HELP Spark plugs will not screw in - Page 6 - Mercedes-Benz Forum
post #51 of 74 (permalink) Old 06-10-2018, 02:47 PM
liviu165's Avatar
Date registered: Aug 2013
Vehicle: 1989 MB 420SEL, 1991 560SEC
Quoted: 626 Post(s)
Congratulations, I am glad it turned out such a great success and thank you for sharing with us what you did and how you did it to correct it.
HardwayMB likes this.
liviu165 is offline
post #52 of 74 (permalink) Old 06-11-2018, 06:21 AM
John350's Avatar
Date registered: Nov 2014
Vehicle: 1990 350SDL, "Grandpa's Roadster" Project Car
Quoted: 808 Post(s)
I'm glad it all worked out well.
For anyone from the future reading this, I'll just say, I've probably installed more than 50 helicoils in spark plug holes in aluminum heads, and, while you should be cautious, you really don't need to go to all these lengths to prevent damage to the cylinder. As long as the debris is small enough to prevent it from being squeezed between the piston and the head, it'll all blow out the exhaust valve the first you turn the engine over. If you put grease on the tap, it's unlikely that anything will end up in the cylinder anyhow. If you want the belt and suspenders approach, position the crank so the piston is approaching the top of the exhaust stroke before you start and blast air in through the plug hole after you're finished.
TMSAISTI...
Richter Rox likes this.
John
"Real engines don't have spark plugs!"
John350 is offline
post #53 of 74 (permalink) Old 06-12-2018, 01:24 AM
sec-crazy's Avatar
Date registered: Feb 2018
Vehicle: 85' 500SEC Nautical Blue, 94' S600 coupe, 97' CL500, 01' ML55, ML320, Past: W210 4matic, W212 4Matic
Quoted: 42 Post(s)
Congrats, HardwayMB! Glad it all worked out! And a testament to the support of the great community here.
sec-crazy is offline
post #54 of 74 (permalink) Old 06-12-2018, 03:20 PM
oldmako's Avatar
Date registered: Feb 2013
Vehicle: 1990 560 SEC 1985 300CD
Quoted: 299 Post(s)
...As long as the debris is small enough to prevent it from being squeezed between the piston and the head, it'll all blow out the exhaust valve the first you turn the engine over. If you put grease on the tap, it's unlikely that anything will end up in the cylinder anyhow...
TMSAISTI...
My concern was with a bit of shaving getting trapped between the cylinder wall and the piston, or potentially fouling a ring somehow. No chance of that or are you counting on the soft alum not harming the cylinder wall?
Bottom Feeding Belt & Suspenders guy. One-timer with the Helicoil.
oldmako is offline
post #55 of 74 (permalink) Old 06-12-2018, 07:40 PM
John350's Avatar
Quoted: 808 Post(s)
Anything's possible, I suppose. Although, aluminum won't hurt the steel cylinder.
John
John350 is offline
post #56 of 74 (permalink) Old 05-05-2019, 01:16 PM
Silversun262's Avatar
Date registered: Jul 2014
Vehicle: 2013 C63 AMG 79K miles & 1991 560SEL 133K miles
Quoted: 5 Post(s)
Resurrecting this old thread as it seems I have the same issue on #8. All the other plugs were cake, then #8. It seems a prior plug change was botched and left uncorrected. I am ordering the back tap mentioned and used by @HardwayMB - fingers crossed it works. #8 is not the easiest to access. Also thanks to the community for taking the time to post and comment on these issues. I would be lost without.
ianrandom likes this.
Silversun262 is offline
post #57 of 74 (permalink) Old 05-05-2019, 02:02 PM
MBL87560SEC's Avatar
Date registered: Jul 2004
Vehicle: 1991 500SEC sub 50K mi. 1987 560SEC Now 150K mi. 2018
Quoted: 403 Post(s)
Originally Posted by Silversun262 View Post
I am ordering the back tap mentioned and used by @HardwayMB - fingers crossed it works. Also thanks to the community for taking the time to post and comment on these issues. I would be lost without.
On the strength of this thread, I ordered a back threads chaser too..
Good luck, man.
MBL
Silversun262 likes this.
91 500SEC EURO Germany
87 560SEC USA 49 State Version
MBL87560SEC is offline
post #58 of 74 (permalink) Old 05-06-2019, 03:05 AM
plinker17722's Avatar
Date registered: Mar 2015
Vehicle: 1989 W124 260E
Quoted: 144 Post(s)
Do the same as a chaser,, by cutting a slot down one side of an old spark plug .
Tom Kaiser and Silversun262 like this.
This is a retro ride .
plinker17722 is offline
post #59 of 74 (permalink) Old 05-08-2019, 05:52 AM
Date registered: Apr 2004
Vehicle: '91 560SEC, '98 SL500
Quoted: 160 Post(s)
Good thread certainly, I have seen many aluminum heads ruined by cross-threaded plugs. Take you time and use the "feel" method, even someone with limited experience can feel threads starting to bind..always use common sense and don't force it. I always use a dab of anti-seize as well.
Dikdaan and Silversun262 like this.
slownrusty is offline
post #60 of 74 (permalink) Old 05-08-2019, 08:55 AM
John350's Avatar
Quoted: 808 Post(s)
John
John350 is offline
