade fuse, wiggled the ignition I went to the fan motor and found issue. Made the spade clip tighter on the power attachment.
_____________________________________________
1991 560SEC 199 /268, 17" RS90'S, Eibach springs, Bilstein HD shocks, Custom rear sway bar, Euro Headlights, Custom ceramic coated headers and down pipes with stainless dual exhaust, W140 glass sunroof, dog ear trunk spoiler, OEM Skid Plate, Euro bumpers, wood refinish and restored.
281lxm is offline
