On-board KE-Jetronic test device - Mercedes-Benz Forum
LinkBack Thread Tools
Old 11-06-2017, 10:30 PM Thread Starter
H.D.'s Avatar
Date registered: May 2014
Vehicle: 1988 300CE
Quoted: 511 Post(s)
I‘d like to introduce a simple self-built on-board test device that provides diagnostic information (mainly) about the KE-Jetronic fuel injection system anytime … while driving or parking. … Makes detecting or narrowing down problems a lot easier, especially if they occur intermittently. …
I built it into what‘s otherwise useless items in my cars … the ashtray. … On the first picture below you can see the device‘s interface in the opened “ashtray“. It has two push-button switches with integrated LED‘s, a digital panel meter (voltmeter), a rotary selector switch and three test sockets for external meters. The labels on it are not up to date … shortly after I installed it (about twenty years ago) I changed the circuitry, without changing the labels, to the following functions:
1) Orange and red push-button switches
Orange switch:
When pressed in, its integrated LED, if illuminated, indicates that the FPR (Fuel Pump Relay) is providing voltage to the fuel pumps.
Depending on country version and production date cars with M103 engine have a MAS (Motoragregatesteuergerät) instead of a FPR. In that case the illuminated LED would indicate that the MAS is providing voltage to the fuel pumps.
Red switch:
When pressed in, its LED is illuminated if and for as long as the FPR (respectively the MAS) is providing voltage to the CSV (Cold Start Valve).
2) Digital panel meter (voltmeter)
Depending on the selection via rotary selector switch, it displays the following information:
P:
IACV (Idle Air Control Valve) supply voltage … provided via OVP (OverVoltage Protection relay) in case of M103 engine, respectively via OVP and IACV-ECU (N8) in case of M116 and M117 engine.
TD:
TD-signal (engine speed signal) … generated by the ignition control module based on input from the CPS (Crankshaft Position Sensor).
K1:
KE-Jetronic-ECU (N3) supply voltage… provided via OVP.
Z:
Duty Cycle (Lambda control ‘off/on’-ratio) in volts.
B:
Battery voltage.
Aus:
Digital panel meter switched “off”.
3) Red, black and green test sockets
green & black:
Alternatively to the above mentioned option “Z”, the duty cycle can be monitored in “%” with a duty cycle featuring multimeter or, more comfortably, with an analog duty cycle meter plugged into the green & black sockets above the digital panel meter.
red & black:
With a (preferably analog) multimeter plugged into the red & black sockets the o2 sensor voltage can be monitored.
Examples of use:
In case of a problem with idle speed the selector switch can be kept in position “P“ in order to monitor the IACV supply voltage on the digital panel meter. … Missing or wrong supply voltage would point to a problem with the OVP or its fuse(s) or its wires, or (in case of M116 and M117 engine) with the IACV-ECU or its wires.
With the selector switch set to “K1“ the supply voltage for the KE-Jetronic-ECU can be monitored, which is always provided via OVP, no matter which engine. … Very useful in case of various engine problems, like difficult cold starts and bad idle quality, stumbling, stalling, acceleration problems (especially if occuring simultaneously before the engine has warmed up) and higher fuel consumption, etc.. … In case of M116 and M117 engine this voltage is also the supply voltage for the IACV-ECU.
These two options “P“ and “K1“ (in case of M116, M117 just “K1“) make it very easy to check and monitor the OVP (as for its engine related functions) … thus preventing unnecessary replacements of one of the most often unnecessarily replaced parts on cars equipped with KE-Jetronic. …
Talking about often unnecessarily replaced parts … with the selector switch set to “B” the voltage regulator‘s function can be monitored too, of course.
In case of (sudden) engine stalling and subsequent starting problems the two most typical suspects can be checked in a matter of seconds immediately after the engine stalled. … You just press the orange switch “P” and set the selector switch to “TD”. Then during cranking the orange switch’s LED tells you if the fuel pumps are receiving voltage from the FPR (respectively from the MAS) or not, and the digital panel meter shows if there is a TD-signal and if its voltage is within plausible range, thus if the CPS is in order.
Checking these two things (fuel pump voltage and TD-signal) is, of course, advisable in any case of starting problems, not only after the engine stalled.
Additionally, a push on the red button shows if the system correctly orders the CSV to spray during cranking when the engine is cold… or it shows if it‘s wrongly ordered to spray when the engine is warm.
With the duty cycle being displayed (selector switch set to ”Z”) Lambda control can be monitored under all kinds of driving conditions. … Plus, keeping the switch set to ”Z” can help detect a range of (intermittent) problems. If, for instance, during driving the reading becomes static at ~8.4 volts, there is a problem with the AFM-POT (Air Flow Meter Potentiometer) ... static voltage of ~9.8 volts indicates a problem with the CTS (Coolant Temperature Sensor) ... ~11.2 volts a problem with the TPS (Throttle Position Switch) … zero volt usually indicates a problem with the OVP (verifiable by above-described option “K1“) … etc.
For a little deeper view into Lambda control (i.e. the function chain “o2 sensor - ECU - EHA”) the duty cycle can be monitored either on the digital panel meter or on a duty cycle meter (plugged into the green & black sockets) while at the same time the o2 sensor voltage can be monitored on a voltmeter (plugged into the red & black sockets).
Usually, however, I keep the device switched off and the “ashtray“ closed … and enjoy a pleasant ride. ...
Maybe some readers like the idea of such a device’s availabilty at a push on the ashtray panel and feel inspired to think about making one themselves. Works in any car equipped with CIS-E. Material costs are ~ €100 … the costs for unnecessary part replacements and troubleshooting time it can help to save I leave to the reader’s imagination. …
The only circuit diagram I have is the one I started to draw by hand when I had my first thoughts about the device. To post that one would be too confusing … there are too many subsequent changes in it. I’ll try to find some time to draw a new simple diagram soon.
H.D.
P.S. to 124-series and 129-series owners among the readers:
Note that on the CIS-E engines M104 (124 and 129) and M119 (129) the CSV control and the IACV control work a little differently.
ID:	2305410   Click image for larger version
H.D. is offline
Old 11-06-2017, 11:32 PM
Date registered: Feb 2008
Vehicle: Too many to list
Quoted: 1533 Post(s)
I don't know what this awesome gauge does but I want one !
Do you build and sell them ?
plinker17722 and sbpsu354 like this.
tusabes is offline
Old 11-07-2017, 12:50 AM
1783pictures's Avatar
Date registered: Feb 2016
Vehicle: 85 500SEC (Euro), 87 560SEC (now sold)
Location: Eastern NC (formerly China, NYC and Connecticut)
Quoted: 334 Post(s)
I think the word COOOOOOL come to mind!
1783pictures is offline
Old 11-07-2017, 11:50 AM Thread Starter
H.D.'s Avatar
Vehicle: 1988 300CE
Quoted: 511 Post(s)
Haha … I‘ve often been asked that question when CIS-E car owners saw it work. … But I‘m not planing to build and sell them. …
H.D. is offline
Old 11-07-2017, 11:52 AM
281lxm's Avatar
Date registered: Dec 2011
Vehicle: 1991 560 SEC 1994 E500 2014 E350 Cab
Quoted: 436 Post(s)
HD stands for Hard Da Get
_____________________________________________
1991 560SEC 199 /268, 17" RS90'S, Eibach springs, Bilstein HD shocks, Custom rear sway bar, Euro Headlights, Custom ceramic coated headers and down pipes with stainless dual exhaust, W140 glass sunroof, dog ear trunk spoiler, OEM Skid Plate, Euro bumpers, wood refinish and restored.
281lxm is offline
Old 11-07-2017, 01:23 PM
liviu165's Avatar
Date registered: Aug 2013
Vehicle: 1989 MB 420SEL, 1991 560SEC
Quoted: 626 Post(s)
Building the display device is relatively easy, wiring it to the car's system is not. IMO the easiest time to wire it is when you have the climate control box out for a refresh, the wires are exposed anyway so is easy to tap into them. You just have to be careful to tap in the right locations.
liviu165 is offline
Old 11-07-2017, 10:50 PM Thread Starter
H.D.'s Avatar
Vehicle: 1988 300CE
Quoted: 511 Post(s)
Originally Posted by liviu165 View Post
Building the display device is relatively easy, wiring it to the car's system is not. ...
I‘d say that building and installing the device nicely with all the wires into the tiny space of the car‘s ashtray is the relatively difficult part … wiring it to the car's system is the easier part. … I‘ll draw a simple diagram showing the wiring to the car‘s system soon. …
H.D.
luckymike and mgw001 like this.
H.D. is offline
Old 11-08-2017, 10:52 AM
liviu165's Avatar
Quoted: 626 Post(s)
The ashtray of the W126 is probably not the easiest place to install it, unless the entire astray assembly is completely removed.
liviu165 is offline
Old 11-09-2017, 02:52 AM Thread Starter
H.D.'s Avatar
Vehicle: 1988 300CE
Quoted: 511 Post(s)
It could also be installed somewhere else, of course.
… or the digital display, the push-botton switches and the test sockets could be installed in the ashtray and the selector switch somewhere else on the center console.
… or it could be installed in a small box with a cable attached to it. And if you want to use it you take it out of the glove box, or wherever you want to store it, fix it somewhere like a smartphone and connect it to a multi plug that you install somewhere (on the center console).
… or you incorporate the male part of the multi plug directly to the back of the box and connect the box cable-free to the female part of the multi plug on the center console.
I selected the ashtray, because I wanted the decice to be visible only when I use it … and the ashtray served no other purpose anyway.
H.D.
H.D. is offline
Old 11-10-2017, 10:12 AM Thread Starter
H.D.'s Avatar
Vehicle: 1988 300CE
Quoted: 511 Post(s)
Here‘s a simple diagram of the wiring to the car‘s system.
In case of a MAS (instead of a FPR) the labeling at the wire of the first push-button switch (fuel pump voltage) would be “MAS, 87”, instead of “FPR, 87“ (“Fuel Pump Relay, terminal 87”) … and the labeling at the wire of the second push-button switch (CSV voltage) would be “MAS, 87V”, instead of “FPR, 87V“.
But I actually tapped the fuel pump voltage, coming from the FPR, at connector “X36” under the right back seat … and the TD-signal, coming from the diagnostic coupling X11, I tapped at terminal “TD” of the FPR, in order to include most of the TD signal wire into the monitoring.
In case of M116 and M117 engine the wire of the rotary selector switch terminal “P“, labeled “OVP 87L”, would go to terminal 6 or 7 of the ICV-ECU “N8“, depending on which is the supply voltage terminal. Not having access to a 420 or 560 MB right now, I don’t know for sure which of the two terminals that is.
The rotary selector switch actually leads two voltages to the digital panel meter … the meter’s supply voltage and the voltage that it measures. … I’ll make a diagram using CAD that will show the wiring inside the ashtray in detail.
H.D.
Name:	wiring diagram.jpg
luckymike and liviu165 like this.
H.D. is offline
